This is a running release notes topic. Subscribe to it if you want notifications when we release updates to the Unreal Engine Connector.
100.2 Hotfix Release Notes
- Features
- Add Unreal Engine 4.26 editor support
- Note: The export folder dialogs in 4.26 do not refresh Omniverse server folders properly. Browse/create folders from the Content Browser first.
- Bug Fixes
- Collision properly exported from stand-alone static mesh asset exports
- Fix crash when exporting DDS textures when a material uses virtual textures (note, proper VT export is not supported)
- Fix crash when loading Level with USD actors
- Fix live-edit of many Cinematic Camera properties
- Fix binding materials to geometry subsets, honored only if the familyName of subset is UsdShadeTokens->materialBind
- Remove the “Omniverse USD Sequence+ (usd)” Image Output Format from the Render Movie Settings because it is no longer supported
- Fix crash when importing USD skeletal meshes. Garbage collection cleans up StaticMeshLOD so some classes needed to be moved to a different module.
- Changes
- Avoid exporting TangentX array for skeletal meshes if unnecessary
100.3 Hotfix Release Notes
- Features
- Add support for MetersPerUnit on import and export for meshes, shapes, cameras, lights, and stages
- Bug Fixes
- Fix crash when editing material caused by Geometry Subset material binding
- Remove duplicate vertices when exporting UE4 Landscape to USD mesh
- Fix SkelRoot live edit perf issue
- Get full data and handle transform exporting from Level Sequence sections even if there’s no key in a shot
- Avoid crashing when MDL function call creation fails and reports an error
- SkyAtmosphere material expressions get a constant 0 value when exported as MDL
- Changes
- Always create UE4 actor when loading a USD prim (rather than only if it is a model or lacks a parent component). This changes the layout actors, meshes, components, etc in UE4 to be more like the USD stage. Fewer components, more actors
- Merge multiple camera sequence shots into a new USD camera while still preserving the original shot cameras
- Support exporting BC6H/BC7 2D textures
- Replace UE4 material function DeriveTangentBasis with TangentBasis when exporting MDL materials due to the usage of incompatible DDX and DDY material nodes
100.4 Hotfix Release Notes
- Features
- Add the optional OmniverseGroom plugin to 4.25 and 4.26. This plugin will export Groom assets as USD Basis Curves.
- Bug Fixes
- Fix crash when importing Black_Oak from mounted tree library. Do not attempt to reuse an actor of a different class.
- Fix a crash when closing the editor when connection to an Omniverse server had previously failed
- Fix a crash when opening an MDL that is referenced from a path larger than 260 characters (or so) due to Unreal Editor path length issues
- Fix a crash when exporting a Level Sequence actor with a shot in negative time
- Fix USD Skeletal Mesh animation importing and playing when triggered from within a Level Sequence
- Fix an issue where imported USD timesamples that changed visibility on a parent prim did not affect children meshes.
- Fix an issue where the Landscape default weight map was missing when DDS textures are exported.
- Changes
- Make basic USD shapes (sphere, cube, etc) use the same default material that meshes use when no material is bound
- Don’t allow deletes of ancestral prims from referenced USDs within a stage
- Support live replacement of mesh prim from point instancer with a UE4 static mesh
- Workaround issues related to materials that employ Parallax Occlusion Mapping (POM) since this doesn’t translate well to MDL
- Add support for the Black-body radiation material expression node with MDL
- Add primitive data (bounding box, etc) from Unreal Engine to MDLs through a custom expression
- Trigger Skeletal Mesh animation from within a Level Sequence rather then on the actor to ensure that animations with other actors are synchronized.
100.5 Hotfix Release Notes
Highlights
- C++ projects can now build properly if the are using the Epic Games Launcher source
- Fixes for Spotlight and Post Process Volume translation reported by the community
- Enhanced MDL translation support for more Unreal material expressions
Details
C++ projects can now build properly if the are using the Epic Games Launcher editor source
While we’re still working on releasing the plugin source, we have included the *.Build.cs files so that C++ projects are supported with the NVIDIA Omniverse USD and MDL plugins. This won’t yet work with the GitHub Unreal Engine source, but it will work with a project based on the Epic Games Launcher editor source.
- We improved the Spotlight to Sphere light translation and added mapping of the PPV’s “Exposure Compensation” to “cm^2 Factor” in the Tone Mapping RTX Settings in Create.
Complete changelog:
- Features
- Add the module *.Build.cs files to allow C++ source project builds using the Epic Games Launcher source
- Bug Fixes
- Materials
- Unify MDL export warnings so they all appear in the same message log whether exporting to local disk or Nucleus server
- Add a new way to identify if the refraction contained in material expressions can be used for MDL IOR. For example, if texture sampling is used to drive refraction attributes in a material, it will be ignored and replaced with the default IOR constant.
- Fix 4.26 fog volume MDL exports, the subsurface color attribute was incorrect
- Fix an issue with a missing override material when exporting instanced meshes
- Fix an issue where initial material creation and application on a prim in Create did not live-sync to Unreal Engine
- Fix MDL/texture importing when sampled with address mode (wrap vs. clamp)
- Fix translation of the Panner material expression node to MDL
- USD
- Fix a crash when exporting shots in a Level Sequence that end outside the time range
- Fix a crash by not allowing an imported Level Sequence actor to be renamed
- Fix a crash when editing the transform of an instanceable prim by locking the movement of an actor if it’s a descendent of an instanceable prim
- Fix USD warnings when reading incorrect value types
- Fix an issue where USD mesh shapes axis changes did not live-sync
- Lights
- Fix export of SpotLights to USD SphereLights (credit Alex Jenyon for notifying us of this issue)
- Fix the import of SphereLights as SpotLights to take the stage’s metersPerUnit setting into account
- Install
- Fix the uninstall to only delete files that were installed, not the entire folder where the plugins were installed
- Changes
- Materials
- Add annotation to MDL parameters so that DisplayName, Description, SortPriority, Group, and Range are all exported and visible in Create
- Add support for the clamped texture sample setting in the texture asset for MDL export
- Add support for the exporting the PerInstanceRandom material expression node to MDL
- Other
- Add a utility Blueprint function to list the contents of a Omniverse server folder (ListOmniverseFiles)
- Add support for exporting Level Sequence shots with the correct priority into a single Omniverse shot camera
- Support mapping a Post Process Volume’s “Exposure Compensation” to “cm^2 Factor” in the Tone Mapping RTX Settings in Create
- Add support for importing USD capsule shapes
- The defaultPrim on exported stages now have a blank Kind, rather than be set to “group”. This fixes some prim/defaultPrim selection issues in Create.
100.6 Hotfix Release Notes
Highlights
Significant Skeletal Mesh and Animation import and export improvements
Fix bugs to allow for easy USD timesample/animation exports of recorded sequences - makes it easy to capture dynamic Blueprint behavior as timesampled data (tutorial coming soon!)
Further fixes to material creation live-syncing between Create and Unreal Engine
Improvements to mesh caching of USD stages, both during the editor process lifetime (mesh cache) and between editor executions (DDC) - this makes reloading a USD stage significantly faster
Added an option to export prims in a stage as Payloads rather than References.
Complete Changelog:
- Bug Fixes
- Fix a USD Skeletal Mesh animation import issue where the start time was being ignored (OM-27456, OM-27454)
- Fix a Skeletal Mesh export issue when morph targets are employed by using LOD RenderData instead of the LOD Model
- Fix crash when loading skel root with multiple skeleton bindings as the default prim
- Fix exporting Level Sequence visibility/boolean sections if there’s only one keyframe (OM-27613)
- Remove live-syncing of Level Sequence changes because of performance issues
- Fix exporting spawned Blueprint meshes in Level Sequences (OM-27613)
- Fix exporting Level Sequence with a 3D constraint section that has an infinite range
- Fix exporting a mesh component as a Xform prim when there’s no actual mesh asset assigned (OM-27790)
- Fix exporting material with PrecomputedAOMask in DDS mode
- Fix a material export crash when HLSL text in custom material expressions contain comments near the end of the text block.
- Fix a material export/import issue where refraction was removed with using the Fresnel node (now default IOR for invalid refraction is set to 1.491 instead of 1.0)
- Fix another issue where initial material creation and application on a prim in Create did not live-sync to Unreal Engine (OM-26415)
- Fix attenuation radius scaling (MetersPerUnit) for spot and point lights
- Fix scaling (MetersPerUnit) for USD cameras, which use fixed units, so no scaling required
- Changes
- USD Mesh Importing
- Meshes are now cached by both the mesh cache and the DDC to speed the subsequent loading of unmodified USD meshes
- USD Payloads and References
- Add an option to export props as payloads rather than references (OM-28488)
- Materials
- Update MDL Core Definitions to version 2.0.0 and set the exported SDK version to 1.6
- Add support for exporting sincos() HLSL function in custom material expressions (OM-27401)
- Workaround HLSL usage of the SampleGrad() function in custom material expressions (OM-27401)
- Support exporting HLSL vector components as left assignment in a custom expression (OM-27401)
- Add support for exporting Texture2DSample UE4 material function in custom material expressions
- Add support for HLSL distance in a custom material expression
- Prevent MDL export errors when encountering View to World and World to View transforms and emit a warning
- Update the MDL Core materials to support hair color
- Add MDL display_name annotations to strip the extraneous “inputs:” from the name in Create
- Add support for exporting 2D Render Targets to PNG and DDS (OM-28954)
- Animation
- Add support for exporting a Blueprint animation with the “Copy Pose from Mesh” graph
- Note: Only attached parent is supported
- Automatically export a Level Sequence if there’s only one in the level, previously “Auto Play” had to be checked
- File Support
- Use UTF-8 (rather than ANSI) when interacting with the Omniverse Client Library to support all possible characters from the Content Browser
- Installer
- Make the uninstaller silent (OM-28140)
101.1 Update Release Notes
Highlights
Source code included to allow source builders of Unreal Engine to use the plugin.
USD Skeletal Mesh import improvements to support more USD hierarchies
Viking courtesy of Turbosquid, artist Michael Weisheim
Fixed Skeletal Mesh material editing and assignment in live-sync
Added support for exporting IOR values in MDL with Unreal Ray Tracing Translucency
Fixed many custom HLSL material expression issues for MDL export
(Epic Games Automotive Pack used for testing)
Add support for exporting USD Point Instancers from Unreal’s Grass system on Landscape Terrain Actors.
Add import and live-sync support for USD DomeLights as UE4 sky sphere actors.
Features
- Include source code in the Launcher download to support GitHub Unreal Engine source builds
Bug Fixes
- Materials
- Fix an issue where an MDL parameter name might be redefined, causing invalid materials (OM-29128)
- Fix an issue where deleting a material made in Create while in a live sync session didn’t update in Unreal (OM-28940)
- Fix missing parameter annotations from parameters in material functions
- Fix live editing of materials in a skeletal mesh (OM-29530)
- USD importer will convert mesh from Y-up to Z-up, so cache should be changed if the up-axis is different (OM-29351)
Changes
- Materials
- Add support for Unreal’s combined material and post process volume ray tracing translucency in transparent MDLs (OM-27969)
- Prevent duplicate custom expressions in exported MDLs by using a cache
- Add support for radians and degrees in custom expressions in exported MDLs
- Add support for mul in custom expressions in exported MDLs (OM-29276)
- Support exporting additional outputs for custom expressions (OM-29276)
- Support additional float4 constructors in custom expressions (OM-29276)
- Unifying the material loading for USD skeletal and static meshes (OM-29351)
- Add support for DistanceToNearestSurface material node when exporting MDLs by using a constant value to generate a valid material (OM-30208)
- Skeletal Meshes
- Reorganize the hierarchy of UsdSkelRoot to fix a missing UsdSkeleton transform, also helpful for the multiple skeletons. (OM-29351)
- Old: UsdSkelRoot → SkeletalMeshActor
- New: UsdSkelRoot → Actor and UsdSkeleton + UsdMesh → SkeletalMeshActor
- Landscapes
- Export Landscape actors with a GeomSubset and MDL Preset for each Landscape component to address issues with the visibility mask (OM-29643)
- Only export the Landscape visibility mask once, as opposed to once for every layer
- Add support for exporting USD Point Instancers from Unreal’s Grass system on Landscape Terrain Actors in 4.26 (OM-29803)
- Lights
- Improve skylight when importing a USD stage (OM-27528)
Add support for importing USD DomeLights as UE4 sky sphere mesh plus a material that supports some DomeLight properties (textures, exposure, intensity, color)
101.2 Hotfix Release Notes
Features
Add an option to export SubLevels as USD SubLayers (OM-30422)![|505x554]
Add an option to export Decal Actors and Components as USD meshes (OM-10250)
Add an option to export stages as Y-up (default is Z-up) (OM-3518)
Bug Fixes
- Fix missing USD Layer names in the Omniverse Layers tab (OM-13577)
- Add a missing vector and matrix multiplication support for MDL distilling (OM-30492)
- Fix MDL importer to handle some custom functions (OM-31735)
- Fix installer to support a relocated Unreal Engine install from Epic Games Launcher (OM-30765)
- Fix a vertex color bug on mesh export and weld USD static mesh verts
- Fix Skeletal Mesh live transform update issues (OM-30696)
- Fix USD SkelMesh importer to handle Geometry Subsets (OM-31735)
- Fix a crash due to shared SkelMesh DDC entries between engine versions (OM-31982)
- Fix an issue where imported animations replay too slowly due to usage of framesPerSecond rather than
timecodesPerSecond
- Prevent OmniAsset in mounts from saving and live editing (OM-31753)
- Fix folders and assets missing read-only mount flags (OM-31821)
- Fix a reconnect loop on disconnected Nucleus servers (OM-26381)
Changes
- Add “localhost” as the default in the Add Omniverse Server dialog (OM-2734)
- Allow “omniverse://servername” in the Add Omniverse Server dialog (OM-2734)
- Add export commandlet options for payloads and layered sublevels
- Export World Outliner folders as USD Scope prims (OM-30645)
- Add an “Export Current Level to Omniverse” option from the menu button (OM-30627)
- Update the Omniverse Client Library to 1.11.17
- Add an option in the project plugin settings to save stage changes during Play in Editor sessions (OM-28372)
Notes
This is the last update to the Unreal Engine 4.24 Connector. Future releases will only contain Connectors for 4.25, 4.26, etc.
102.1 Update Release Notes
Features
Unreal 4.27 Preview 2 editor support added
Add an export option to create a “material override” sublayer and material references (OM-31466)
- Materials are exported to referenced material USD files rather than embedded in the prop USD files
- This ensures that changes to a shared material between to props applies to both props
- This allows a user to save material changes in the MaterialOvers layer and future exports won’t overwrite them
Add Omniverse Checkpoints on Save, Export, and Live Toggle (OM-31918)
The USD DLLs are prefixed to allow the NVIDIA USD plugins to be loaded at the same time as the Epic USD plugins (OM-31328)
- Note that some functionality in the plugins might be impacted due to both running at the same time
Add support for http/S3 references to allow for Omniverse skies, materials, and other assets from Create (OM-31892)
Add support for importing materials generated by the MDL Material Graph in Create (OM-31608)
Bug Fixes
- Add version control to USD DDC to prevent crashes when importing the same USD SkelMeshes with different editor versions (OM-31982)
- Add MetersPerUnit stage value to DDC cache to prevent incorrect scale on importing
- Fix invalid MDLs in Create when exporting using the Core library dependencies
- Fix USD Domelight import material by normalizing the reflected vector to prevent scaling
- Fix bounds for USD SkelMesh animation imports (EuclidVR sample)
- Fix live editing material from the USD Skel which mixes with Mesh and GeomSubset
- Fix importing tangent_space_normal_texture function from base module to fix normals on OmniPBR (OM-33899)
- Fix check() when importing Automotive Materials Pack M_Opaque_Master (OM-33666)
- Fix a HUGE memory leak when exporting USD stages to Nucleus servers (OM-20218)
Changes
- Unreal 4.24 is no longer supported
- Live Edit will automatically be disabled when opening/importing a USD stage (OM-31918)
- Add support for HLSL clamp conversion to MDL clamp
- Add support for importing/exporting “unpack integer as float function” (OM-30252)
- Add support for converting hlsl rgb per-component operation for the variable and function to mdl (OM-30252)
- Update MDL SDK to 2021.0 (344800.2052): 01 Jun 2021
- Support loading specific material from the core material lib in preparation for material node graphs (OM-31608)
- Omniverse Client Library update to 1.13
102.2 4.27 Hotfix Release Notes
Note, this hotfix is only for the 4.27 Preview 3 Unreal Editor. Epic Games recently updated from Preview 2 to Preview 3 and our 102.1 release isn’t compatible, so we updated it.
Features
- Updated build to support Unreal 4.27 Preview 3 (Preview 2 is no longer supported)
Bug Fixes
- Fix the result of MDL lerp expression when the input is constant (OM-34457)
- Adjust spot and point light exporting (OM-34234)
- Fix the incorrect relative texture path when exporting objects (static mesh/skeletal mesh) to local disk
- Fix crash when loading transform_vector_from_tangent_to_world() and transform_vector_from_world_to_tangent() from Ue4Function mdl
- Clamping the texture coordinate index if exceeding the number of texture coordinates: Omniverse MDL used the 3rd and 4th uv sets as vertex color, so out of bound coordinates will cause the issue (OM-34912)
- Add notification when the filename on the Omniverse is too long (OM-31735)
Changes
- Setting max roughness to 1.0 which is 0.3 by default in Create to match the roughness attribute of UE material (OM-34749)
- Update Core material libraries to 1dcbfb85 for OmniSurface
102.3 Hotfix Release Notes
Bug Fixes
Separate MDL functions which require MDL 1.7 to a new core template which will be imported as needed. The main Ue4Function template maintains MDL 1.6 to compatible with older Kit SDK versions (OM-35152)
Fix a crash by adding error checking for the custom mdl function translator
Avoid repeatedly copying template MDL files when exporting materials
Changes
- Add option to decide if exporting preview mesh as well when exporting the animation sequence (disabled by default)
- Add support for HSLS exp/exp2 to MDL math functions
102.5 (4.27 only) Hotfix Release Notes
Features
- Updated build to support 4.27.0 Release
- Add support for importing the OmniSurface MDL materials (OM-34790)
- Add support for exporting a material with virtual textures (OM-35721)
Changes
- Add an export option to disable exporting Landscape Grass to reduce memory usage
- Add support for exporting materials that use a Desaturation material expression node (OM-35720)
102.4 (4.27 only) Hotfix Release Notes
Features
- Unreal 4.27 Preview 4 editor support added (Preview 3 support dropped)
Bug Fixes
- Fix Lerp material expression node losing inputs with a scalar parameter caused by OM-34457 (OM-35242)
102.6 Hotfix Release Notes
Features
- Add IES texture light profile import for USD lights, export not yet supported (OM-34371)
Bug Fixes
- Initialize static mesh render data outside of OmniverseUSD module to avoid crash (OM-36271)
- Support exporting cameras created from Default Pawn and spawned actors when recorded in a sequence (OM-34197)
- Also add basic support for the spring arm component as a fixed joint to suspend a camera (without any collision avoidance)
- Fix MDL custom annotation by unmangling paths
- Fix strange triangulation due to world normal usage in Unreal materials when exporting as MDL (OM-34110)
- Reset EV100 to 0 when the luminance is 0 to prevent the post process from overexposure
Changes
Add support for referencing textures, materials, and USD stages with a checkpoint URL (file.png?checkpoint=2) (OM-34630)
Allow a material to load for a GeomSubset that doesn’t define the “familyName” attribute set to “materialBind” - still emit a warning
Add support for the USD Preview Surface “Transform2d” function
If USD camera focus distance is zero use the setting from post-process on import (OM-35714)
Export EXR files as 16 bit textures since they’re now supported by Create
103.1 Update Release Notes
Features
Bug Fixes
- Fix crash when exporting a USD mesh with null material in Y-up axis mode (OM-37433)
- Checkpoint actors that are right clicked from the viewport or world outliner panel (OM-37414)
- Don’t allow saving or exporting to a read-only Nucleus folder and notify the user (OM-37424)
- Fix exporting mesh with the socket attachments (OM-38063)
- Add OmniSurface support for material graph MDLs (OM-37830)
- Fix Undo/Redo changes so they replicate over live sync (OM-16706)
- Fix deleting a copy of a referenced mesh under a referenced prim (OM-39178)
- Add error notification when attempting to delete an ancestral prim
- Fix USD mesh actor duplication (Alt+Drag, Copy/Paste, Ctrl+W) failures (OM-38541)
- Disable Edit/Cut operations and notify user (OM-39468)
- Fix reparenting USD prims hierarchy (dragging actors around in the World Outliner) (OM-39422)
- Fix USD Scope loading and exporting - now acts as an unmovable actor (OM-39383)
- Fix remove/add Nucleus server so it works (also fixes a server disconnect) (OM-38546)
- Fix “Copy Omniverse URL” to have a correct extension “.usd” rather than “_usd” (OM-32549)
- Added case sensitivity to the USD prim to Unreal actor mapping to load both “Axe” and “axe” (OM-39443)
- Support loading MDL module from http (OM-39402)
Changes
- Support exporting DynamicParameter material expression
- Add a new parameter that was added in base::file_bump_texture in MDL 1.7
- Ask the user if they want to fetch changes from the server when entering live mode (OM-32236)
- Override attributes instead of duplicating full props when exporting a painted mesh (OM-38566)
- Fix uninstall/delete from the Omniverse Launcher to only remove the currently installed Connector (OM-26048)
- Note: this will only work with 103.1 builds and later, previous builds will have a broken uninstall/delete
- Clean up many of the MDL warnings that were generated from exported materials (OM-37089)
- Enable “Show Empty Folder” automatically so Nucleus server browsing works properly (OM-39423)
103.2 Hotfix Release Notes
Features
Bug Fixes
- Make empty actors first class USD Xform prims and handle them properly (OM-38960)
- Fix OmniSurfaceBlend MDL import by replacing long distilled material network with bespoke functions
- Fix multiple camera actors being created when dragging and placing a Camera Actor (OM-40783)
- Fix mouse control causing a bad rotation when piloting a camera (OM-38749)
- Don’t live edit unsupported component types (OM-40746)
Changes
- Modular exports will group materials for splines and landscapes (OM-39408)
- Add support for importing Reallusion’s character MDLs in 3.44 (OM-39977)
103.3 Hotfix Release Notes
Deprecated
- Updates for 4.25 will stop after this release and we’ll continue fully supporting 4.26 and 4.27
Features
- Support for viewing live synced USD variant changes from other clients (OM-26617)
Bug Fixes
- Fix missing LightColor timesamples from lights in Level Sequences (OM-40909)
- Fix exported exposure when Post Process Volume’s “Apply Physical Camera Exposure” is disabled (OM-40877)
- Fix MetaHuman Fuzzy Hoodie material export due to a regression (OM-41058)
- Fix MetaHuman Teeth occlusion material export (OM-41055)
- Fix a crash and behavior with USD prim attaching (OM-41418)
- Fix USD Preview Surface normal map to undo the default tangent space calculations made by texture nodes (OM-41410)
- Fix live sync when a Translate:pivot is used in USD xform op stack (OM-41542)
- Fix loading MDLs with unpack_integer_as_float: It was moved to new 1.7 template (OM-41759)
- Fix changing the SpotLight Cone Angle in Kit not changing the Outer Cone Angle in Unreal (OM-8166)
Changes
- Updated to Omniverse Client Library 1.17 (OM-40371)
- Live lock for “fast updates” is removed since there were issues with it
- Export auto exposure settings to USD custom layer (OM-40877)
- Disable two sided material when rendering translucent USD Preview Surface materials
- Add support for OmniHair MDL importing (OM-40241)
- Auto-refresh Content and Export Browser windows with Nucleus files and folders (OM-41548 OM-2399)
- Remove preview height fog when opening USD stages
104.1 Update Release Notes
Features
The Omniverse Connector is released for Unreal Editor versions 4.26, 4.27, and 5.0 Preview 2
Layer visibility and locked state is synced between Unreal and Create (OM-41867)
Add support for loading MDL templates (OmniPBR and friends) as an instance based on Connector templates
- Rather than re-importing OmniPBR every time, the OmniPBR Unreal material is used as the parent material
Add support for loading USDZ files from Nucleus (OM-43305)
Bug Fixes
- Refactored the Commandlet exporting to fix an issue where sublevels wouldn’t properly export (OM-15147)
- Note, there is still an issue when exporting a persistent level, sublevels won’t export
- Fix specifying the MDL template folder so that the template MDLs are copied properly (OM-42933)
- Export 16bit PNGs for normal maps to prevent pixelated highly reflective/metallic surfaces (OM-30912)
- Fix empty actors when they are attached to a Blueprint actor (OVSD-349)
- Skip exporting hidden instanced components
- Fix material location for exporting instanced meshes to avoid duplicates
- Fix exporting custom material expressions with macros
- Fix OmniGlass importing
- Cutout opacity will be treated as opacity for translucent materials
- Fix glass opacity when it isn’t enabled and disable RT shadow if the imported MDL is translucent
- Fix editing a USD stage causing a reload issue (OM-42016)
- Decode URLs before loading assets (fixed a texture path with space %20 encoding) (OM-43689)
- Fix a regression with scene depth in a spiderweb MDL export (OM-44215)
Changes
- Add an option to export Nanite meshes with their complete geometry from UE 5.0
- Add a message log for loading USD and MDL to report issues with custom MDL distillation (OM-41762)
- Add support for translating Square/Pow2/Pow3/Pow4/Pow5/Pow6 Unreal material functions
- Add support for exporting instanced meshes as a referenced USD rather than including it inline in the stage USD
- Update the Omniverse client library to v1.17.2. It uses Python 3.7 and fixes file subscription callbacks
- Update the texture saving pipeline and only rebuild PNGs to improve perf if texture parameters require it
- Remove local to remote USD layer copies in the stage control class (OM-44628)
- Use individual file subscription for updates on Omniverse Assets rather than subscribing to the entire folder’s changes
- Avoid redundant texture files copies when uploading to Nucleus servers
- Add an accurate progress bar when exporting (OM-43374)
- Add cancel button when exporting to Nucleus (OM-43680)
104.2 Hotfix Release Notes
Features
- The Omniverse Connector is released for Unreal Editor versions 4.26, 4.27, and 5.0.0 Release
Bug Fixes
- Fix progress bar that might show 100% when exporting a map for the first time (OM-46329)
- Fix VertexInterpolator in the MDL translator (OM-47468)
Changes
- Support the PreSkinnedNormal material expression in the MDL translator (OM-47468)
- Add support for exporting a master pose component (OM-46978)
- Add support for exporting with CopyPoseFromMesh in an AnimGraph (OM-46978)
- Add an export option to set the Skeleton’s root transform to an identity transform (to assist downstream tools that prefer this)
104.3 Hotfix Release Notes
Bug Fixes
- Fix loading the USD animation sequence length
- Fix MDL exports when virtual textures are used (OM-48724)
- Fix Omniverse texture loading in projects with virtual textures enabled (OM-46133)
- Fix crashes due to invalid USD prims when live editing (OM-48918)
Changes
- Update the Omniverse client library to v1.17.4 to update OpenSSL
- Update the Core MDL library to 910238b3
- Setup imported meshes with convex collision rather than using “complex as simple”
- Load DDS block compressed textures as 2D when importing USD files to open/edit (OM-49132)
- NOTE: this means that the Marbles RTX content from the
/NVIDIA/Samples/Marbles Nucleus mount is loadable within Unreal - most of it uses DDS textures.
105.1 Update Release Notes
Features
Bug Fixes
- Fix live editing exposure and loading exposure time samples for USD lights (OM-49611)
- Mark imported textures as sRGB if the color space is auto in a material (OM-49285)
- Add support BC4 DDS exporting and fix building 16bit grey texture (OM-48724)
- Fix exporting UDIM/VT with different dimension (OM-48684)
- Add support for local exporting of BC6, BC6H, and BC7 DDS (OM-48684)
- Handle UE5 issue where C: is a relative path while C:/ is not for material loading (OM-53158)
- Fix loading mdl which contains the full parameters list in SourceAssetSubIdentifier (OM-50358)
- Fix a crash after dragging a USD into a level then running PIE, then quitting (OM-50761)
- Fix a crash when exporting Skeletal Mesh with no Skeleton (OM-50461)
- Fix an issue where the content browser is blocked when starting the editor due to a refresh
- Don’t create a preview Directional Light if the USD stage contains a Dome Light (OM-52432)
- Fix crash when exporting a Blueprint with a root that’s an instanced mesh component (OM-51882)
- Fix crash when exporting only USD Preview Surface due to uninitialized OmniverseExportMaterialResult (OM-53656)
Changes
- Add support for the DomeLight “Visible in Primary Ray” attribute in the Unreal sky mesh plus material (OM-50112)
- Add support for exporting Animation Montages (OM-50677)
- Dramatically improve the performance of loading stages with thousands of prims (OM-50300)
- Add support for importing Mineways materials (OM-51513)
200.0 Update Release Notes
Features
Bug Fixes
- Fix a crash when renaming a folder in the export folder selection dialog (OM-33512)
- Install the Connector under /Engine/Plugins/Marketplace by default to enable 5.0 to build C++ projects (OM-
53266)
- Add a scrollbar to the export dialog (OM-46285)
- Fix mdl error on materials from gltf converted asset (OM-57847)
Changes
- Expose USD and Facial Animation loading to Editor Utility Blueprints (OM-58488)
Deprecated
- Updates for 4.26 will stop after this update and we’ll continue fully supporting 4.27 and 5.0
