Description
Running sample graph reference app test1 from the below URL fails on Jetson NX device.
The error is :
2021-10-31 17:20:02,284 - Registry - INFO - Installing graph ...
2021-10-31 17:20:02,372 - Registry - ERROR - Failed to find extension: NvDsBaseExt version: 0.0.4
2021-10-31 17:20:02,373 - Registry - ERROR - Failed to find dependencies
2021-10-31 17:20:02,373 - Registry - ERROR - Failed to find extensions for manifest from graphs ['/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/deepstream-test1/deepstream-test1.yaml']
Failed to install graph with output directory
Environment
TensorRT Version: 8.0.1.6-1+cuda10.2
GPU Type: Jetson Xavier NX Developer Kit GPU
Nvidia Driver Version: Cannot find it but it should be the one with the OS image of NX developer kit
CUDA Version: 10.2
CUDNN Version: 8.2.1.32-1+cuda10.2
Operating System + Version: Ubuntu 18.04.5 LTS
Python Version (if applicable): 2.7.17
TensorFlow Version (if applicable): N/A
PyTorch Version (if applicable): N/A
Baremetal or Container (if container which image + tag): Baremetal Jetson Xavier NX Developer Kit
Relevant Files
I am using OOTB files from DeepStream SDK 6 and graph composer reference apps.
Steps To Reproduce
- Fresh install of Xavier NX with JetPack 4.6
- Install
libgstrtspserver-1.0-0as it is a prerequisite for DeepStream SDK 6 - Install DeepStream SDK 6
- Install Graph Composer runtime for Jetson
- Install Graph Composer reference apps
- Run the below:
cd /opt/nvidia/deepstream/deepstream-6.0/reference_graphs/deepstream-test1/
/opt/nvidia/graph-composer/execute_graph.sh deepstream-test1.yaml parameters.yaml -d ../common/target_aarch64.yaml
