v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=“UYVY” --device=/dev/video1 --stream-count=300 --stream-mmap
v4l2-ctl-23368 [005] … 2595.136956: tegra_channel_open: vi-output, apach3_5 2-001c
v4l2-ctl-23368 [000] … 2595.141143: tegra_channel_set_power: apach3_5 2-001c : 0x1
v4l2-ctl-23368 [000] … 2595.141170: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
v4l2-ctl-23368 [000] … 2595.141175: csi_s_power: enable : 0x1
v4l2-ctl-23368 [000] … 2595.162868: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23369 [004] .n… 2595.163136: tegra_channel_set_stream: enable : 0x1
vi-output, apac-23369 [005] … 2595.166772: tegra_channel_set_stream: 150c0000.nvcsi–1 : 0x1
vi-output, apac-23369 [005] … 2595.166775: csi_s_stream: enable : 0x1
vi-output, apac-23369 [005] … 2595.166818: tegra_channel_set_stream: apach3_5 2-001c : 0x1
kworker/5:3-8921 [005] … 2595.188377: rtos_queue_peek_from_isr_failed: tstamp:81370479313 queue:0x0b4b4940
kworker/5:3-8921 [005] … 2595.188389: rtcpu_start: tstamp:81370483329
kworker/5:3-8921 [005] … 2595.188396: rtos_queue_send_from_isr_failed: tstamp:81370546061 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.188399: rtos_queue_send_from_isr_failed: tstamp:81370546237 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.188402: rtos_queue_send_from_isr_failed: tstamp:81370546421 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.188404: rtos_queue_send_from_isr_failed: tstamp:81370546598 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.188407: rtos_queue_send_from_isr_failed: tstamp:81370546771 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.188409: rtos_queue_send_from_isr_failed: tstamp:81370546945 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.188412: rtos_queue_send_from_isr_failed: tstamp:81370547119 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.188415: rtos_queue_send_from_isr_failed: tstamp:81370547293 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.188420: rtos_queue_send_failed: tstamp:81370548117 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.188423: rtos_queue_send_from_isr_failed: tstamp:81370556139 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.188425: rtos_queue_send_from_isr_failed: tstamp:81370556315 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.188428: rtos_queue_send_from_isr_failed: tstamp:81370556491 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.188431: rtos_queue_send_from_isr_failed: tstamp:81370556666 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.188433: rtos_queue_send_from_isr_failed: tstamp:81370556840 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.188436: rtos_queue_send_from_isr_failed: tstamp:81370557014 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.188439: rtos_queue_send_from_isr_failed: tstamp:81370557188 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.188442: rtos_queue_send_from_isr_failed: tstamp:81370557392 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.188444: rtos_queue_send_failed: tstamp:81370559404 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.356292: rtos_queue_peek_from_isr_failed: tstamp:81375479700 queue:0x0b4b4940
vi-output, apac-23369 [000] … 2595.385332: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23369 [000] … 2595.385377: tegra_channel_capture_frame: sof:-549620698988.-268121905728
kworker/5:3-8921 [005] … 2595.412358: rtos_queue_send_from_isr_failed: tstamp:81377488813 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.412364: rtos_queue_send_from_isr_failed: tstamp:81377488989 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.412367: rtos_queue_send_from_isr_failed: tstamp:81377489167 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.412369: rtos_queue_send_from_isr_failed: tstamp:81377489342 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.412372: rtos_queue_send_from_isr_failed: tstamp:81377489514 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.412375: rtos_queue_send_from_isr_failed: tstamp:81377489687 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.412378: rtos_queue_send_from_isr_failed: tstamp:81377489860 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.412381: rtos_queue_send_from_isr_failed: tstamp:81377490033 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.412384: rtos_queue_send_failed: tstamp:81377490924 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.412387: rtos_queue_send_from_isr_failed: tstamp:81377494453 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.412389: rtos_queue_send_from_isr_failed: tstamp:81377494627 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.412392: rtos_queue_send_from_isr_failed: tstamp:81377494802 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.412395: rtos_queue_send_from_isr_failed: tstamp:81377494977 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.412398: rtos_queue_send_from_isr_failed: tstamp:81377495156 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.412401: rtos_queue_send_from_isr_failed: tstamp:81377495329 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.412404: rtos_queue_send_from_isr_failed: tstamp:81377495509 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.412406: rtos_queue_send_from_isr_failed: tstamp:81377495683 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.412409: rtos_queue_send_failed: tstamp:81377496383 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.412412: rtos_queue_send_from_isr_failed: tstamp:81377505404 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.412414: rtos_queue_send_from_isr_failed: tstamp:81377505579 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.412417: rtos_queue_send_from_isr_failed: tstamp:81377505754 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.412420: rtos_queue_send_from_isr_failed: tstamp:81377505930 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.412423: rtos_queue_send_from_isr_failed: tstamp:81377506103 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.412425: rtos_queue_send_from_isr_failed: tstamp:81377506275 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.412428: rtos_queue_send_from_isr_failed: tstamp:81377506453 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.412430: rtos_queue_send_from_isr_failed: tstamp:81377506628 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.412433: rtos_queue_send_failed: tstamp:81377507384 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.412436: rtos_queue_send_from_isr_failed: tstamp:81377510037 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.412438: rtos_queue_send_from_isr_failed: tstamp:81377510212 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.412441: rtos_queue_send_from_isr_failed: tstamp:81377510387 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.412444: rtos_queue_send_from_isr_failed: tstamp:81377510562 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.412447: rtos_queue_send_from_isr_failed: tstamp:81377510768 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.412449: rtos_queue_send_from_isr_failed: tstamp:81377510943 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.412452: rtos_queue_send_from_isr_failed: tstamp:81377511117 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.412455: rtos_queue_send_from_isr_failed: tstamp:81377511291 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.412457: rtos_queue_send_failed: tstamp:81377513209 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.525886: rtos_queue_peek_from_isr_failed: tstamp:81380479700 queue:0x0b4b4940
vi-output, apac-23369 [000] … 2595.605480: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23369 [000] … 2595.605521: tegra_channel_capture_frame: sof:-549620698988.-268121905728
kworker/5:3-8921 [005] … 2595.636287: rtos_queue_send_from_isr_failed: tstamp:81384367339 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.636295: rtos_queue_send_from_isr_failed: tstamp:81384367517 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.636298: rtos_queue_send_from_isr_failed: tstamp:81384367694 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.636301: rtos_queue_send_from_isr_failed: tstamp:81384367871 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.636304: rtos_queue_send_from_isr_failed: tstamp:81384368043 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.636306: rtos_queue_send_from_isr_failed: tstamp:81384368217 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.636309: rtos_queue_send_from_isr_failed: tstamp:81384368389 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.636312: rtos_queue_send_from_isr_failed: tstamp:81384368563 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.636317: rtos_queue_send_failed: tstamp:81384369412 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.636320: rtos_queue_send_from_isr_failed: tstamp:81384373349 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.636322: rtos_queue_send_from_isr_failed: tstamp:81384373535 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.636325: rtos_queue_send_from_isr_failed: tstamp:81384373708 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.636328: rtos_queue_send_from_isr_failed: tstamp:81384373883 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.636330: rtos_queue_send_from_isr_failed: tstamp:81384374057 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.636333: rtos_queue_send_from_isr_failed: tstamp:81384374231 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.636336: rtos_queue_send_from_isr_failed: tstamp:81384374403 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.636338: rtos_queue_send_from_isr_failed: tstamp:81384374576 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.636341: rtos_queue_send_failed: tstamp:81384375271 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.636344: rtos_queue_send_from_isr_failed: tstamp:81384384777 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.636347: rtos_queue_send_from_isr_failed: tstamp:81384384952 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.636349: rtos_queue_send_from_isr_failed: tstamp:81384385127 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.636352: rtos_queue_send_from_isr_failed: tstamp:81384385302 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.636355: rtos_queue_send_from_isr_failed: tstamp:81384385476 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.636357: rtos_queue_send_from_isr_failed: tstamp:81384385648 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.636360: rtos_queue_send_from_isr_failed: tstamp:81384385822 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.636362: rtos_queue_send_from_isr_failed: tstamp:81384386001 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.636365: rtos_queue_send_failed: tstamp:81384386713 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.636368: rtos_queue_send_from_isr_failed: tstamp:81384389525 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.636370: rtos_queue_send_from_isr_failed: tstamp:81384389700 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.636373: rtos_queue_send_from_isr_failed: tstamp:81384389875 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.636376: rtos_queue_send_from_isr_failed: tstamp:81384390057 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.636378: rtos_queue_send_from_isr_failed: tstamp:81384390229 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.636381: rtos_queue_send_from_isr_failed: tstamp:81384390411 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.636383: rtos_queue_send_from_isr_failed: tstamp:81384390583 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.636386: rtos_queue_send_from_isr_failed: tstamp:81384390757 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.636389: rtos_queue_send_failed: tstamp:81384392693 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.692344: rtos_queue_peek_from_isr_failed: tstamp:81385479738 queue:0x0b4b4940
kworker/5:3-8921 [005] … 2595.804324: rtos_queue_peek_from_isr_failed: tstamp:81390479713 queue:0x0b4b4940
vi-output, apac-23369 [000] … 2595.825421: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23369 [000] … 2595.825463: tegra_channel_capture_frame: sof:-549620698988.-268121905728
kworker/5:3-8921 [005] … 2595.860327: rtos_queue_send_from_isr_failed: tstamp:81391240811 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.860333: rtos_queue_send_from_isr_failed: tstamp:81391240990 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.860336: rtos_queue_send_from_isr_failed: tstamp:81391241168 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.860343: rtos_queue_send_from_isr_failed: tstamp:81391241343 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.860346: rtos_queue_send_from_isr_failed: tstamp:81391241523 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.860349: rtos_queue_send_from_isr_failed: tstamp:81391241695 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.860353: rtos_queue_send_from_isr_failed: tstamp:81391241869 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.860355: rtos_queue_send_from_isr_failed: tstamp:81391242041 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.860359: rtos_queue_send_failed: tstamp:81391242937 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.860362: rtos_queue_send_from_isr_failed: tstamp:81391248757 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.860364: rtos_queue_send_from_isr_failed: tstamp:81391248932 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.860367: rtos_queue_send_from_isr_failed: tstamp:81391249106 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.860369: rtos_queue_send_from_isr_failed: tstamp:81391249282 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.860372: rtos_queue_send_from_isr_failed: tstamp:81391249456 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.860375: rtos_queue_send_from_isr_failed: tstamp:81391249630 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.860378: rtos_queue_send_from_isr_failed: tstamp:81391249803 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.860380: rtos_queue_send_from_isr_failed: tstamp:81391249977 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.860383: rtos_queue_send_failed: tstamp:81391250679 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.860386: rtos_queue_send_from_isr_failed: tstamp:81391257753 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.860388: rtos_queue_send_from_isr_failed: tstamp:81391257932 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.860391: rtos_queue_send_from_isr_failed: tstamp:81391258140 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.860394: rtos_queue_send_from_isr_failed: tstamp:81391258315 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.860396: rtos_queue_send_from_isr_failed: tstamp:81391258489 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.860399: rtos_queue_send_from_isr_failed: tstamp:81391258662 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.860401: rtos_queue_send_from_isr_failed: tstamp:81391258837 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.860404: rtos_queue_send_from_isr_failed: tstamp:81391259038 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.860407: rtos_queue_send_failed: tstamp:81391259755 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.860409: rtos_queue_send_from_isr_failed: tstamp:81391262682 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.860412: rtos_queue_send_from_isr_failed: tstamp:81391262901 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2595.860415: rtos_queue_send_from_isr_failed: tstamp:81391263076 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2595.860417: rtos_queue_send_from_isr_failed: tstamp:81391263255 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2595.860420: rtos_queue_send_from_isr_failed: tstamp:81391263429 queue:0x0b4af718
kworker/5:3-8921 [005] … 2595.860423: rtos_queue_send_from_isr_failed: tstamp:81391263609 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2595.860425: rtos_queue_send_from_isr_failed: tstamp:81391263783 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2595.860428: rtos_queue_send_from_isr_failed: tstamp:81391263957 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2595.860430: rtos_queue_send_failed: tstamp:81391265890 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2595.972387: rtos_queue_peek_from_isr_failed: tstamp:81395479759 queue:0x0b4b4940
vi-output, apac-23369 [000] … 2596.045825: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23369 [000] … 2596.045872: tegra_channel_capture_frame: sof:-549620698988.-268121905728
kworker/5:3-8921 [005] … 2596.084315: rtos_queue_send_from_isr_failed: tstamp:81398125832 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.084325: rtos_queue_send_from_isr_failed: tstamp:81398126010 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2596.084328: rtos_queue_send_from_isr_failed: tstamp:81398126186 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2596.084331: rtos_queue_send_from_isr_failed: tstamp:81398126361 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2596.084334: rtos_queue_send_from_isr_failed: tstamp:81398126534 queue:0x0b4af718
kworker/5:3-8921 [005] … 2596.084337: rtos_queue_send_from_isr_failed: tstamp:81398126706 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2596.084339: rtos_queue_send_from_isr_failed: tstamp:81398126880 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2596.084342: rtos_queue_send_from_isr_failed: tstamp:81398127052 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2596.084346: rtos_queue_send_failed: tstamp:81398128017 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.084349: rtos_queue_send_from_isr_failed: tstamp:81398136328 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.084352: rtos_queue_send_from_isr_failed: tstamp:81398136501 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2596.084355: rtos_queue_send_from_isr_failed: tstamp:81398136676 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2596.084357: rtos_queue_send_from_isr_failed: tstamp:81398136850 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2596.084360: rtos_queue_send_from_isr_failed: tstamp:81398137023 queue:0x0b4af718
kworker/5:3-8921 [005] … 2596.084363: rtos_queue_send_from_isr_failed: tstamp:81398137225 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2596.084366: rtos_queue_send_from_isr_failed: tstamp:81398137397 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2596.084368: rtos_queue_send_from_isr_failed: tstamp:81398137570 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2596.084371: rtos_queue_send_failed: tstamp:81398138271 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.084374: rtos_queue_send_from_isr_failed: tstamp:81398145216 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.084376: rtos_queue_send_from_isr_failed: tstamp:81398145391 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2596.084379: rtos_queue_send_from_isr_failed: tstamp:81398145566 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2596.084382: rtos_queue_send_from_isr_failed: tstamp:81398145743 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2596.084384: rtos_queue_send_from_isr_failed: tstamp:81398145915 queue:0x0b4af718
kworker/5:3-8921 [005] … 2596.084387: rtos_queue_send_from_isr_failed: tstamp:81398146089 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2596.084389: rtos_queue_send_from_isr_failed: tstamp:81398146263 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2596.084392: rtos_queue_send_from_isr_failed: tstamp:81398146435 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2596.084395: rtos_queue_send_failed: tstamp:81398147148 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.084397: rtos_queue_send_from_isr_failed: tstamp:81398150014 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.084400: rtos_queue_send_from_isr_failed: tstamp:81398150189 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2596.084403: rtos_queue_send_from_isr_failed: tstamp:81398150364 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2596.084405: rtos_queue_send_from_isr_failed: tstamp:81398150539 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2596.084408: rtos_queue_send_from_isr_failed: tstamp:81398150719 queue:0x0b4af718
kworker/5:3-8921 [005] … 2596.084411: rtos_queue_send_from_isr_failed: tstamp:81398150892 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2596.084413: rtos_queue_send_from_isr_failed: tstamp:81398151064 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2596.084416: rtos_queue_send_from_isr_failed: tstamp:81398151237 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2596.084419: rtos_queue_send_failed: tstamp:81398153127 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.140330: rtos_queue_peek_from_isr_failed: tstamp:81400479753 queue:0x0b4b4940
vi-output, apac-23369 [000] … 2596.265227: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23369 [000] … 2596.265267: tegra_channel_capture_frame: sof:-549620698988.-268121905728
kworker/5:3-8921 [005] … 2596.308323: rtos_queue_send_from_isr_failed: tstamp:81404987780 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.308332: rtos_queue_send_from_isr_failed: tstamp:81404987957 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2596.308336: rtos_queue_send_from_isr_failed: tstamp:81404988133 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2596.308340: rtos_queue_send_from_isr_failed: tstamp:81404988308 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2596.308343: rtos_queue_send_from_isr_failed: tstamp:81404988482 queue:0x0b4af718
kworker/5:3-8921 [005] … 2596.308346: rtos_queue_send_from_isr_failed: tstamp:81404988654 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2596.308348: rtos_queue_send_from_isr_failed: tstamp:81404988832 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2596.308352: rtos_queue_send_from_isr_failed: tstamp:81404989003 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2596.308356: rtos_queue_send_failed: tstamp:81404989866 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.308359: rtos_queue_send_from_isr_failed: tstamp:81404993522 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.308362: rtos_queue_send_from_isr_failed: tstamp:81404993713 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2596.308364: rtos_queue_send_from_isr_failed: tstamp:81404993888 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2596.308367: rtos_queue_send_from_isr_failed: tstamp:81404994063 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2596.308370: rtos_queue_send_from_isr_failed: tstamp:81404994235 queue:0x0b4af718
kworker/5:3-8921 [005] … 2596.308372: rtos_queue_send_from_isr_failed: tstamp:81404994408 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2596.308375: rtos_queue_send_from_isr_failed: tstamp:81404994580 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2596.308377: rtos_queue_send_from_isr_failed: tstamp:81404994753 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2596.308380: rtos_queue_send_failed: tstamp:81404995444 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.308383: rtos_queue_send_from_isr_failed: tstamp:81405001825 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.308385: rtos_queue_send_from_isr_failed: tstamp:81405002000 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2596.308388: rtos_queue_send_from_isr_failed: tstamp:81405002175 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2596.308391: rtos_queue_send_from_isr_failed: tstamp:81405002350 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2596.308393: rtos_queue_send_from_isr_failed: tstamp:81405002522 queue:0x0b4af718
kworker/5:3-8921 [005] … 2596.308396: rtos_queue_send_from_isr_failed: tstamp:81405002695 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2596.308399: rtos_queue_send_from_isr_failed: tstamp:81405002869 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2596.308401: rtos_queue_send_from_isr_failed: tstamp:81405003041 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2596.308404: rtos_queue_send_failed: tstamp:81405003788 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.308407: rtos_queue_send_from_isr_failed: tstamp:81405006602 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.308409: rtos_queue_send_from_isr_failed: tstamp:81405006777 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2596.308412: rtos_queue_send_from_isr_failed: tstamp:81405006952 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 2596.308414: rtos_queue_send_from_isr_failed: tstamp:81405007128 queue:0x0b4ae958
kworker/5:3-8921 [005] … 2596.308417: rtos_queue_send_from_isr_failed: tstamp:81405007302 queue:0x0b4af718
kworker/5:3-8921 [005] … 2596.308420: rtos_queue_send_from_isr_failed: tstamp:81405007482 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 2596.308422: rtos_queue_send_from_isr_failed: tstamp:81405007656 queue:0x0b4b1298
kworker/5:3-8921 [005] … 2596.308425: rtos_queue_send_from_isr_failed: tstamp:81405007830 queue:0x0b4b2058
kworker/5:3-8921 [005] … 2596.308427: rtos_queue_send_failed: tstamp:81405009737 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.308431: rtos_queue_peek_from_isr_failed: tstamp:81405479771 queue:0x0b4b4940
kworker/5:3-8921 [005] … 2596.476306: rtos_queue_peek_from_isr_failed: tstamp:81410479752 queue:0x0b4b4940
vi-output, apac-23369 [000] … 2596.485346: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23369 [000] … 2596.485391: tegra_channel_capture_frame: sof:-549620698988.-268121905728
kworker/5:3-8921 [005] … 2596.532390: rtos_queue_send_from_isr_failed: tstamp:81411863754 queue:0x0b4a7698
kworker/5:3-8921 [005] … 2596.532399: rtos_queue_send_from_isr_failed: tstamp:81411863931 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 2596.532402: rtos_queue_send_from_isr_failed: tstamp:81411864139 queue:0x0b4acdd8
v4l2-ctl --set-fmt-video=width=1920,height=1080” --device=/dev/video1 --stream-count=300 --stream-mmap
v4l2-ctl-23611 [004] … 3482.230770: tegra_channel_open: vi-output, apach3_5 2-001c
v4l2-ctl-23611 [000] … 3482.232237: tegra_channel_set_power: apach3_5 2-001c : 0x1
v4l2-ctl-23611 [000] … 3482.232260: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
v4l2-ctl-23611 [000] … 3482.232264: csi_s_power: enable : 0x1
v4l2-ctl-23611 [004] … 3482.256298: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23612 [003] … 3482.256561: tegra_channel_set_stream: enable : 0x1
vi-output, apac-23612 [000] … 3482.260120: tegra_channel_set_stream: 150c0000.nvcsi–1 : 0x1
vi-output, apac-23612 [000] … 3482.260124: csi_s_stream: enable : 0x1
vi-output, apac-23612 [000] … 3482.260167: tegra_channel_set_stream: apach3_5 2-001c : 0x1
kworker/5:3-8921 [005] … 3482.289745: rtos_queue_peek_from_isr_failed: tstamp:109092154204 queue:0x0b4b4940
kworker/5:3-8921 [005] … 3482.289754: rtcpu_start: tstamp:109092155678
kworker/5:3-8921 [005] … 3482.289758: rtos_queue_send_from_isr_failed: tstamp:109092218487 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.289760: rtos_queue_send_from_isr_failed: tstamp:109092218663 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.289762: rtos_queue_send_from_isr_failed: tstamp:109092218838 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.289763: rtos_queue_send_from_isr_failed: tstamp:109092219033 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.289765: rtos_queue_send_from_isr_failed: tstamp:109092219205 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.289767: rtos_queue_send_from_isr_failed: tstamp:109092219378 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.289768: rtos_queue_send_from_isr_failed: tstamp:109092219552 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.289770: rtos_queue_send_from_isr_failed: tstamp:109092219724 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.289773: rtos_queue_send_failed: tstamp:109092220541 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.289774: rtos_queue_send_from_isr_failed: tstamp:109092226031 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.289776: rtos_queue_send_from_isr_failed: tstamp:109092226233 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.289777: rtos_queue_send_from_isr_failed: tstamp:109092226408 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.289778: rtos_queue_send_from_isr_failed: tstamp:109092226582 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.289779: rtos_queue_send_from_isr_failed: tstamp:109092226755 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.289781: rtos_queue_send_from_isr_failed: tstamp:109092226932 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.289782: rtos_queue_send_from_isr_failed: tstamp:109092227106 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.289783: rtos_queue_send_from_isr_failed: tstamp:109092227278 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.289784: rtos_queue_send_failed: tstamp:109092229211 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.457823: rtos_queue_peek_from_isr_failed: tstamp:109097154580 queue:0x0b4b4940
vi-output, apac-23612 [004] … 3482.479167: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23612 [004] … 3482.479214: tegra_channel_capture_frame: sof:-549620698988.-269473933120
kworker/5:3-8921 [005] … 3482.513864: rtos_queue_send_from_isr_failed: tstamp:109099160893 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.513874: rtos_queue_send_from_isr_failed: tstamp:109099161069 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.513877: rtos_queue_send_from_isr_failed: tstamp:109099161245 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.513880: rtos_queue_send_from_isr_failed: tstamp:109099161421 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.513883: rtos_queue_send_from_isr_failed: tstamp:109099161594 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.513885: rtos_queue_send_from_isr_failed: tstamp:109099161768 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.513888: rtos_queue_send_from_isr_failed: tstamp:109099161942 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.513890: rtos_queue_send_from_isr_failed: tstamp:109099162116 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.513896: rtos_queue_send_failed: tstamp:109099162984 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.513898: rtos_queue_send_from_isr_failed: tstamp:109099169387 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.513902: rtos_queue_send_from_isr_failed: tstamp:109099169562 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.513904: rtos_queue_send_from_isr_failed: tstamp:109099169736 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.513907: rtos_queue_send_from_isr_failed: tstamp:109099169911 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.513909: rtos_queue_send_from_isr_failed: tstamp:109099170085 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.513912: rtos_queue_send_from_isr_failed: tstamp:109099170257 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.513915: rtos_queue_send_from_isr_failed: tstamp:109099170430 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.513918: rtos_queue_send_from_isr_failed: tstamp:109099170609 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.513920: rtos_queue_send_failed: tstamp:109099171314 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.513923: rtos_queue_send_from_isr_failed: tstamp:109099186265 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.513926: rtos_queue_send_from_isr_failed: tstamp:109099186440 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.513928: rtos_queue_send_from_isr_failed: tstamp:109099186615 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.513931: rtos_queue_send_from_isr_failed: tstamp:109099186790 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.513933: rtos_queue_send_from_isr_failed: tstamp:109099186964 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.513936: rtos_queue_send_from_isr_failed: tstamp:109099187137 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.513939: rtos_queue_send_from_isr_failed: tstamp:109099187310 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.513941: rtos_queue_send_from_isr_failed: tstamp:109099187482 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.513944: rtos_queue_send_failed: tstamp:109099188197 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.513947: rtos_queue_send_from_isr_failed: tstamp:109099191800 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.513949: rtos_queue_send_from_isr_failed: tstamp:109099191975 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.513952: rtos_queue_send_from_isr_failed: tstamp:109099192149 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.513955: rtos_queue_send_from_isr_failed: tstamp:109099192326 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.513957: rtos_queue_send_from_isr_failed: tstamp:109099192528 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.513960: rtos_queue_send_from_isr_failed: tstamp:109099192734 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.513963: rtos_queue_send_from_isr_failed: tstamp:109099192913 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.513966: rtos_queue_send_from_isr_failed: tstamp:109099193087 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.513968: rtos_queue_send_failed: tstamp:109099194977 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.625847: rtos_queue_peek_from_isr_failed: tstamp:109102154643 queue:0x0b4b4940
vi-output, apac-23612 [004] … 3482.698839: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23612 [004] … 3482.698885: tegra_channel_capture_frame: sof:-549620698988.-269473933120
kworker/5:3-8921 [005] … 3482.737836: rtos_queue_send_from_isr_failed: tstamp:109106037845 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.737844: rtos_queue_send_from_isr_failed: tstamp:109106038024 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.737846: rtos_queue_send_from_isr_failed: tstamp:109106038200 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.737849: rtos_queue_send_from_isr_failed: tstamp:109106038378 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.737852: rtos_queue_send_from_isr_failed: tstamp:109106038553 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.737855: rtos_queue_send_from_isr_failed: tstamp:109106038727 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.737857: rtos_queue_send_from_isr_failed: tstamp:109106038900 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.737860: rtos_queue_send_from_isr_failed: tstamp:109106039074 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.737866: rtos_queue_send_failed: tstamp:109106040053 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.737868: rtos_queue_send_from_isr_failed: tstamp:109106043937 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.737871: rtos_queue_send_from_isr_failed: tstamp:109106044114 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.737874: rtos_queue_send_from_isr_failed: tstamp:109106044297 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.737876: rtos_queue_send_from_isr_failed: tstamp:109106044472 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.737879: rtos_queue_send_from_isr_failed: tstamp:109106044646 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.737882: rtos_queue_send_from_isr_failed: tstamp:109106044818 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.737888: rtos_queue_send_from_isr_failed: tstamp:109106044991 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.737892: rtos_queue_send_from_isr_failed: tstamp:109106045163 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.737895: rtos_queue_send_failed: tstamp:109106045856 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.737898: rtos_queue_send_from_isr_failed: tstamp:109106052351 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.737901: rtos_queue_send_from_isr_failed: tstamp:109106052526 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.737904: rtos_queue_send_from_isr_failed: tstamp:109106052701 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.737906: rtos_queue_send_from_isr_failed: tstamp:109106052876 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.737909: rtos_queue_send_from_isr_failed: tstamp:109106053050 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.737912: rtos_queue_send_from_isr_failed: tstamp:109106053222 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.737914: rtos_queue_send_from_isr_failed: tstamp:109106053396 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.737917: rtos_queue_send_from_isr_failed: tstamp:109106053570 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.737919: rtos_queue_send_failed: tstamp:109106054265 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.737922: rtos_queue_send_from_isr_failed: tstamp:109106056994 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.737925: rtos_queue_send_from_isr_failed: tstamp:109106057169 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.737928: rtos_queue_send_from_isr_failed: tstamp:109106057344 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.737930: rtos_queue_send_from_isr_failed: tstamp:109106057522 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.737933: rtos_queue_send_from_isr_failed: tstamp:109106057696 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.737936: rtos_queue_send_from_isr_failed: tstamp:109106057868 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.737938: rtos_queue_send_from_isr_failed: tstamp:109106058042 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.737941: rtos_queue_send_from_isr_failed: tstamp:109106058217 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.737944: rtos_queue_send_failed: tstamp:109106060135 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.737948: rtos_queue_peek_from_isr_failed: tstamp:109107154603 queue:0x0b4b4940
kworker/5:3-8921 [005] … 3482.905837: rtos_queue_peek_from_isr_failed: tstamp:109112154592 queue:0x0b4b4940
vi-output, apac-23612 [004] … 3482.919063: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23612 [004] … 3482.919105: tegra_channel_capture_frame: sof:-549620698988.-269473933120
kworker/5:3-8921 [005] … 3482.961859: rtos_queue_send_from_isr_failed: tstamp:109112911953 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.961871: rtos_queue_send_from_isr_failed: tstamp:109112912131 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.961874: rtos_queue_send_from_isr_failed: tstamp:109112912309 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.961876: rtos_queue_send_from_isr_failed: tstamp:109112912485 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.961879: rtos_queue_send_from_isr_failed: tstamp:109112912661 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.961882: rtos_queue_send_from_isr_failed: tstamp:109112912840 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.961884: rtos_queue_send_from_isr_failed: tstamp:109112913017 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.961888: rtos_queue_send_from_isr_failed: tstamp:109112913189 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.961893: rtos_queue_send_failed: tstamp:109112914081 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.961895: rtos_queue_send_from_isr_failed: tstamp:109112918574 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.961898: rtos_queue_send_from_isr_failed: tstamp:109112918749 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.961901: rtos_queue_send_from_isr_failed: tstamp:109112918929 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.961903: rtos_queue_send_from_isr_failed: tstamp:109112919103 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.961906: rtos_queue_send_from_isr_failed: tstamp:109112919283 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.961909: rtos_queue_send_from_isr_failed: tstamp:109112919456 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.961911: rtos_queue_send_from_isr_failed: tstamp:109112919628 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.961914: rtos_queue_send_from_isr_failed: tstamp:109112919801 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.961917: rtos_queue_send_failed: tstamp:109112920502 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.961920: rtos_queue_send_from_isr_failed: tstamp:109112929088 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.961922: rtos_queue_send_from_isr_failed: tstamp:109112929294 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.961925: rtos_queue_send_from_isr_failed: tstamp:109112929469 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.961928: rtos_queue_send_from_isr_failed: tstamp:109112929659 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.961930: rtos_queue_send_from_isr_failed: tstamp:109112929832 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.961933: rtos_queue_send_from_isr_failed: tstamp:109112930004 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.961935: rtos_queue_send_from_isr_failed: tstamp:109112930179 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.961938: rtos_queue_send_from_isr_failed: tstamp:109112930355 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.961941: rtos_queue_send_failed: tstamp:109112931129 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.961943: rtos_queue_send_from_isr_failed: tstamp:109112937035 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3482.961946: rtos_queue_send_from_isr_failed: tstamp:109112937209 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3482.961949: rtos_queue_send_from_isr_failed: tstamp:109112937383 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3482.961951: rtos_queue_send_from_isr_failed: tstamp:109112937559 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3482.961954: rtos_queue_send_from_isr_failed: tstamp:109112937731 queue:0x0b4af718
kworker/5:3-8921 [005] … 3482.961957: rtos_queue_send_from_isr_failed: tstamp:109112937904 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3482.961959: rtos_queue_send_from_isr_failed: tstamp:109112938076 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3482.961962: rtos_queue_send_from_isr_failed: tstamp:109112938250 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3482.961964: rtos_queue_send_failed: tstamp:109112940216 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.073853: rtos_queue_peek_from_isr_failed: tstamp:109117154679 queue:0x0b4b4940
vi-output, apac-23612 [004] … 3483.138860: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23612 [004] … 3483.138906: tegra_channel_capture_frame: sof:-549620698988.-269473933120
kworker/5:3-8921 [005] … 3483.185883: rtos_queue_send_from_isr_failed: tstamp:109119787060 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.185892: rtos_queue_send_from_isr_failed: tstamp:109119787238 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3483.185895: rtos_queue_send_from_isr_failed: tstamp:109119787414 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3483.185897: rtos_queue_send_from_isr_failed: tstamp:109119787591 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3483.185900: rtos_queue_send_from_isr_failed: tstamp:109119787763 queue:0x0b4af718
kworker/5:3-8921 [005] … 3483.185903: rtos_queue_send_from_isr_failed: tstamp:109119787937 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3483.185906: rtos_queue_send_from_isr_failed: tstamp:109119788111 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3483.185908: rtos_queue_send_from_isr_failed: tstamp:109119788285 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3483.185912: rtos_queue_send_failed: tstamp:109119789218 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.185915: rtos_queue_send_from_isr_failed: tstamp:109119793090 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.185918: rtos_queue_send_from_isr_failed: tstamp:109119793265 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3483.185920: rtos_queue_send_from_isr_failed: tstamp:109119793440 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3483.185923: rtos_queue_send_from_isr_failed: tstamp:109119793615 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3483.185926: rtos_queue_send_from_isr_failed: tstamp:109119793789 queue:0x0b4af718
kworker/5:3-8921 [005] … 3483.185928: rtos_queue_send_from_isr_failed: tstamp:109119793992 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3483.185931: rtos_queue_send_from_isr_failed: tstamp:109119794166 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3483.185934: rtos_queue_send_from_isr_failed: tstamp:109119794346 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3483.185936: rtos_queue_send_failed: tstamp:109119795089 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.185939: rtos_queue_send_from_isr_failed: tstamp:109119802300 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.185942: rtos_queue_send_from_isr_failed: tstamp:109119802475 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3483.185944: rtos_queue_send_from_isr_failed: tstamp:109119802649 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3483.185947: rtos_queue_send_from_isr_failed: tstamp:109119802859 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3483.185950: rtos_queue_send_from_isr_failed: tstamp:109119803033 queue:0x0b4af718
kworker/5:3-8921 [005] … 3483.185952: rtos_queue_send_from_isr_failed: tstamp:109119803205 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3483.185955: rtos_queue_send_from_isr_failed: tstamp:109119803379 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3483.185958: rtos_queue_send_from_isr_failed: tstamp:109119803553 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3483.185960: rtos_queue_send_failed: tstamp:109119804285 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.185963: rtos_queue_send_from_isr_failed: tstamp:109119807522 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.185965: rtos_queue_send_from_isr_failed: tstamp:109119807697 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3483.185968: rtos_queue_send_from_isr_failed: tstamp:109119807873 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3483.185971: rtos_queue_send_from_isr_failed: tstamp:109119808048 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3483.185973: rtos_queue_send_from_isr_failed: tstamp:109119808227 queue:0x0b4af718
kworker/5:3-8921 [005] … 3483.185976: rtos_queue_send_from_isr_failed: tstamp:109119808410 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3483.185979: rtos_queue_send_from_isr_failed: tstamp:109119808584 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3483.185982: rtos_queue_send_from_isr_failed: tstamp:109119808764 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3483.185984: rtos_queue_send_failed: tstamp:109119810648 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.241857: rtos_queue_peek_from_isr_failed: tstamp:109122154643 queue:0x0b4b4940
vi-output, apac-23612 [004] … 3483.358964: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, apac-23612 [004] … 3483.359016: tegra_channel_capture_frame: sof:-549620698988.-269473933120
kworker/5:3-8921 [005] … 3483.361901: rtos_queue_send_from_isr_failed: tstamp:109126661912 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.361907: rtos_queue_send_from_isr_failed: tstamp:109126662089 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3483.361909: rtos_queue_send_from_isr_failed: tstamp:109126662266 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3483.361911: rtos_queue_send_from_isr_failed: tstamp:109126662442 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3483.361913: rtos_queue_send_from_isr_failed: tstamp:109126662616 queue:0x0b4af718
kworker/5:3-8921 [005] … 3483.361916: rtos_queue_send_from_isr_failed: tstamp:109126662792 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3483.361918: rtos_queue_send_from_isr_failed: tstamp:109126662966 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3483.361920: rtos_queue_send_from_isr_failed: tstamp:109126663138 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3483.361923: rtos_queue_send_failed: tstamp:109126663990 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.361925: rtos_queue_send_from_isr_failed: tstamp:109126667406 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.361927: rtos_queue_send_from_isr_failed: tstamp:109126667609 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3483.361930: rtos_queue_send_from_isr_failed: tstamp:109126667817 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3483.361932: rtos_queue_send_from_isr_failed: tstamp:109126667993 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3483.361934: rtos_queue_send_from_isr_failed: tstamp:109126668167 queue:0x0b4af718
kworker/5:3-8921 [005] … 3483.361936: rtos_queue_send_from_isr_failed: tstamp:109126668338 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3483.361938: rtos_queue_send_from_isr_failed: tstamp:109126668511 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3483.361940: rtos_queue_send_from_isr_failed: tstamp:109126668683 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3483.361942: rtos_queue_send_failed: tstamp:109126669434 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.361944: rtos_queue_send_from_isr_failed: tstamp:109126676528 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.361946: rtos_queue_send_from_isr_failed: tstamp:109126676703 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3483.361948: rtos_queue_send_from_isr_failed: tstamp:109126676877 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3483.361950: rtos_queue_send_from_isr_failed: tstamp:109126677052 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3483.361953: rtos_queue_send_from_isr_failed: tstamp:109126677224 queue:0x0b4af718
kworker/5:3-8921 [005] … 3483.361955: rtos_queue_send_from_isr_failed: tstamp:109126677398 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3483.361957: rtos_queue_send_from_isr_failed: tstamp:109126677572 queue:0x0b4b1298
kworker/5:3-8921 [005] … 3483.361959: rtos_queue_send_from_isr_failed: tstamp:109126677745 queue:0x0b4b2058
kworker/5:3-8921 [005] … 3483.361961: rtos_queue_send_failed: tstamp:109126678487 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.361963: rtos_queue_send_from_isr_failed: tstamp:109126683345 queue:0x0b4a7698
kworker/5:3-8921 [005] … 3483.361965: rtos_queue_send_from_isr_failed: tstamp:109126683520 queue:0x0b4ab1a8
kworker/5:3-8921 [005] … 3483.361968: rtos_queue_send_from_isr_failed: tstamp:109126683696 queue:0x0b4acdd8
kworker/5:3-8921 [005] … 3483.361970: rtos_queue_send_from_isr_failed: tstamp:109126683871 queue:0x0b4ae958
kworker/5:3-8921 [005] … 3483.361972: rtos_queue_send_from_isr_failed: tstamp:109126684045 queue:0x0b4af718
kworker/5:3-8921 [005] … 3483.361974: rtos_queue_send_from_isr_failed: tstamp:109126684219 queue:0x0b4b04d8
kworker/5:3-8921 [005] … 3483.361976: rtos_queue_send_from_isr_failed: tstamp:109126684391 queue:0x0b4b1298
