I flashed my jetson with the jetpack 3.1 and followed the deepstream instructions.
I’m getting the following errors when testing the installation:
nvgstiva-app -c ${HOME}/configs/PGIE-FP16-CarType-CarMake-CarColor.txt
(gst-plugin-scanner:10049): GStreamer-WARNING **: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcaffegie.so’: libnvcaffe_parser.so.3: cannot open shared object file: No such file or directory
(gst-plugin-scanner:10049): GStreamer-WARNING **: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvtracker.so’: libvisionworks.so: cannot open shared object file: No such file or directory
Failed to connect to Mir: Failed to connect to server socket: No such file or directory
Unable to init server: Could not connect: Connection refused
(gst-plugin-scanner:10049): Clutter-CRITICAL **: Unable to initialize Clutter: Could not initialize Gdk
(gst-plugin-scanner:10049): Clutter-Gst-CRITICAL **: Unable to initialize Clutter
** ERROR: <create_secondary_gie:105>: Failed to create ‘secondary_gie_0’
** ERROR: <create_secondary_gie:235>: create_secondary_gie failed
** ERROR: <create_secondary_gie_bin:364>: create_secondary_gie_bin failed
** ERROR: <create_processing_instance:890>: create_processing_instance failed
** ERROR: <create_pipeline:1024>: create_pipeline failed
** ERROR: main:384: Failed to create pipeline
Quitting
App run failed
