Maya Omniverse Connector Updates
We released an update to the Maya Omniverse Connector.
Listed here is the highlights for the release.
  • Added Maya 2022 support. Must unload other USD plug-ins first.
  • Added Arnold 6.2 support for Maya 2020 / 2022
  • Added auto skel root generation for files that don’t meet usdSkel requirements
  • Added auto conversion of meshes with joint parents to be rigidly skin bound on export
  • Added scripted export options for Skin bind position.
  • Added USD Python Bindings, using Python 2.7, + USD 3 for Maya 2022. ( Other usd plug ins must be completely uninstalled to not have a conflict)
  • Added initial support for materials created by Create Material Editor / USD Shade
  • Added Checkpoint support ( replaced Snapshots), for supported servers
  • Added OmniSurface materials to Core MDL materials
  • Improved Material Export support
  • Improved instance Export
  • Improved Live Sync
  • Improved resolving default prims on import USD
  • Fixed animation transforms if animation is exported at a different up axis than the source.
  • Fixed an Omniverse Connection issue
  • Fixed Default Prim when export a Prop Animation Clip
  • Fixed a variety of Windows and Linux specific bugs
  • Changed Export Option - Normalize Skin moved to a only script command
  • Changed Export Option - Embedded MDL on by default, script command available to control it.
See full documentation here.
Does this mean i have to unload the native Maya_USD plugin?
This is true as it stands today, We cannot run side by side at this time.
We have it on our radar to lift this limitation in the future.
An update to the Maya Omniverse Connector has been released. Version 102.2.3 is now out. Release notes are listed below as well as in the docs.
  • Add Client Log Level script command OmniExtraCmd - clientLogLevel
  • Add Upload & download status to log file
  • Fixed bug exporting OmniSurface Preset materials
  • Fixed Crash on Marbles scene
  • Fixed OM-29272 Reexport of an existing USD broke some materials
  • Fixed OM-30555 Live object move with Variant caused duplicate
  • Fixed OM-34879 fix and set plug registration for Linux
  • Fixed OM-35172 UDIMs do not export for specific file
  • Fixed OM-35381 Variants has unexpected behavior on Export and Live
  • Fixed OM-35396 Export selected have wrong skeletal errors
  • Fixed OM-35428 Linux Connector won’t load USD Preview Surface
  • Fixed OM-30555 Live object moved caused undesired duplicate
  • Fixed OM-34558 Variant Crashed on Export
  • Fixed OM-34934 Exported incorrect inbetween blendshapes
  • Fixed OM-35381 Variant had incorrect visibility
  • Fixed OM-35462 Linux MDL templates and collections fail to load
  • Fixed OM-35546 CentOS MDLs fail to export to disc
  • Fixed OM-35548 CentOS MDLs are not immediately visible in Hypershade
  • Fixed OM-35956 Materials don’t load from Blender export
  • Fixed OM-36009 stage hierarchy wrong on load
  • Fixed OM-36520 Save USD didn’t save upaxis change
  • Fixed OM-36559 UV’s are broken for some assets
  • Fixed OM-36066 Export Selected Exported ALL material
  • Fixed OM-36070 Live object move doesn’t submit to server
  • Improved Export Selected with type Skel Mesh - Now selecting a bound mesh will automatically pick up the joints, eliminating the need to select the joints manually
  • Improved Animation Clip export by removing unused options
  • Improved support for the Create MDL Graph
  • Updated UMM and license
  • Updated Client Library and Client Wait call
  • Updated Core material Library
Maya Connect Version 102.3.0
  • No longer support Maya 2018
  • Added Animated Point Cache export option, Vertex Only. See documentation here.
  • Added Live Update options on Setting panel
  • Added Blendshape support for export type Skelmesh Animation Clip
  • Added checkpoint of auxiliary files
  • Improved Live Update performance with timeline scrub, and transforming objects
    • Updates are now on Mouse Release
  • Improved material conversion feedback
  • Improved usdSkel processing
  • Improved material handling for dds textures
  • Updated Prop vs Skelmesh export. Skinned meshes should be exported as type SkelMesh now.
  • Updated Core Materials
Additional bug fixes all noted in release notes online here
Maya Connect Version 102.4.0 was released today.
This is a small update with Client Library 1.16 as the main change plus a handful of bug fixed that you can find here.
Maya Connect Version 103.1.14
Maya Connector update is now live today. This update has a batch export feature, which is the same functionality as our 3dsmax Connector. Aside from this we’ve added a variety of smaller improvements and bug fixes. Please see below for the release notes.
  • Updated Client Library to 1.17.2
  • Renamed export option “Split USD to Multiple Files” to “Batch Export”
  • Added Payloads as an option to Batch Export
  • Added Prevent Maya connector from installing if Maya is not detected.
  • Added Add post fix names to export.
  • Added tooltips to Omniverse dialogs throughout.
  • Added command to normalize frames on export, example NormalizeFrameRangeOnExport -onflag true -basenumber 0; see :ref: maya_normalize_anim_range script reference.
  • Added Arnold 7 support for Windows
  • Fixed OM-43113 pivot issue when object had frozen transforms not at origin.
  • Fixed OM-30884 Crash with specific Skel Mesh asset
  • Fixed OM-42510 MDLs not honoring viewport texture control.
  • Fixed OM-42214 Camera filmback not exporting correctly
  • Fixed OM-41829 USD imported and Save USD command have unexpected result
  • Fixed OM-42323 Transforms are not saved on a group if group is not saved first.
Release notes are also here.
Image made with Maya and NVIDIA Omniverse Create.
Maya 103.2.1 was released today. This is a small update that only updated the Client Library to version 1.17.3.
We released Maya 103.3 Connector today. This version adds Maya 2023 support along with Client Library 1.17.5 update.
There is a known limitation with Maya 2023 and our Maya Connector where Bifrost must be turned off due to a compatibility issue. This will be resolved in a future connector release.
Update is working. Thank you
We released Maya 103.4 Connector today. There is no visible impact to users.
Release notes
Maya (Legacy) Connect Version 200.0.0
  • Maya Connector now referred to as Maya )(Legacy) Connector
  • Updated Client Library to 2.12
  • Updated - MDL Core materials
  • Added - OmniLive 2.0
  • Added - Interactive Groom Export
  • Fixed a variety of bugs which can be found in the full release notes here.
The Maya Legacy Connector 200.1 update is released.
  • Updated - Resolver 1.11.0 and Client Library 2.15.0
  • Numerous Bug fixes
Release Notes
When do you think you will be able to support Pixar Renderman, and therefore be able to export renderman shaders, light and camera in the USD?
Maya Legacy Connector 200.2 is released today
  • Users Can now paste in an Omniverse URL to open a file directly.
  • Variety of Live Workflows fixes and Improvements.
  • Fixed Community Bug, OM-54241 - [Community Bug] Added point light in Maya, got spotlight in Unreal, and a few other bug fixes too.
    openbypath_maya
See Full Release Notes here.
See Maya Connector FAQ here.
Maya Legacy Connector 200.3 is released today. This release addresses some minor bug fixes and improvements.
  • Updated resolver to 1.18.0
  • Fixed failed to export mdl in a special case
  • Fixed materials when reexporting Reallusion characters
