Hi, I’m trying to run one of DeepStream-6.1 samples with a Pylon GigE camera as the source.
I followed this link “Quickstart Guide — DeepStream 6.1.1 Release documentation ” to install DeepStream and I can successfully run a sample pipeline on one of the prerecorded videos.
I have also Installed a Pylon plugin from “GitHub - joshdoe/gst-plugins-vision: GStreamer plugins related to the field of machine vision ” for Gstreamer before, and it works fine.
How can I get the DeepStream to work with the camera now? I want to be able to add the pylonsrc instead of CAmeraV4L2 in the config files:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=0
• Hardware Platform (Jetson / GPU) NVIDIA GeForce RTX 3070
• DeepStream Version 6.1
• TensorRT Version 8.4.3
• NVIDIA GPU Driver Version (valid for GPU only) 11.7
• Issue Type( questions, new requirements, bugs) questions
deepstream-app is just a sample app, it is totally open source, you can modify the code to add the new source type. Please refer to /opt/nvidia/deepstream/deepstream/sources/apps/
Thank you for your response. Could you please give me a bit more details? I have no idea what to modify and how.
Thank you
Update: I tried this repo (GitHub - NVIDIA-AI-IOT/deepstream-yolo3-gige-apps: A project demonstration on how to use the GigE camera to do the DeepStream Yolo3 object detection, how to set up the GigE camera, and deployment for the DeepStream apps. · GitHub ) to write an app that works with GigE cameras, it uses Aravis plugin for GigE cameras and the plugin works with GStreamer however I get the following error with both plugins (Aravis and the one here GitHub - joshdoe/gst-plugins-vision: GStreamer plugins related to the field of machine vision · GitHub ):
Could not create 'src_elem'
Failed to create source bin. Exiting
The following lines cause this error:
//create a source for ARAVIS SDK
GstElement *src_elem = gst_element_factory_make ("aravissrc", "src_elem");
if (!src_elem)
g_printerr ("Could not create 'src_elem'\n");
return NULL;
I found another topic with the exact same problem:
I’m trying to record a video using a PoE camera on a Jetson Xavier AGX. To do this I’m trying to use Aravis and Deepstream(5.1 version). To do this a pipeline is created. I have a cloned repository in “/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-yolo3-gige-apps/”. When I try to run the code I get the following error:
Failed to create source bin. Exiting.
I believe that this happens because deepstream is not being able to create the…
How much do you know about gstreamer?( GStreamer: open source multimedia framework ). It is just to add a new source which is a very common gstreamer usage.
joshdoe/gst-plugins-vision: GStreamer plugins related to the field of machine vision (github.com) is third party open source projects, please ask the owner for help.
