Hi everyone!
I am trying to define a deformable body using a custom mesh. However, after I add the deformable body configuration, Isaac-Sim is shut down with the following error messages:
2022-08-31 01:21:32 [81,856ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 24076 backtrace follows:
2022-08-31 01:21:32 [81,856ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: omni.physx.plugin.dll!carbOnPluginStartup+0x1f3eed
2022-08-31 01:21:32 [81,856ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: omni.physx.plugin.dll!carbOnPluginStartup+0x1f7eb1
2022-08-31 01:21:32 [81,856ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: omni.physx.plugin.dll!carbOnPluginStartup+0x1f6911
2022-08-31 01:21:32 [81,856ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: omni.physx.plugin.dll!carbOnPluginStartup+0x1ab603
2022-08-31 01:21:32 [81,856ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: omni.physx.plugin.dll!carbOnPluginStartup+0x2502
2022-08-31 01:21:32 [81,856ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: omni.physx.plugin.dll!carbOnPluginStartup+0x3dec8
2022-08-31 01:21:32 [81,858ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: carb.tasking.plugin.dll!+0x17a3d
2022-08-31 01:21:32 [81,858ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: carb.tasking.plugin.dll!+0x10179
2022-08-31 01:21:32 [81,858ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: carb.tasking.plugin.dll!+0x101a9
2022-08-31 01:21:32 [81,859ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: KERNELBASE.dll!GetCommandLineA+0x4b
2022-08-31 01:21:32 [81,859ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: ntdll.dll!RtlUserFiberStart+0x24
I attached a scene containing a minimal example and a video. Thank you in advance.
Att
Juan
(I’m usging Isaac-sim 2022.1.1 on Windows 11)
test_deformable_block.usd (4.1 KB)
