I would like to use a camera with the GigE Vision protocol (i.e. Basler acA 1920-40gc) for the object detection based on DeepStream and YOLOv3. At present, the camera runs on the Jetson AGX Xavier.
I wonder how to modify the file deepstream_app_config_yoloV3.txt so that the data of the camera can be used as the input data of the DeepStream. The following configuration cannot ensure that the camera operates in the DeepStream:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
#uri=file://../../samples/streams/sample_1080p_h264.mp4
uri=udp://219.216.101.5
num-sources=1
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
Any helps is welcomed.
