• Hardware Platform (Jetson / GPU) GPU 2080 Ti
• DeepStream Version 6.0.0
• TensorRT Version 8.2.0
• NVIDIA GPU Driver Version (valid for GPU only) 470.182
• Issue Type( questions, new requirements, bugs) questions, bugs
I have two situation to do face detection on stream. The first one does not stop at the end of the stream while the second one does that correctly.
First Situation:
I am using this awesome repository - runtime_source_add_delete- to add or remove stream meanwhile running time. Also to utilize in specific problem face detection I change some functionality of this code (for example commenting this line:
g_timeout_add_seconds (15, add_sources, (gpointer) g_source_bin_list); .
Second Situation:
In addition to it I add brings extra functions to do face detection job. When I run it, it start correctly but it never stops at the end of the video stream.
In spite of it, when I run face detection project that utilized another functions like
decodebin_child_added()
cb_newpad()
It stops successfully.
First Situation:
To running project I should send you face detection engine, tracker file and configs. Also I upload output log.
main_first_situation.cpp (44.7 KB)
Output (3.8 KB)
Second Situation:
main_second_situation.cpp (67.0 KB)
