Cumulus + mlag +bond1
Hi ,
I have a question: A server with dual NICs configured in bond1 mode (active-back) is connected to two 2700 switches (MLAG). Since it’s not LACP, does the switch support this bond1 mode (active-back) in conjunction with MLAG technology?
thank you !
Yes it is supported from the switch side. Cumulus Linux (and most other network operating systems) would consider these two ports as unrelated L2 ports; there would be no bonding configured at all on these ports since only one of them will ever be “active” at a time, no bond is necessary on the switch side.
okey,Just configure 2 switches, each with 1 port set to access mode, and you’re good to go. and the server is bond1 mode, just like this
