Hi @KevinFFF,
I got following error with your suggested command :
Writing esp partition done
writing item=11, 9:0:recovery_alt, 487870464, 83886080, , , fixed-<reserved>-11,
[ 32]: l4t_flash_from_kernel: Warning: skip writing recovery_alt partition as no image is specified
writing item=12, 9:0:recovery-dtb_alt, 571756544, 524288, , , fixed-<reserved>-12,
[ 32]: l4t_flash_from_kernel: Warning: skip writing recovery-dtb_alt partition as no image is specified
writing item=13, 9:0:esp_alt, 572280832, 67108864, , , fixed-<reserved>-13,
[ 33]: l4t_flash_from_kernel: Warning: skip writing esp_alt partition as no image is specified
writing item=14, 9:0:UDA, 639401984, 419430400, , , fixed-<reserved>-14,
[ 33]: l4t_flash_from_kernel: Skip writing UDA partition
writing item=15, 9:0:reserved, 1058832384, 502792192, , , fixed-<reserved>-15,
[ 33]: l4t_flash_from_kernel: Warning: skip writing reserved partition as no image is specified
writing item=16, 9:0:APP, 1561624576, 59641638912, , , expand-<reserved>-1,
Formatting APP partition /dev/nvme0n1p1 ...
mke2fs 1.46.5 (30-Dec-2021)
Discarding device blocks: done
Creating filesystem with 124645641 4k blocks and 31162368 inodes
Filesystem UUID: 6b3702ec-80fa-49b6-91f4-7f7c1261a1c2
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
102400000
Allocating group tables: done
Writing inode tables: done
Creating journal (262144 blocks): done
Writing superblocks and filesystem accounting information: done
Formatting APP parition done
tar --checkpoint-action="ttyout=Hit %s checkpoint #%u%*\r" -x -I 'zstd -T0' -pf /mnt/external/system.img --warning=no-timestamp --numeric-owner --xattrs --xattrs-include=* -C /tmp/ci-X5V2grhpKe
Flash failure
Either the device cannot mount the NFS server on the host or a flash command has failed. Check your network setting (VPN, firewall,...) to make sure the device can mount NFS server. Debug log saved to /tmp/tmp.SP0kNkLoLB. You can access the target's terminal through "sshpass -p root ssh root@fc00:1:1:0::2"
Cleaning up...
And the /tmp/tmp.SP0kNkLoLB :
showmount -e
Export list for ASUS-MINIPC-PN64:
/home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs fc00:1:1::/48
/home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images fc00:1:1::/48
/home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1
systemctl status nfs-kernel-server
● nfs-server.service - NFS server and services
Loaded: loaded (/lib/systemd/system/nfs-server.service; enabled; vendor preset: enabled)
Active: active (exited) since Thu 2025-07-24 21:02:07 +07; 7min ago
Process: 1130301 ExecStartPre=/usr/sbin/exportfs -r (code=exited, status=0/SUCCESS)
Process: 1130302 ExecStart=/usr/sbin/rpc.nfsd $RPCNFSDARGS (code=exited, status=0/SUCCESS)
Main PID: 1130302 (code=exited, status=0/SUCCESS)
Thg 7 24 21:02:06 ASUS-MINIPC-PN64 systemd[1]: Starting NFS server and services...
Thg 7 24 21:02:07 ASUS-MINIPC-PN64 systemd[1]: Finished NFS server and services.
blkid
/dev/nvme0n1p4: UUID="d1174521-00a4-400e-88bc-702de5783cff" TYPE="swap" PARTUUID="a9712fcb-48ab-4e25-bc83-e06e613e4c3e"
/dev/nvme0n1p2: UUID="5f4b4f6f-739e-4950-9227-8a122fba28e4" TYPE="ext4" PARTUUID="59dce8e9-0a19-41e4-aef2-10c462ff980c"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/nvme0n1p1: UUID="6EAA-356B" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="3fbf1491-cf52-4a8e-b5b1-35f6341e0d09"
/dev/nvme0n1p3: UUID="b4c3a209-fd91-40fe-ab5c-04ad6103a044" TYPE="ext4" PARTUUID="bc1831b6-f53f-48b1-b4f8-6ef54bac80e8"
/dev/sda1: UUID="8EC1-4DB3" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="b5cce681-16b3-4652-ab41-53b01862676b"
/dev/sda3: UUID="308AC2248AC1E706" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="cb2b7b63-2ea0-4c2b-b17b-a39dd6f0256f"
/dev/sda4: UUID="E0B465DBB465B4A6" TYPE="ntfs" PARTUUID="547c865f-050f-46c3-a6de-826a3d892356"
/dev/loop9: TYPE="squashfs"
/dev/loop8: TYPE="squashfs"
/dev/loop10: TYPE="squashfs"
/dev/loop12: TYPE="squashfs"
/dev/loop11: TYPE="squashfs"
/dev/sda2: PARTLABEL="Microsoft reserved partition" PARTUUID="560c48d8-cd59-4843-a9c1-24e577e2940a"
df -h
Filesystem Size Used Avail Use% Mounted on
udev 7,7G 0 7,7G 0% /dev
tmpfs 1,6G 2,2M 1,6G 1% /run
/dev/nvme0n1p2 201G 24G 168G 13% /
tmpfs 7,7G 5,1M 7,7G 1% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 7,7G 0 7,7G 0% /sys/fs/cgroup
/dev/loop0 128K 128K 0 100% /snap/bare/5
/dev/loop2 64M 64M 0 100% /snap/core20/2582
/dev/loop1 74M 74M 0 100% /snap/core22/2010
/dev/loop3 517M 517M 0 100% /snap/gnome-42-2204/202
/dev/loop4 347M 347M 0 100% /snap/gnome-3-38-2004/119
/dev/loop5 350M 350M 0 100% /snap/gnome-3-38-2004/143
/dev/loop6 46M 46M 0 100% /snap/snap-store/638
/dev/loop7 13M 13M 0 100% /snap/snap-store/1216
/dev/loop9 50M 50M 0 100% /snap/snapd/24792
/dev/loop8 51M 51M 0 100% /snap/snapd/24718
/dev/loop10 92M 92M 0 100% /snap/gtk-common-themes/1535
/dev/loop12 74M 74M 0 100% /snap/core22/2045
/dev/loop11 64M 64M 0 100% /snap/core20/2599
/dev/nvme0n1p1 511M 6,1M 505M 2% /boot/efi
/dev/nvme0n1p3 733G 640G 56G 92% /home
tmpfs 1,6G 128K 1,6G 1% /run/user/1000
Checking folder /home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs
drwxr-xr-x 18 root root 4096 Thg 7 23 14:00 rootfs
Checking folder /home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/images
drwxr-xr-x 4 root root 4096 Thg 7 24 21:01 images
-rwxrwxr-x 1 ontrak ontrak 20243 Thg 1 8 2025 l4t_create_images_for_kernel_flash.sh
iptables -vL -t filter
Chain INPUT (policy ACCEPT 5599K packets, 3605M bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy DROP 0 packets, 0 bytes)
0 0 DOCKER-USER all -- any any anywhere anywhere
0 0 DOCKER-FORWARD all -- any any anywhere anywhere
0 0 ACCEPT all -- any wlx00e030000416 192.168.55.0/24 anywhere
0 0 ACCEPT all -- wlx00e030000416 any anywhere 192.168.55.0/24 state RELATED,ESTABLISHED
Chain OUTPUT (policy ACCEPT 4276K packets, 2912M bytes)
Chain DOCKER (1 references)
0 0 DROP all -- !docker0 docker0 anywhere anywhere
Chain DOCKER-BRIDGE (1 references)
0 0 DOCKER all -- any docker0 anywhere anywhere
Chain DOCKER-CT (1 references)
0 0 ACCEPT all -- any docker0 anywhere anywhere ctstate RELATED,ESTABLISHED
Chain DOCKER-FORWARD (1 references)
0 0 DOCKER-CT all -- any any anywhere anywhere
0 0 DOCKER-ISOLATION-STAGE-1 all -- any any anywhere anywhere
0 0 DOCKER-BRIDGE all -- any any anywhere anywhere
0 0 ACCEPT all -- docker0 any anywhere anywhere
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
0 0 DOCKER-ISOLATION-STAGE-2 all -- docker0 !docker0 anywhere anywhere
Chain DOCKER-ISOLATION-STAGE-2 (1 references)
0 0 DROP all -- any docker0 anywhere anywhere
Chain DOCKER-USER (1 references)
0 0 RETURN all -- any any anywhere anywhere
Then it gave error on the flash command that I often used :
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
Please install the Secureboot package to use initrd flash for fused board
# Entry added by NVIDIA initrd flash tool
/home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
rpcbind: another rpcbind is already running. Aborting
Export list for localhost:
/home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p -c bootloader/t186ref/cfg/flash_t234_qspi.xml --showlogs --network usb0 jetson-orin-nano-devkit internal
* Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
ADDITIONAL_DTB_OVERLAY="" /home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/flash.sh --no-flash --sign -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
# L4T BSP Information:
# R36 , REVISION: 4.3
# User release: 0.0
ECID is 0x80012344705E015B8000000016FE81C0
copying device_config(/home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
copying emc_fuse_dev_params(/home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying minratchet_config(/home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
Existing emcfuse(/home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
./tegraflash.py --chip "0x23" --applet "/home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --cmd "readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0119 ] Reading fuses
[ 0.0126 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0132 ] File rcm_state open failed
[ 0.0134 ] ERROR: failed to read rcm_state
[ 0.0134 ]
[ 0.0141 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0143 ] Assuming zero filled SBK key
[ 0.0137 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0178 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0238 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[ 0.0276 ] Parsing partition layout
[ 0.0282 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0292 ] Kernel DTB used: None
[ 0.0292 ] WARNING: dce base dtb is not provided
[ 0.0292 ] Parsing partition layout
[ 0.0298 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0305 ] Creating list of images to be signed
[ 0.0310 ] Generating ratchet blob
[ 0.0311 ] Generating coldboot mb1-bct
[ 0.0315 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 0.0321 ] MB1-BCT version: 0.13
[ 0.0342 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0343 ] Added Platform Config 9 data with size :- 100
[ 0.0344 ]
[ 0.0344 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 0.0344 ]
[ 0.0345 ] Updating mb1-bct with firmware information
[ 0.0350 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0365 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0371 ] Generating SHA2 Hash for mb1bct
[ 0.0388 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 0.0398 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 0.0398 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.0404 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0416 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0417 ] Assuming zero filled SBK key
[ 0.0428 ] Warning: pub_key.key is not found
[ 0.0429 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0439 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 0.0444 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0450 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0452 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0479 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0480 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0506 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0507 ] adding BCH for mb2_t234_aligned.bin
[ 0.0522 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0597 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0598 ] adding BCH for mb2_t234_aligned.bin
[ 0.0682 ] Filling MB1 storage info
[ 0.0682 ] Parsing dev params for multi chains
[ 0.0735 ] Generating br-bct
[ 0.0742 ] Updating dev and MSS params in BR BCT
[ 0.0743 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0751 ] Updating bl info
[ 0.0760 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0767 ] WARNING: boot chain is not completed. set to 0
[ 0.0772 ] Generating signatures
[ 0.0779 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0782 ] Assuming zero filled SBK key
[ 0.0902 ] Warning: pub_key.key is not found
[ 0.0897 ] Parsing dev params for multi chains
[ 0.0897 ] Generating br-bct
[ 0.0903 ] Updating dev and MSS params in BR BCT
[ 0.0903 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0911 ] Updating bl info
[ 0.0916 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0921 ] WARNING: boot chain is not completed. set to 0
[ 0.0926 ] Generating SHA2 Hash
[ 0.0941 ] Sha saved in br_bct_BR.sha
[ 0.0935 ] Get Signed section of bct
[ 0.0940 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.0945 ] Signing BCT
[ 0.0953 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0954 ] Assuming zero filled SBK key
[ 0.0972 ] Sha saved in br_bct_BR.sha
[ 0.0974 ] Warning: pub_key.key is not found
[ 0.0967 ] Updating BCT with signature
[ 0.0974 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.0978 ] Offset :4608 Len :3584
[ 0.0980 ] Generating SHA2 Hash
[ 0.0987 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.0990 ] Assuming zero filled SBK key
[ 0.1016 ] Sha saved in br_bct_BR.sha
[ 0.1012 ] Updating BCT with SHA2 Hash
[ 0.1019 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1025 ] Offset :4608 Len :3584
[ 0.1027 ] Offset :68 Len :8124
[ 0.1027 ]
[ 0.1028 ] Generating coldboot mb1-bct
[ 0.1035 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 0.1043 ] MB1-BCT version: 0.13
[ 0.1057 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1060 ] Added Platform Config 9 data with size :- 100
[ 0.1060 ]
[ 0.1060 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 0.1060 ]
[ 0.1060 ] Updating mb1-bct with firmware information
[ 0.1066 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1082 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1089 ] Generating SHA2 Hash for mb1bct
[ 0.1107 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 0.1117 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 0.1118 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1124 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1136 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1137 ] Assuming zero filled SBK key
[ 0.1149 ] Warning: pub_key.key is not found
[ 0.1148 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1157 ] Generating recovery mb1-bct
[ 0.1165 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 0.1171 ] MB1-BCT version: 0.13
[ 0.1191 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1192 ] Added Platform Config 9 data with size :- 100
[ 0.1193 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 0.1194 ] Updating mb1-bct with firmware information
[ 0.1201 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1213 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1219 ] Generating SHA2 Hash for mb1bct
[ 0.1235 ] Sha saved in mb1_bct_MB1_aligned.sha
[ 0.1244 ] Sha saved in mb1_bct_MB1.sha
[ 0.1244 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1248 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1260 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1261 ] Assuming zero filled SBK key
[ 0.1273 ] Warning: pub_key.key is not found
[ 0.1273 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1281 ] Info: Skip generating mem_bct because sdram_config is not defined
[ 0.1281 ] Copying signatures
[ 0.1288 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1317 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1318 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1318 ] Boot Rom communication
[ 0.1324 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1329 ] BR_CID: 0x80012344705E015B8000000016FE81C0
[ 0.1604 ] Sending bct_br
[ 0.2036 ] Sending mb1
[ 0.2042 ] Sending psc_bl1
[ 0.2169 ] Sending bct_mb1
[ 0.2234 ] Boot Rom communication completed
[ 0.2269 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.2311 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.2330 ] adding BCH for applet_t234_aligned.bin
[ 0.2482 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2484 ] Assuming zero filled SBK key
[ 0.2519 ] Warning: pub_key.key is not found
[ 0.2542 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.2606 ] Sending mb2_applet...
[ 0.2618 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.2626 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[ 0.4476 ] Sending applet
[ 0.5451 ] completed
[ 0.5459 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.5465 ] MB2 Applet version 01.00.0000
[ 0.7354 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7378 ] MB2 Applet version 01.00.0000
[ 0.7663 ] Parsing fuse info as per xml file
[ 0.7682 ] tegraparser_v2 --chip 0x23 0 --get_fuse_names fuse_t234.xml read_fuse_names.txt
[ 0.7698 ] MagicId=0x45535546 version=0x2
[ 0.7701 ] trying to read fuse with MB2 Applet
[ 0.7719 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PublicKeyHash read_fuse.bin
[ 0.7762 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.7781 ] MB2 Applet version 01.00.0000
[ 0.8497 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.8554 ] Fuse read successful
[ 0.8570 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash1 read_fuse.bin
[ 0.8582 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.8588 ] MB2 Applet version 01.00.0000
[ 0.9459 ] Saved read fuses in file __fuse_read_scatter.bin
[ 0.9518 ] Fuse read successful
[ 0.9551 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash2 read_fuse.bin
[ 0.9594 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 0.9607 ] MB2 Applet version 01.00.0000
[ 1.0383 ] Saved read fuses in file __fuse_read_scatter.bin
[ 1.0439 ] Fuse read successful
[ 1.0456 ] tegraparser_v2 --chip 0x23 0 --read_fusetype BootSecurityInfo read_fuse.bin
[ 1.0471 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 1.0477 ] MB2 Applet version 01.00.0000
[ 1.1231 ] Saved read fuses in file __fuse_read_scatter.bin
[ 1.1289 ] Fuse read successful
[ 1.1330 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ArmJtagDisable read_fuse.bin
[ 1.1371 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 1.1385 ] MB2 Applet version 01.00.0000
[ 1.2104 ] Saved read fuses in file __fuse_read_scatter.bin
[ 1.2161 ] Fuse read successful
[ 1.2184 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SecurityMode read_fuse.bin
[ 1.2202 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 1.2208 ] MB2 Applet version 01.00.0000
[ 1.2938 ] Saved read fuses in file __fuse_read_scatter.bin
[ 1.2997 ] Fuse read successful
[ 1.3030 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SwReserved read_fuse.bin
[ 1.3068 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 1.3080 ] MB2 Applet version 01.00.0000
[ 1.3819 ] Saved read fuses in file __fuse_read_scatter.bin
[ 1.3875 ] Fuse read successful
[ 1.3893 ] tegraparser_v2 --chip 0x23 0 --read_fusetype DebugAuthentication read_fuse.bin
[ 1.3905 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 1.3910 ] MB2 Applet version 01.00.0000
[ 1.4783 ] Saved read fuses in file __fuse_read_scatter.bin
[ 1.4841 ] Fuse read successful
[ 1.4883 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmInfo read_fuse.bin
[ 1.4921 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 1.4935 ] MB2 Applet version 01.00.0000
[ 1.5660 ] Saved read fuses in file __fuse_read_scatter.bin
[ 1.5718 ] Fuse read successful
[ 1.5739 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmId read_fuse.bin
[ 1.5761 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 1.5769 ] MB2 Applet version 01.00.0000
[ 1.6507 ] Saved read fuses in file __fuse_read_scatter.bin
[ 1.6562 ] Fuse read successful
[ 1.6590 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmLock read_fuse.bin
[ 1.6622 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 1.6635 ] MB2 Applet version 01.00.0000
[ 1.7380 ] Saved read fuses in file __fuse_read_scatter.bin
[ 1.7440 ] Fuse read successful
[ 1.7477 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm0 read_fuse.bin
[ 1.7514 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 1.7528 ] MB2 Applet version 01.00.0000
[ 1.8259 ] Saved read fuses in file __fuse_read_scatter.bin
[ 1.8318 ] Fuse read successful
[ 1.8359 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm1 read_fuse.bin
[ 1.8402 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 1.8417 ] MB2 Applet version 01.00.0000
[ 1.9138 ] Saved read fuses in file __fuse_read_scatter.bin
[ 1.9196 ] Fuse read successful
[ 1.9232 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm2 read_fuse.bin
[ 1.9273 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 1.9287 ] MB2 Applet version 01.00.0000
[ 2.0060 ] Saved read fuses in file __fuse_read_scatter.bin
[ 2.0117 ] Fuse read successful
[ 2.0135 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm3 read_fuse.bin
[ 2.0147 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 2.0152 ] MB2 Applet version 01.00.0000
[ 2.1027 ] Saved read fuses in file __fuse_read_scatter.bin
[ 2.1084 ] Fuse read successful
[ 2.1125 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm4 read_fuse.bin
[ 2.1163 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 2.1178 ] MB2 Applet version 01.00.0000
[ 2.1899 ] Saved read fuses in file __fuse_read_scatter.bin
[ 2.1956 ] Fuse read successful
[ 2.1975 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm5 read_fuse.bin
[ 2.1989 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 2.1995 ] MB2 Applet version 01.00.0000
[ 2.2739 ] Saved read fuses in file __fuse_read_scatter.bin
[ 2.2795 ] Fuse read successful
[ 2.2814 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm6 read_fuse.bin
[ 2.2827 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 2.2832 ] MB2 Applet version 01.00.0000
[ 2.3581 ] Saved read fuses in file __fuse_read_scatter.bin
[ 2.3639 ] Fuse read successful
[ 2.3679 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm7 read_fuse.bin
[ 2.3714 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 2.3722 ] MB2 Applet version 01.00.0000
[ 2.4465 ] Saved read fuses in file __fuse_read_scatter.bin
[ 2.4523 ] Fuse read successful
[ 2.4560 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Sku read_fuse.bin
[ 2.4599 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 2.4613 ] MB2 Applet version 01.00.0000
[ 2.5341 ] Saved read fuses in file __fuse_read_scatter.bin
[ 2.5397 ] Fuse read successful
[ 2.5415 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Uid read_fuse.bin
[ 2.5427 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 2.5433 ] MB2 Applet version 01.00.0000
[ 2.6181 ] Saved read fuses in file __fuse_read_scatter.bin
[ 2.6239 ] Fuse read successful
[ 2.6261 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OptEmcDisable read_fuse.bin
[ 2.6279 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 2.6287 ] MB2 Applet version 01.00.0000
[ 2.7026 ] Saved read fuses in file __fuse_read_scatter.bin
[ 2.7084 ] Fuse read successful
[ 2.7127 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 2.7147 ] MB2 Applet version 01.00.0000
[ 2.7444 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 2.7459 ] MB2 Applet version 01.00.0000
[ 2.7920 ] Retrieving board information
[ 2.7934 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 2.7946 ] MB2 Applet version 01.00.0000
[ 2.8377 ] Saved platform info in chip_info.bin
[ 2.8431 ] Chip minor revision: 1
[ 2.8432 ] Bootrom revision: 0x7
[ 2.8432 ] Ram code: 0x3
[ 2.8433 ] Chip sku: 0xd5
[ 2.8433 ] Chip Sample: prod
[ 2.8442 ] Retrieving EEPROM data
[ 2.8442 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 2.8449 ] MB2 Applet version 01.00.0000
[ 2.8904 ] Saved platform info in /home/ontrak/Workspace/Ref/Platforms/Nvidia/Jetson/SDK/install/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 2.9258 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 2.9268 ] MB2 Applet version 01.00.0000
[ 2.9547 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 2.9555 ] MB2 Applet version 01.00.0000
[ 3.0017 ] Dumping customer Info
[ 3.0029 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 3.0038 ] MB2 Applet version 01.00.0000
[ 3.0498 ] 0000000054220302: E> NV3P_SERVER: Failed to get address for br bct from nv3p helper.
[ 3.1282 ]
[ 3.1282 ]
[ 3.1282 ] Error: try getting custinfo fail. Moving on
[ 3.1284 ] Rebooting to recovery mode
[ 3.1314 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 3.1645 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 3.1660 ] MB2 Applet version 01.00.0000
[ 3.2112 ] Booting to recovery mode
[ 3.2144 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 3.2161 ] MB2 Applet version 01.00.0000
Board ID(3767) version(301) sku(0003) revision(F.1)
Preset RAMCODE is 3
Chip SKU(00:00:00:D5) ramcode(3) fuselevel(fuselevel_production) board_FAB(301)
emc_opt_disable_fuse:(0)
Error: missing cfgfile ().
Usage: sudo ./flash.sh [options] generic internal
options:
-c <cfgfile> ---------- Flash partition table config file.
-d <dtbfile> ---------- device tree file.
-f <flashapp> --------- Path to flash application (tegraflash.py)
-h -------------------- print this message.
-i <enc rfs key file>-- key for disk encryption support.
-k <partition id> ----- partition name or number specified in flash.cfg.
-m <mts preboot> ------ MTS preboot such as mts_preboot_si.
-n <nfs args> --------- Static nfs network assignments
<Client IP>:<Server IP>:<Gateway IP>:<Netmask>
-o <odmdata> ---------- ODM data.
-r -------------------- skip building and reuse existing system.img.
-t <tegraboot> -------- tegraboot binary such as nvtboot.bin
-u <PKC key file>------ PKC key used for odm fused board.
-v <SBK key file>------ Secure Boot Key (SBK) key used for ODM fused board.
-w <wb0boot> ---------- warm boot binary such as nvtbootwb0.bin
-x <tegraid> ---------- Tegra CHIPID.
-B <boardid> ---------- BoardId.
-C <cmdline> ---------- Kernel commandline arguments.
WARNING:
Each option in this kernel commandline gets
higher preference over the values set by
flash.sh. In case of NFS booting, this script
adds NFS booting related arguments, if -i option
is omitted.
-F <flasher> ---------- Flash server such as cboot.bin.
-G <file name> -------- Read partition and save image to file.
-I <initrd> ----------- initrd file. Null initrd is default.
-K <kernel> ----------- Kernel image file such as zImage or Image.
-L <bootloader> ------- Bootloader such as cboot.bin or u-boot-dtb.bin.
-M <mts boot> --------- MTS boot file such as mts_si.
-N <nfsroot> ---------- i.e. <my IP addr>:/my/exported/nfs/rootfs.
-R <rootfs dir> ------- Sample rootfs directory.
-S <size> ------------- Rootfs size in bytes. Valid only for internal
rootdev. KiB, MiB, GiB short hands are allowed,
for example, 1GiB means 1024 * 1024 * 1024 bytes.
-T <ext num sectors> ---The number of the sectors of the external storage device.
The default value is 119537664 if this option is not set.
-U <int num sectors> ---The number of the sectors of the internal storage device.
-Z -------------------- Print configurations and then exit.
--no-flash ------------ perform all steps except physically flashing the board.
This will create a system.img.
If combined with --rcm-boot, the command will generate rcmboot_blob.
--external-device------ Generate flash images for external devices
--sparseupdate--------- only flash partitions that have changed. Currently only support SPI flash memory
--no-systemimg -------- Do not create or re-create system.img.
--bup ----------------- Generate bootloader update payload(BUP).
--single-image-bup <part name> Generate specified single image BUP, this must work with --bup.
--bup-type <type> ----- Generate specific type bootloader update payload(BUP), such as bl or kernel.
--multi-spec----------- Enable support for building multi-spec BUP.
--clean-up------------- Clean up BUP buffer when multi-spec is enabled.
--usb-instance <id> --- Specify the USB instance to connect to;
<id> = USB port path (e.g. 3-14).
--no-root-check ------- Typical usage of this script require root permissions.
Pass this option to allow running the script as a
regular user, in which case only specific combinations
of command-line options will be functional.
--uefi-keys <keys_conf> Specify UEFI keys configuration file.
--rcm-boot ------------ Do RCM boot instead of physically flashing the board.
--sign ---------------- Sign images and store them under "bootloader/signed"
directory. The board will not be physically flashed.
--image --------------- Specify the image to be written into board.
--boot-chain-flash <c> Flash only a specific boot chain (ex. "A, "B", "all").
Defaults to "all", inputs are case insensitive.
Not suitable for production.
--boot-chain-select <c> Specify booting chain (ex. "A" or "B") after the board is flashed.
Defaults to "A", inputs are case insensitive.
--pv-crt -------------- The certificate for the key that is used to sign cpu_bootloader
--with-systemimg ------ Generate system images also when using -k option
--pv-enc <enc_key>----- The encryption key that is used to encrypt cpu_bootloader.
--uefi-enc <uefi_enc_key> Key file (0x19: 16-byte; 0x23: 32-byte) to encrypt UEFI payloads
--uda-dir-------------- Directory to store user data that will be encrypted in UDA partition.
--generic-passphrase -- Use generic passphrase for disk encryption.
--disable-random-iv --- Disable generation of random IV, SALT1, SALT2 and DERSTR.
--read-info ----------- Read and display board related info, fuse info (based on fuse_t234.xml),
and EEPROM content.
--reuse-uuid --------- Reuse uuid which is already generated first time.
--qspi-only --------- Flash QSPI device only.
--gen-rcmdump -------- Generate rcmdump_blob
Error: failed to generate images
Cleaning up...
