Remote machine setup:
• Jetson nano
• DeepStream Version - 6.0.1
• JetPack Version - 4.6.1
• TensorRT Version - 8.2.1-1+cuda10.2
When runing graph composer 2.0.1 on windows to Remote Machine the followind erros occurs:
Seems the extensions in the remote device are not sync correctly.
Please make sure the extensions have been sync in the remote device.
I have used this commands to set up graph composer on the jetson:
wget https://developer.download.nvidia.com/assets/Deepstream/DeepStream_6.0.1/graph_composer-1.0.0_arm64.deb
sudo dpkg -i graph_composer-1.0.0_arm64.deb
registry repo sync -n ngc-public
Output of the console after syncing repository:
2022-12-21 10:50:05,203 - Registry - INFO - Syncing repo ngc-public …
2022-12-21 10:50:08,230 - Registry - INFO - 28 extensions found
2022-12-21 10:50:09,109 - Registry - INFO - Syncing extension NvDsBaseExt version 0.0.4
2022-12-21 10:50:23,147 - Registry - INFO - Syncing extension NvDsBaseExt version 0.0.3
2022-12-21 10:50:41,349 - Registry - INFO - Syncing extension NvDsAnalyticsExt version 0.0.3
2022-12-21 10:50:55,741 - Registry - INFO - Syncing extension NvDsCloudMsgExt version 0.0.3
2022-12-21 10:51:11,747 - Registry - INFO - Syncing extension NvDsConverterExt version 0.0.3
2022-12-21 10:51:27,069 - Registry - INFO - Syncing extension NvDsDewarperExt version 0.0.4
2022-12-21 10:51:42,746 - Registry - INFO - Syncing extension NvDsInferenceExt version 0.0.4
2022-12-21 10:51:58,262 - Registry - INFO - Syncing extension NvDsInferenceExt version 0.0.3
2022-12-21 10:52:14,886 - Registry - INFO - Syncing extension NvDsInferenceUtilsExt version 0.0.5
2022-12-21 10:52:30,323 - Registry - INFO - Syncing extension NvDsInferenceUtilsExt version 0.0.4
2022-12-21 10:52:46,871 - Registry - INFO - Syncing extension NvDsInterfaceExt version 0.0.3
2022-12-21 10:53:03,356 - Registry - INFO - Syncing extension NvDsMuxDemuxExt version 0.0.4
2022-12-21 10:53:20,585 - Registry - INFO - Syncing extension NvDsOpticalFlowExt version 0.0.3
2022-12-21 10:53:37,471 - Registry - INFO - Syncing extension NvDsOutputSinkExt version 0.0.3
2022-12-21 10:53:57,124 - Registry - INFO - Syncing extension NvDsSampleExt version 0.0.3
2022-12-21 10:54:15,296 - Registry - INFO - Syncing extension NvDsSampleModelsExt version 0.0.4
2022-12-21 10:54:35,992 - Registry - INFO - Syncing extension NvDsSourceExt version 0.0.6
2022-12-21 10:55:00,018 - Registry - INFO - Syncing extension NvDsTemplateExt version 0.0.3
2022-12-21 10:55:20,825 - Registry - INFO - Syncing extension NvDsTrackerExt version 0.0.3
2022-12-21 10:55:41,593 - Registry - INFO - Syncing extension NvDsTranscodeExt version 0.0.3
2022-12-21 10:56:03,424 - Registry - INFO - Syncing extension NvDsTritonExt version 0.0.3
2022-12-21 10:56:25,008 - Registry - INFO - Syncing extension NvDsVisualizationExt version 0.0.3
2022-12-21 10:56:47,888 - Registry - INFO - Syncing extension StandardExtension version 1.0.1
2022-12-21 10:57:15,897 - Registry - INFO - Syncing extension NvDsBodyPose2D version 0.0.4
2022-12-21 10:57:37,690 - Registry - INFO - Syncing extension NvDsBodyPose2D version 0.0.3
2022-12-21 10:58:00,242 - Registry - INFO - Syncing extension NvDsFacialLandmarks version 0.0.7
2022-12-21 10:58:22,168 - Registry - INFO - Syncing extension NvDsFacialLandmarks version 0.0.4
2022-12-21 10:58:44,976 - Registry - INFO - Syncing extension NvDsEmotionExt version 0.0.5
2022-12-21 10:59:06,767 - Registry - INFO - Syncing extension NvDsEmotionExt version 0.0.4
2022-12-21 10:59:28,741 - Registry - INFO - Syncing extension NvDsEmotionExt version 0.0.3
2022-12-21 10:59:51,652 - Registry - INFO - Syncing extension NvDsGazeExt version 0.0.5
2022-12-21 11:00:13,538 - Registry - INFO - Syncing extension NvDsGazeExt version 0.0.4
2022-12-21 11:00:35,530 - Registry - INFO - Syncing extension NvDsGazeExt version 0.0.3
2022-12-21 11:00:58,289 - Registry - INFO - Syncing extension NvDsHeartRateExt version 0.0.3
2022-12-21 11:01:24,230 - Registry - INFO - Syncing extension MultimediaExtension version 1.0.0
2022-12-21 11:01:47,909 - Registry - INFO - Syncing extension NvDsGesture version 0.0.3
2022-12-21 11:02:12,825 - Registry - INFO - Syncing extension NvDsGesture version 0.0.2
2022-12-21 11:02:35,840 - Registry - INFO - Syncing extension NvDsActionRecognitionExt version 0.0.1
Repository synced
