"Deformable body (deprecated)" was deprecated in version 5.0.0
Isaac Sim Version
[√] 5.0.0
Operating System
[√]Ubuntu 22.04
GPU Information
  • Model: Geforce RTX5080
  • Driver Version: 575.64
Topic Description
Detailed Description
I want to create a mold similar to a phone screen protector, so it needs to be made of a slightly soft material. However, in version 5.0.0, it shows “(deprecated),” and I’m not sure if this affects its use. Although I still use it, an “air wall” issue occurs. How should I adjust it? This problem appears even in the simplest scene (cube, ground).
Steps to Reproduce
Using the Isaac Sim UI
  1. Create →Physics→Ground Plane
  2. Create →Mesh→Cube(Add→Physics→Deformable Body)
  3. Play
You can observe an “air wall” between the ground and the cube.
Screenshots or Videos
Additional Information
NO
Does this always repro for you? I didn’t see the issue following your repro steps.
Yes, it happens every time, and you can observe it by checking the Z-axis. So, does the “(deprecated)” status of deformable body mean it does not affect functionality? Additionally, I tested in three environments: RTX 3070 Ti with driver 550.163, RTX 5080 with driver 575.64, and RTX 5090 with driver 570.172, and the issue occurs in all of them. Below is the model we tested, from which you can see that the issue does not occur with rigid body but does occur with deformable body.
File: Issac sim - Google Drive
Can you try the new Deformables Beta feature in 5.0.0?
  • Deformables Beta
  • PhysX supports a new schema for volume and surface deformables, replacing current particle cloth and deformable body functionality. The beta feature set can be enabled in the physics preferences:
  • Edit → Preferences → Physics → General → Enable Deformable Schema Beta (Requires Restart)
Of course, I’m very excited about the new Deformables Beta. I followed the tutorial to enable this feature and reloaded the stage, but I couldn’t find anything about the volume deformable body. Additionally, using the surface deformable body results in an error and cannot be used.
Could I have missed something? Or is there any tutorial for the new Deformables Beta that I can refer to?
Thank you!
The error means that the mesh assigned as a surface for a deformable body contains polygons that are not triangles. Isaac Sim (and PhysX) requires that meshes used for deformable body simulation consist entirely of triangles, not quads or other polygons.
You can find more information and tutorials at Deformable Bodies
