Hello I am very new to Jetson and am trying to write a graph composer app that takes in an rtsp stream and just displays to the screen on the Jetson. I am getting the following error on the gxf_server when I try to run my graph.
2024-01-26 15:01:18.081 ERROR gxf/std/extension_loader.cpp@114: Failed to load extension /tmp/gxf_281473226890512/deepstream/nvdsinterface/libgxf_nvdsinterface.so Error: /tmp/gxf_281473226890512/deepstream/nvdsinterface/libgxf_nvdsinterface.so: cannot open shared object file: No such file or directory
2024-01-26 15:01:18.082 ERROR gxf/gxe/gxe.cpp@242: LoadExtensionManifest Error: GXF_EXTENSION_FILE_NOT_FOUND
• DeepStream Version
• TensorRT Version
Jetson AGX Orin developer kit
6.3
5.1.2.b104
• TensorRT Version
8.5.2-1 + cuda11.4
Question
It happens every time I try to run any graph. I have been trying to run deepstream-test2
Can you follow the steps in this post to run the sampel graph How to run Graph Composer and check deepstream version post JP 6.0 Flash & GC install - #3 by Fiona.Chen? Even the steps are for DeepStream 6.4 and Graph Composer 3.1.0, the same as DeepStream 6.3 and Graph Composer 3.0.0
Please make sure you run all the steps with root.
