[DeepStream6.1] Build Error: gesture_recognition_tlt_deepstream
I’v already run below github project with JetPack4.5.1 and Deepstream5.1 on Jetson Xavier NX.
And I try to run below github project with JetPack5.0.1 and Deepstream6.1 on Jetson Xavier NX.
But we found errors like below;
I also check below migration guides.
But it seems not to be clue about this Error.
Question:
Are there anyone success to run this github project with JetPack5.0.1 and Deepstream6.1 on JetsonNX?
I also try to build by commented out like below;
// case NV_DS_SINK_RENDER_OVERLAY:
Build Error was not found.
But we found another Error by running “deepstream-app-bbox” like below;
We would appreciate if you tell us how to solve this issue.
Best regards,
Can you find nvinferserver plugin?
gst-inspect-1.0 nvinferserver
Thank you for your kindness.
I’d like to check it.
Best regards,
I’d like to share the result.
nvinferserver is not found.
inf
You may try in DS 6.1 triton docker to run the app.
Thank you very much for your kindness.
I really appreciate your help.
I’d like to continue to check the behavior with your guide.
Best regards,
