Cursor's AI & Visual Studio: A powerful UE5 C++ Hybrid Workflow
Cursor’s AI & Visual Studio: A powerful UE5 C++ Hybrid Workflow
Cursor is a VS Code–based editor built for AI-assisted development: it can plan work, apply multi-file changes (Agent mode), enforce team standards with rules, and navigate large codebases with strong context and code understanding. This guide shows how to use Cursor as your primary Unreal Engine C++ editor (navigation, refactors, AI-assisted changes) while keeping Visual Studio as your debugger on Windows.
  • Use this when: you want Cursor’s AI features for day-to-day development, but you still need a reliable native debugger for the Unreal Editor / your game (e.g., UnrealEditor*.exe).
  • Key constraint: the Microsoft C++ debug engine for VS Code (cppvsdbg) is restricted to Visual Studio Code and is not supported in Cursor. In practice, Visual Studio is the most reliable Unreal debugger on Windows; other debugger options exist, but this guide focuses on Visual Studio and treats Cursor as your editor/AI tool.
Figure 1: Debugging C++ code in Visual Studio while simultaneously viewing the source in Cursor and the viewport in Unreal Engine.
Scope and Guide Limitations
⚠️ Note on Feature Scope: This guide is based on a specific deployment of the Cursor editor used for internal development projects at NVIDIA. Due to internal security and compliance policies, some features or options of the public/commercial version of Cursor may not have been available or utilized during the writing of this guide. Consequently, this document may not be an exhaustive reference for all publicly available Cursor features.
Technical Scope
This guide focuses solely on Windows and UE5 C++ projects. macOS/Linux use different toolchains and debugger options and are not covered here.
Out of Scope
Source control setup and policy (Git/GitHub/GitLab/Bitbucket/Perforce, branching, reviews).
Quickstart (10–15 minutes)
  1. Install prerequisites
  • Install Cursor
  • Install Visual Studio 2022 with Desktop development with C++ (for debugging and the MSVC toolchain)
  1. Generate the UE workspace for Cursor
  • In the Unreal Editor: Edit > Editor Preferences > Source Code → set Source Code Editor = Visual Studio Code
    • Note: Unreal won’t list Cursor here; selecting “Visual Studio Code” enables VS Code-style workspace generation, which you then open in Cursor.
  • Generate the workspace:
    • Tools > Refresh Visual Studio Code Project, or
    • Right-click your .uproject > Generate Project Files
  • Open the generated .code-workspace in Cursor (recommended; it includes build tasks and launch/attach configs)
  1. Get basic code intelligence
  • In Cursor, install C/C++ (Microsoft)
  • (Optional,strongly recommended for UE C++ IntelliSense ) Install clangd (LLVM) for deeper navigation; you can add compile_commands.json later
  1. Build once from Cursor
  • Terminal > Run Build Task
  • Run your editor target build (example: YourProjectEditor Win64 Development build)
  1. Debug once in Visual Studio (recommended)
  • Generate Visual Studio project files (so you have a .sln):
    • Unreal Editor: Tools > Generate Visual Studio project files (if available), or
    • Right-click your .uproject > Generate Visual Studio project files
  • Open the .sln in Visual Studio
  • Match your config (DebugGame Editor / Development Editor) and launch or attach to UnrealEditor*.exe
  1. Optional: enable Live Coding for faster iteration
  • For small .cpp changes, compile via Unreal’s Live Coding workflow (safer than legacy Hot Reload)
I. Core AI features of Cursor (what you’ll use day-to-day)
Cursor serves as a viable alternative code editor for Unreal Engine projects. It emphasizes AI-powered assistance.
Top AI benefits for UE5 development
  • Agent Mode: Execute complex, multi-file changes across your source code using natural language commands.
  • Rules & Memories: Enforce C++ best practices and Unreal Engine coding standards automatically by providing Cursor with custom rule files.
  • Task Planning: Generate actionable, step-by-step to-do lists from design documents and execute tasks sequentially.
  • Codebase Understanding: Leverage the codebase embedding model for deep understanding and excellent context recall across large projects.
Note: Cursor assists with C++ code only. It does not have awareness of Blueprint assets or UE reflection metadata—IDEs like Jetbrains’ Rider offer tighter Blueprint integration (e.g.,viewing Blueprint property overrides, navigating between C++ and derived Blueprints). For Blueprint-heavy workflows, keep this limitation in mind.
AI feature overview
Feature Category Feature Explanation
Agent Interaction Agent Mode Used for complex tasks or when editing multiple files (source code or documents).
Agent Interaction Plan Mode Break work into a checklist before changing code; execute tasks step-by-step.
Agent Interaction Ask Mode A chat-based mode used for talking directly to the agent and asking general questions without writing code or documents.
Code Understanding Codebase Understanding Cursor’s codebase embedding model gives the Agent deep understanding and recall.
Model Selection Model Options Choose from multiple model providers (availability depends on your plan, region, and policy).
Model Customization Rules & Memories Users can customize how the models behave with reusable, scoped instructions.
Change Management Scoped Changes Agents can make targeted edits or run terminal commands using natural language. Changes made by the agent can be applied in real time.
Change Management Pending Changes Proposed changes will continue pending as long as you don’t accept or reject them; users can choose to Keep or Undo changes.
Change Management Context Control The AI defaults to including the file you are looking at as context, but users can manually add more.
Advanced Input Image Input The agent chat window can accept images quite well, allowing analysis of visual data, such as a screenshot of a trace to identify performance issues.
Code Completion Custom Autocomplete Cursor uses its own custom autocomplete model to predict user actions.
Code Completion Smart Rewrites Users can type naturally, and Cursor will finish the idea.
Review & Debug Changes Review Cursor offers review of changes to identify issues and fix them easily.
Review & Debug Debug Mode Helps reproduce and fix tricky bugs by instrumenting your app with runtime logs and AI analysis. Note: the Microsoft C++ debugger for VS Code (cppvsdbg) is not supported in Cursor,so use Visual Studio (recommended) for interactive debugging. An experimental LLDB workaround exists but is not recommended (see Debugging).
II. Debugging: why Visual Studio is the recommended default (Windows)
Cursor can open Unreal’s generated .code-workspace and run build tasks, but interactive debugging is the missing piece. Unreal’s VS Code workspace generation typically targets Microsoft’s VS Code C++ debug engine (cppvsdbg), and that engine is restricted to Visual Studio Code and does not run in Cursor.
Other debugger options exist (including LLDB-based options), but Visual Studio is generally the most stable path for Unreal debugging on Windows.
  • Recommended workflow: use Cursor for editing + AI-assisted changes, and use Visual Studio to debug (launch/attach to UnrealEditor*.exe or your game process).
  • Reference: VS Code cppvsdbg license
Figure 2: The licensing error notification you’ll see in Cursor when trying to run the Microsoft C++ debugger.
Debugging in Visual Studio (recommended)
  • Open the .sln: generate Visual Studio project files (separate from the VS Code workspace) and open the .sln in Visual Studio.
    • In the Unreal Editor: Tools > Generate Visual Studio project files (if available for your setup)
    • Or: right-click your .uproject > Generate Visual Studio project files
  • Match your build configuration: use the same config as the editor/game you’re running (e.g., Development Editor vs DebugGame Editor).
    • Tip: DebugGame Editor is a common sweet spot (debuggable game modules, optimized engine). Development Editor is faster, but variables may be optimized away.
  • Attach when needed: use Debug > Attach to Process… and select the running editor/game process (e.g., UnrealEditor*.exe or YourGame*.exe).
  • Symbols: for better callstacks/stepping, make sure you have PDBs available:
    • Launcher installs: enable Editor symbols for debugging in the Epic Games Launcher.
    • Source builds: build configurations that generate PDBs and ensure Visual Studio can find them.
Optional: LLDB workaround (experimental, not recommended)
If you really want to debug from a VS Code–style UI, you can try an LLDB-based debugger (typically via the CodeLLDB extension, debug type lldb). Treat this as experimental; for most teams, Visual Studio remains the stable default.
  • Configuration complexity: you must manually edit the generated .code-workspace file to change the debugger “type”. This change is lost every time the workspace is regenerated (unless you automate it).
Figure 3: Updating the launch.json file to use lldb for debugging Unreal Engine, bypassing the Microsoft-exclusive debugger restrictions.
  • Setup note: you must install CodeLLDB, and you may need additional config changes beyond “type” (arguments, working directory, environment, etc.).
  • Performance: launching the Unreal Editor via LLDB can be slow (often due to symbol loading/indexing).
  • Stability: LLDB-based debugging on Windows can be flaky (PDB support, crashes, slow stepping). For production work, Visual Studio is the recommended debugger.
Manual LLDB configuration steps (experimental)
The following lldb configuration steps are provided for transparency and advanced reference only, and are not the recommended workflow for production stability.
To temporarily enable an alternative debugger like lldb, you must manually edit the project’s launch configurations.
  1. Locate the Workspace File: Navigate to your Unreal Engine project’s root folder and find the Visual Studio Code workspace file, which has a .code-workspace extension (e.g., YourProject.code-workspace).
  2. Open and Edit: Open the .code-workspace file in a text editor. This file is in JSON format.
  3. Find the Launch Configurations: Search for the “configurations” array, which is nested within the main “launch” object. This array contains all the project launch profiles.
  4. Modify the Debugger Type: For each configuration you intend to debug (e.g., “Launch YourProjectEditor (DebugGame)”), find the “type” field and change its value from cppvsdbg to lldb.
Example Modification:
The following is an example of a launch configuration before modification (using cppvsdbg, which is not supported in Cursor):
“name”: “Launch CursorTestEditor (DebugGame)”,
“request”: “launch”,
“program”: “D:\\EpicGames\\UE_5.7\\Engine\\Binaries\\Win64\\UnrealEditor-Win64-DebugGame.exe”,
“preLaunchTask”: “CursorTestEditor Win64 DebugGame Build”,
// … other settings …
“type”: “cppvsdbg”,
Change the “type” field to lldb:
“type”: “lldb”,
  1. Save and Restart: Save the .code-workspace file and restart Cursor to load the new debugger configuration. You will need to repeat this process if you regenerate the project files.
From here on, we assume the hybrid workflow: use Cursor for editing and AI-assisted changes, and use Visual Studio for debugging.
With the rationale for the Hybrid Workflow established, the following sections provide the step-by-step instructions for a seamless setup.
III. Prerequisites and installation
1. Install Cursor and Visual Studio / Build Tools
  1. Install Cursor: Download and install Cursor from the official website and complete the sign-in/onboarding process.
    Quickstart | Cursor Docs
  2. Install Visual Studio 2022 (IDE) + MSVC: Unreal Engine uses MSVC on Windows. For this hybrid workflow, install the Visual Studio IDE (Community is fine) so you can debug; the standalone Build Tools are sufficient for compilation only.
  • Install Visual Studio 2022 (or Build Tools): Obtain Visual Studio 2022 Community (or Build Tools for Visual Studio 2022 if you only need to compile) from the official Visual Studio website (found under “all downloads” → “Tools for Visual Studio”).
Figure 4: If you don’t have the full Visual Studio IDE installed, you will need to download the “Build Tools for Visual Studio 2022” to get the necessary compilers and linkers.
  • Select C++ Workload: Open the Visual Studio Installer and ensure you select the “Desktop development with C++” workload.
Figure 5: Inside the Visual Studio Installer, you must ensure the “Desktop development with C++” workload is checked. This installs the essential MSVC compiler (cl.exe) and Windows SDKs required for Unreal Engine development.
⚠️ CRITICAL: match UE-required SDK versions. The MSVC toolchain, Windows SDK, and .NET runtime must match your UE version. Mismatches can cause build failures. Check your UE release notes (Platform SDK / toolchain section). (Exact version numbers change across UE releases—treat any example numbers you find online as “verify in release notes.”)
Epic’s official VS Code setup guide is still a useful reference (most steps apply to Cursor): Setting Up Visual Studio Code for Unreal Engine.
IV. Unreal Engine editor configuration
  1. Open Unreal Engine Editor: Open the Unreal Engine editor with a C++ project.
  2. Set Default Source Code Editor: Navigate to Editor Preferences (Edit > Editor Preferences) > General > Source Code. Set Source Code Editor to Visual Studio Code. Restart the editor to apply the change.
    Note: Unreal doesn’t list Cursor here; selecting “Visual Studio Code” is what enables Unreal’s VS Code-style workspace generation, which you then open in Cursor.
Figure 6: To generate the necessary .vscode configuration files that Cursor relies on, you must open the Unreal Editor Preferences and set the “Source Code Editor” to “Visual Studio Code”
  1. Generate Project Files: Generate the Visual Studio Code project files for your project.
  • This can be done by clicking Tools > Refresh Visual Studio Code Project.
  • Alternatively, on Windows, right-click your project’s .uproject file and select Generate Project Files to create a .code-workspace file.
Figure 7: After updating your preferences, navigate to the Tools menu and select Refresh Visual Studio Code Project.
Alternatively (engine source build), you can generate the VS Code workspace from the Unreal Engine root directory:
GenerateProjectFiles.bat -vscode
Note: GenerateProjectFiles.bat is typically available in engine source builds, but may not exist in Epic Games Launcher/binary installs. In that case, prefer the Unreal Editor’s Tools > Refresh Visual Studio Code Project workflow.
How to Generate Unreal Engine Project Files for Your IDE | Unreal Engine 5.7 Documentation | Epic Developer Community
V. Initial Cursor setup
  1. Open Project in Cursor: Locate the Visual Studio Code workspace file (.code-workspace) in your project folder, right-click it, and select Open with Cursor.
Figure 8: Use File > Open Workspace from File… and select the .code-workspace file.
Note: Cursor can open the project folder directly, but it’s usually better to open Unreal’s generated .code-workspace. It preserves the workspace’s build tasks and launch/attach configurations (program paths, args, Unreal.natvis, source maps), so you don’t have to create/edit that setup manually.
  1. Sign in: Sign up or log in to Cursor.
  2. Import Settings (initial): It’s usually best to skip importing VS Code settings on first launch. You can import later once you’ve confirmed which extensions/features you actually need in Cursor.
VI. Extensions and code intelligence
Cursor supports VS Code extensions. For Unreal C++ projects, install the Microsoft C++ extension for baseline functionality. clangd + compile_commands.json is optional, but strongly recommended** if you want IntelliSense and navigation to feel reliable across UE’s macro-heavy codebase (hover, Go to Definition, Find References), especially into engine source.
A. Install required extensions
  1. Install core C++ extension: Open Extensions and install C/C++ (Microsoft).
Figure 9: To ensure the best compatibility, search the Extensions Marketplace for publisher:“Anysphere”. Make sure to install the C/C++ and C# extensions.
  1. Install clangd (optional, strongly recommended): Install clangd (LLVM) for reliable C++ IntelliSense/navigation. It works best with a compile_commands.json database (see below).
Figure 10: For a faster and more accurate IntelliSense experience with Unreal Engine’s massive codebase, many developers prefer installing clangd.
Note:
  • Disable MSVC IntelliSense: To prevent conflicts/performance issues so clangd and Microsoft C/C++ don’t fight.
  • Build First: You must build the project successfully at least once for IntelliSense to work. Unreal generates headers (.generated.h) during the build; without them, clangd will report missing files.
  • Optional: For streamlined clangd setup, consider the unreal-clangd extension (UE 5.2+). It automates compile_commands.json generation and handles UE-specific configuration.
B. Install the clangd language server
  1. Download clangd: Once the clangd extension is enabled, press Ctrl+Shift+P and run:
clangd: Download Language Server
Alternatively, if the in-app download command fails, you can download the LLVM installer (which installs all necessary files) directly from its repo at Releases · llvm/llvm-project - Detailed installation steps can be found at Getting started
⚠️ Note (Windows): the clangd extension’s download typically installs the clangd language server only. If UnrealBuildTool -Mode=GenerateClangDatabase fails due to missing Clang, install the full LLVM/Clang toolchain (clang/clang-cl) via the LLVM installer above.
⚠️ LLVM version must match your UE version. Different Unreal versions require specific LLVM/clangd versions (e.g., UE 5.7 requires a different version than UE 5.6). Check the UE Release Notes (Platform SDK Upgrades section) for your version’s requirements. Mismatched versions can cause indexing failures or incorrect IntelliSense.
C. Generate a compile_commands.json database (optional)
⚠️ Note: GenerateClangDatabase is primarily intended for engine source builds and can be slow on large projects. It may also work for Launcher installs depending on UE version and install options. If it fails, you can still use Cursor with the Microsoft C++ extension—but expect less accurate navigation than clangd + compile_commands.json
  1. Run the following command and adjust the project name, UE5 location, and target directory according to your project. The recommended location for the compile_commands.json database is the root of your project.
  • Target tip: for editor development, is usually Editor (e.g., FactoryProjectEditor). Use a target/config that matches the code you work on most.
  • UBT location: in UE 5.7, use Engine/Binaries/DotNET/UnrealBuildTool/UnrealBuildTool.exe (not one of the AutomationTool/…/UnrealBuildTool.exe copies).
Placeholder command:
“<UE_ROOT>/Engine/Binaries/DotNET/UnrealBuildTool/UnrealBuildTool.exe” -Mode=GenerateClangDatabase -Project=“<PROJECT_ROOT>/.uproject” Win64 Development -OutputDir=“<PROJECT_ROOT>” -OutputFilename=“compile_commands.json”
Example command for context (line breaks for readability; run as one command):
“D:\EpicGames\UE_5.7\Engine\Binaries\DotNET\UnrealBuildTool\UnrealBuildTool.exe” -Mode=GenerateClangDatabase -Project=“D:\EpicGames\Unreal Projects\FactoryProject\FactoryProject.uproject” FactoryProjectEditor Win64 Development -OutputDir=“D:\EpicGames\Unreal Projects\FactoryProject” -OutputFilename=“compile_commands.json”
  1. Restart Cursor and check that clangd is being correctly processed. The clangd Output window will show the progress processing each source code file in the project
Figure 11: When working with a project as large as Unreal Engine, the initial indexing process can be intensive.
After clangd finishes indexing, IntelliSense and navigation (hover, go to definition, find references, etc.) should be noticeably more reliable—especially across engine code and macro-heavy headers.
Performance note: clangd can be memory-intensive on large Unreal projects, especially engine source builds. Initial indexing may take considerable time depending on project size and hardware. If clangd becomes unresponsive or uses excessive resources, you can limit background indexing in clangd settings or consider using the Microsoft C++ extension as a fallback.
VII. Building your Unreal project from Cursor
To compile your code using the tasks defined in the workspace:
  1. Go to Terminal > Run Build Task.
  2. Select one of the editor build tasks to run (e.g., FactoryProjectEditor Win64 Development build).
Figure 12: To compile your code, open the Command Palette (or press Ctrl+Shift+B) and select Run Build Task. You will see a list of targets generated by the Unreal Build Tool; typically, you will want to select your project’s Editor Win64 Development Build to compile changes for use in the editor.
VIII. Pro development tips
This section focuses on the “power user” patterns that make Cursor productive on large UE codebases while avoiding common failure modes (poor context, inconsistent conventions, and over-broad edits).
A. Use the right mode for the job
  • Ask mode: quick Q&A and explanations without changing files (in some setups, Ask can also use web-enabled tools/models).
  • Plan mode: turn a feature/bug report into a step-by-step checklist; execute tasks sequentially and mark progress as you go.
  • Agent mode: multi-file refactors and repetitive edits (run commands, edit code and docs, and apply changes in scoped chunks).
  • “Debug” (AI) mode: log-driven debugging support (separate from native debugging in Visual Studio).
  • Custom commands / instructions: define reusable workflows (e.g., /refactor, /test) and scoped rules you can invoke from chat or the terminal.
B. Rules: enforce UE C++ conventions consistently
Treat rules as “project guardrails” for the agent:
  • What to encode: naming conventions, module boundaries, ownership/memory rules, preferred patterns (UCLASS/USTRUCT usage, reflection macros, logging conventions, etc.).
  • How to scope: set some rules to always apply, and others to apply conditionally (e.g., only in specific folders/modules).
  • Where to store: keep project rules version-controlled; reserve user rules for personal preferences.
Figure 13: To help Cursor’s AI understand your specific Unreal Engine coding standards, navigate to Settings > Rules, Memories, Commands. Here, you can add “Project Rules” to instruct the AI on conventions and best practices for your project.
C. Architecture awareness: prevent subtle structural regressions
LLMs are great at producing short architecture docs for humans and for future prompts:
  • Ask Cursor to summarize subsystems, dependencies, and constraints into markdown, and include Mermaid diagrams if you like.
  • Use these docs to prevent “architecture drift” (e.g., circular dependencies, wrong dependency directions, crossing module boundaries).
  • Reference the doc(s) directly in prompts before a big change so the agent stays inside the intended design.
Figure 14: To visualize flowcharts and diagrams directly within your project documentation, you can install Markdown Preview Mermaid Support. This extension allows Cursor’s built-in Markdown previewer to render Mermaid.js code blocks, making it easier to maintain technical diagrams alongside your C++ source.
Figure 15: With the Markdown preview support enabled, you can visualize complex Unreal Engine module dependencies (like the relationship between Core SDKs, Gameplay Plugins, and Game Logic Modules).
D. Context management: control quality on large codebases
  • Watch the context indicator: Cursor shows how full your current context window is; when it gets crowded, output quality tends to drop.
Figure 16: Cursor’s large context window in action. Here, the agent is actively holding 100k tokens (out of a 272k limit) which includes a Cursor rule file with programming standards and best practices.
  • Keep it under ~70–80% when you can. Use /summarize or start a new chat between phases (design → plan → implement → cleanup).
  • Be intentional about file selection: the current file is usually included by default; add only the additional files that are truly relevant.
E. Design, planning, iteration, and change control
  • Design before code (high leverage)
  • For medium-to-large changes, start by describing the feature/system clearly and iterating on a short design and plan (e.g., design.md, plan.md) before asking Cursor to write code.
  • In practice, many teams find it takes more time to write/review the design and plan than to generate the first implementation—and that’s a good sign. When the design is strong, implementation becomes straightforward.
  • If implementation requires lots of back-and-forth (“change this, now change that”), it’s usually a symptom of a weak design/plan. In that case, it’s often faster to revert, strengthen the docs, and start a new chat with fresh context.
Figure 17: This split-screen view demonstrates Cursor’s Composer feature (often accessed via Ctrl+I). On the left, a Markdown requirement document outlines the goals. On the right, the AI agent reads that document and automatically drafts a detailed, step-by-step implementation plan with checkboxes..
  • Keep docs as durable context
  • Ask Cursor to write and iterate on design, architecture, and plan documents as .md files.
  • If code gets reverted or breaks, the docs remain and preserve the intent/context for the next attempt.
  • Plan mode execution: let Cursor generate a detailed to-do list from your requirements/design notes, then:
  • edit the plan (remove irrelevant tasks, including tests if they’re out of scope),
  • run tasks one at a time,
  • keep the plan as a “trace” of what changed and why.
  • Create a rollback point before heavy changes
  • Before asking Cursor to implement medium/heavy changes, make sure you can revert quickly (Git commit/branch, Perforce shelf, zip snapshot, etc.).
  • AI can occasionally derail or produce unsatisfactory results. Do not fight the implementation. If you find yourself in a loop of micro-corrections, conflicting changes, or widening diffs, treat it as a signal that the plan/context is wrong. Revert early and start over from a stronger design/plan (ideally in a fresh chat) rather than trying to “salvage” a broken approach.
  • Error handling: paste compiler errors, warnings, or runtime logs; ask the agent to propose a small fix + rationale; apply selectively.
  • Change review + rollback:
  • Cursor keeps a history of proposed edits and lets you review changes before accepting them.
  • If changes are pending, you can choose to Keep or Undo them.
  • If you go down the wrong path, roll back and re-approach the change in smaller, scoped steps.
F. Live Coding + hybrid workflow (optional)
Unreal’s Live Coding can dramatically speed up iteration, but it has sharp edges. The safest hybrid pattern is:
  • Edit in Cursor, then trigger Live Coding from the Unreal Editor (Compile button / Live Coding hotkey) for small changes.
  • Use full rebuilds (via Visual Studio or build tasks) with the editor closed when you make changes that Live Coding can’t safely apply.
    • External builds don’t “patch” a running editor process the way Live Coding does; when in doubt, restart the editor after a rebuild.
  • Prefer Live Coding over legacy Hot Reload. If Live Coding is disabled, compiling while the editor is open can trigger Hot Reload, which can lead to unstable editor state (especially after reflection/header changes).
Good candidates for Live Coding
  • Most .cpp implementation changes inside existing functions
  • Small behavior tweaks, logging/instrumentation, bugfixes that don’t change reflected types
Restart the editor + do a full rebuild when you change
  • Anything that requires UHT/reflection updates (e.g., UCLASS/USTRUCT/UENUM, UFUNCTION, UPROPERTY, adding/removing reflected members)
  • C++ changes that significantly affect type layout or initialization patterns (especially constructors / default subobjects)
  • Module/build configuration (*.Build.cs, dependencies, plugins)
Debugging note
  • If you’re actively stepping in Visual Studio, Live Coding can make debugging less predictable. If breakpoints stop binding or callstacks look odd after a Live Coding compile, prefer a restart + full rebuild, or detach/reattach the debugger.
G. Debugging: Visual Studio for breakpoints, Cursor for log-driven analysis
  • Interactive debugging: use Visual Studio for breakpoints, stepping, watch windows, and attach/launch debugging.
  • AI log-debug workflow (effective for “heisenbugs” and large systems):
    • Form hypotheses: have Cursor propose a few likely causes.
    • Instrument: ask Cursor to add targeted logging/telemetry.
    • Reproduce: run from Visual Studio (or launch normally) to generate logs.
    • Analyze: feed logs back to Cursor when prompted to validate hypotheses and propose fixes.
    • Iterate: repeat with tighter instrumentation until the root cause is isolated.
    • Cleanup: remove temporary instrumentation once fixed (Cursor can help do this reliably).
  • Important constraint: the VS Code cppvsdbg debug engine does not run in Cursor; treat the LLDB approach as experimental.
H. Integrations, automation, and multimodal input (optional)
  • Source control (not covered here): this guide does not cover setting up Git/Perforce, branching strategy, or review policy. Cursor supports standard Git workflows (GitHub/GitLab/Bitbucket) and there are Perforce extensions available for VS Code/Cursor.
  • Shell + VCS automation: Cursor can run shell commands and support VCS workflows. In Perforce-based setups, teams often automate tasks like checkout (p4 edit) and reconcile as part of the edit/apply loop.
  • External tools: some teams connect systems like Jira and Confluence via optional integrations (e.g., middleware or MCP servers) so the agent can pull context or post updates from within the editor.
  • Multimodal input: paste screenshots (compile errors, UI mockups, traces) into chat; Cursor can interpret images and use them as debugging/design input.
  • Security note: treat prompts, logs, screenshots, and pasted stack traces as data—follow your org’s privacy and IP policies.
I. Model selection, cost controls, voice/dictation, and team sharing
  • Model selection: choose models based on the task (speed vs depth vs context size). Large-context models help for wide refactors across many files.
  • Cost controls: if you’re optimizing for throughput, prefer the best-performing model for the hard parts; if cost is a constraint, define a team policy for when to “upgrade” models.
  • Voice/dictation: OS-level voice typing (or any editor-integrated dictation feature you enable) can be useful for quick prompts while debugging or reviewing changes.
  • Collaboration: share rules and architecture docs with the team and version them in source control (e.g., Perforce) so behavior stays consistent across developers.
J. Performance + indexing hygiene (recommended)
Large UE projects generate a lot of build artifacts and file churn. A small amount of hygiene keeps search fast, reduces file-watcher load, and makes code intelligence more stable.
  • Exclude build output from search and file watching: Binaries/, Intermediate/, Saved/, DerivedDataCache/, .vs/,and version control folders like .git/ or .p4/ (and the same folders under Plugins/ if you use plugins).
  • Prefer fast local storage for symbols and caches when possible (slow disks/network shares make debugging and indexing painful).
  • If you use clangd: keep compile_commands.json in the project root (or configure clangd to find it) and regenerate it after build-setting changes.
K. Workspace regeneration strategy (.code-workspace)
Unreal regenerates the .code-workspace file when you refresh project files, so manual edits can be overwritten.
  • Keep workspace customization minimal; prefer Cursor user settings and version-controlled docs/rules where possible.
  • If you must modify the generated workspace (e.g., launch configs), document the small set of edits and re-apply them after regeneration (some teams automate this as a post-generation step).
IX. Troubleshooting and FAQ
This section addresses common issues and frequently asked questions encountered during the integration and use of Cursor with Unreal Engine 5, ensuring a smoother development experience.
A. Common setup errors
Problem Potential Cause Solution
Project fails to compile/launch after setting up build tools. Missing or incorrect Visual Studio components. Re-open the Visual Studio Installer and verify that the “Desktop development with C++” workload is installed. Check the Unreal Engine release notes for the exact versions of the MSVC toolchain, Windows SDK, and .NET runtime required for your UE version.
Generate Project Files option is missing or doesn’t work. Unreal Engine Editor’s Source Code Editor is not set to Visual Studio Code. In the Unreal Engine Editor, navigate to Editor Preferences > General > Source Code and set the Source Code Editor to Visual Studio Code. Restart the editor and attempt to refresh the project files via Tools > Refresh Visual Studio Code Project.
Debugging fails in Cursor with a cppvsdbg/license error. The Microsoft VS Code C++ debug engine (cppvsdbg) is restricted to Visual Studio Code and does not run in Cursor. Use Visual Studio to debug (launch/attach to the running editor/game process, e.g., UnrealEditor*.exe). If you want a VS Code–style UI, the LLDB workaround is possible but experimental.
B. clangd and IntelliSense issues
IntelliSense features (hover, go to definition) are not working. clangd is not installed, is not running, or hasn’t finished indexing. Ensure C/C++ (Microsoft) and clangd (LLVM) are installed. Run Ctrl+Shift+P and search for clangd: Download (Language Server). Verify that compile_commands.json was generated successfully and that Cursor was restarted afterward.
clangd is slow or shows incomplete information. compile_commands.json is missing, outdated, or points at the wrong build settings. Ensure compile_commands.json is in the project root (or configure clangd to find it). Regenerate it via UnrealBuildTool.exe -Mode=GenerateClangDatabase and restart Cursor. Check the clangd Output window for indexing progress.
C. Agent/AI behavior and context
AI output is irrelevant or seems to “hallucinate”. The AI’s context window is too large or contains conflicting information. Use the Cursor command /summarize to shrink the current context, or start a new chat for a different phase (e.g., design, implementation). Selectively add files to the context that are strictly relevant to the current task. Consider using a model with a larger context size for projects with extensive source files.
AI is not following C++ or Unreal Engine conventions. Necessary custom Rules & Memories have not been defined or applied. Create comprehensive Rules files outlining C++ best practices, Unreal Engine naming conventions, and design patterns. Ensure these rules are set to be reusable and scoped to the project or user settings so that Cursor references them during code generation.
D. Hybrid workflow challenges
Difficulty switching between Cursor and Visual Studio for debugging. Unclear separation of roles for each tool in the workflow. Adhere to the dual-tool approach: Use Cursor for all AI-assisted tasks (complex changes with Agent Mode, planning with Plan Mode, code generation, and error analysis). Use Visual Studio as the primary/recommended debugger in this workflow. Close the file in one editor before opening it in the other if you encounter file lock errors.
Cursor does not recognize a change made in Visual Studio. File changes are not automatically refreshing in Cursor. Manually refresh the file in Cursor or, as a last resort, restart Cursor to ensure it loads the latest project state and the clangd server re-indexes the changes. Ensure that both editors are correctly pointing to the same project files.
E. Compiling and build task issues
Build tasks (e.g., ProjectNameEditor Win64 Development build) do not appear in Terminal > Run Build Task. The .code-workspace was not generated/updated correctly. Regenerate the project files via Tools > Refresh Visual Studio Code Project (in the Unreal Editor) or by right-clicking the .uproject and choosing Generate Project Files. For engine source builds, you can also run GenerateProjectFiles.bat -vscode from the Unreal Engine roots (script location: <UE_ROOT>/GenerateProjectFiles.bat). Restart Cursor after regeneration and make sure you open the generated .code-workspace.
X. Conclusion
Cursor can be an excellent Unreal Engine C++ “power editor” when you use it for what it’s best at: fast multi-file changes, refactors, and AI-assisted planning, while keeping a full debugger (typically Visual Studio on Windows) in the loop.
The most reliable workflow today is a hybrid loop:
  • Cursor: plan → implement → review (Agent/Plan/Ask modes, project Rules/Memories, and codebase-aware edits)
  • Visual Studio (recommended on Windows): step-through debugging, watch windows, call stacks, symbols, and crash triage
Recommended pipeline (a simple daily loop)
  • Design first in Cursor: write/iterate a short docs/ design or plan note, then implement against it.
  • Keep changes scoped: small diffs, frequent builds, and review the full change list before moving on.
  • Keep navigation healthy: enable clangd + compile_commands.json if you want accurate IntelliSense on macro-heavy UE code (optional, but a big quality-of-life upgrade).
  • Debug with the right tool: reproduce + capture logs in the Editor, then switch to Visual Studio to launch/attach with the right configuration and symbols.
  • Use Live Coding intentionally: great for safe implementation tweaks; do a full rebuild for UHT/reflection or ABI/layout changes.
Next steps (make it team-ready)
  • Version your workflow: commit shared Cursor rules, team docs, and a “how we build/debug” cheat sheet.
  • Document regeneration: write down when/how you regenerate .code-workspace and (if used) compile_commands.json.
  • Codify quality gates: formatter settings, build configurations, and a short checklist for symbols/crash dumps.
Technical Scope
Out of Scope
  • Install Cursor
AI feature overview
[image][image]
[image]
“type”: “cppvsdbg”,
“type”: “lldb”,
    [image]
    [image]
[image]
    [image]
[image]
    [image]
    [image]
Note:
    [image]
[image]
[image]
[image]
[image]
[image]
[image]
Debugging note
X. Conclusion
