sample_radar_replay sample in DriveWorks 1.2 has an below error
could you have a solution for this?
nvidia@tegra-ubuntu:/usr/local/driveworks/bin$ ./sample_radar_replay --protocol=radar.socket --params=device=DELPHI_ESR2_5,ip=169.254.145.71,port=5555
[23-10-2018 20:41:32] Initialize DriveWorks SDK v1.2.400
[23-10-2018 20:41:32] Release build with GNU 4.9.4 from v1.2.0-rc11-0-ga7f5475 against Vibrante PDK v5.0.10.3
[23-10-2018 20:41:32] Platform: Detected Drive PX2 - Tegra A
[23-10-2018 20:41:32] TimeSource: monotonic epoch time offset is 1540006658047648
[23-10-2018 20:41:32] TimeSource: PTP ioctl returned error. Synchronized time will not be available.
[23-10-2018 20:41:32] TimeSource: Could not detect valid PTP time source at ‘eth0’. Fallback to CLOCK_MONOTONIC.
[23-10-2018 20:41:32] Platform: number of GPU devices detected 1
[23-10-2018 20:41:32] Platform: currently selected GPU device integrated ID 0
[23-10-2018 20:41:32] SDK: Resources mounted from …/./data/resources
[23-10-2018 20:41:32] SDK: Create NvMediaDevice
[23-10-2018 20:41:32] SDK: Create NvMediaIPPManager
[23-10-2018 20:41:32] SDK: use EGL display as provided
[23-10-2018 20:41:32] SensorFactory::createSensor() → radar.socket, device=DELPHI_ESR2_5,ip=169.254.145.71,port=5555
[23-10-2018 20:41:32] RadarSocket::RadarSocket, connected to 169.254.145.71:5555
[23-10-2018 20:41:32] DecoderDelphi: invalid scan type received
[23-10-2018 20:41:33] DecoderDelphi: invalid scan type received
According to the log, DecoderDelphi: invalid scan type received
Could you help to check if your radar is a Delphi product?
And were there any problems in DriveWorks 0.6?
I’m using Delphi ESR2.5(24V), but not work…
The commands and results are below.
The view is displayed, but not ploted and “Packets” displayed in the view is zero.
./sample_radar_replay --protocol=radar.socket --params=ip=192.168.1.11,port=5555,device=DELPHI_ESR2_5
[29-10-2018 23:3:37] Initialize DriveWorks SDK v1.2.400
[29-10-2018 23:3:37] Release build with GNU 4.9.4 from v1.2.0-rc11-0-ga7f5475 against Vibrante PDK v5.0.10.3
[29-10-2018 23:3:37] Platform: Detected Drive PX2 - Tegra A
[29-10-2018 23:3:37] TimeSource: monotonic epoch time offset is 1540876231301103
[29-10-2018 23:3:37] TimeSource: PTP ioctl returned error. Synchronized time will not be available.
[29-10-2018 23:3:37] TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[29-10-2018 23:3:37] Platform: number of GPU devices detected 1
[29-10-2018 23:3:37] Platform: currently selected GPU device integrated ID 0
[29-10-2018 23:3:37] SDK: Resources mounted from .././data/resources
[29-10-2018 23:3:37] SDK: Create NvMediaDevice
[29-10-2018 23:3:37] SDK: Create NvMediaIPPManager
[29-10-2018 23:3:37] SDK: use EGL display as provided
[29-10-2018 23:3:37] SensorFactory::createSensor() -> radar.socket, ip=192.168.1.11,port=5555,device=DELPHI_ESR2_5
[29-10-2018 23:3:37] RadarSocket::RadarSocket, connected to 192.168.1.11:5555
Do you know what causes this error and how to fix it?
Thank you for your response, Can you clarify if the Delphi ESR 2.5 12 VDC Radars will work with DW? Does the Continental ARS408 radar work with DW. We are using the Nvidia PX2 and were told from Autonomousstuff that the ESR 2.5 24VDC worked with this system so no we are back tracking to see what sensors actually work since we were steered in the wrong direction initially.
Please refer to “Supported Sensors” in DriveWorks doc.
DriveWorks SDK Reference → Development Guide → Sensor Abstraction Layer → Sensors.
Supported Sensors
The following list shows the sensors that DriveWorks supports. For the most up-to-date information on supported sensors, see the Release Notes.
GMSL Cameras (NVIDIA DRIVE™ platform only)
Omnivision OV10635
Omnivision OV10640
Sekonix AR0231 (RGGB, RCCB sensors) USB Camera
Any Video4Linux supported devices PointGrey USB Cameras
Chameleon CM3-U3-31S4C-CS (Color sensor)
Chameleon CM3-U3-50S5M-CS (Mono sensor)
Grasshopper GS3-U3-50S5C-C (Color sensor) Stereo Camera
ZED CAN Bus
SocketCAN
Aurix Easy CAN GPS
Any NMEA-compatible sensor using a serial UART
Xsens MTi-G-700 (serial based NMEA protocol + USB proprietary)
Garmin 18x
NovAtel dGPS Lidar
Quanergy M8
IBEO Lux
Velodyne (VPL16, HDL32E, HDL 64-S3) Radar
Continental ARS430 ethernet protocol
Continetal ARS430 CAN protocol
Delphi_ESR_2.5 IMU
Xsens MTi-G-700 (serial based NMEA Protocol + USB proprietary)
