Unable to use NvDsAnalytics in graph composer
• Jetson nano
• DeepStream Version - 6.0.1
• JetPack Version - 4.6.1
• TensorRT Version - 8.2.1-1+cuda10.2
**• When running thefollowing graph composer
deepstream-test2.yaml (7.0 KB)
The following Error appears:
Can you use “reistry extn list” to check whether NvDsAnalyticsExt is registered correctly?
The NvDsAnalyticsExt is registered correctly as you can see in the output of the command:
