Deformable rops is settling sideways even under influence of gravity
Deformable stem is doing one sided swing motion without any input.
Steps to reproduce: USDA file uploaded. Run on Isaac Sim 5.1.0
reproduce_but.zip (5.5 KB)
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model:
  • Driver Version:
The setup is supposed to be of a simple deformable rope hanging via attachment. The lower end of the rope is attached to a dummy invisible rigidbody. This dummy body then connected to a fruit ( sphere ).
When I run the simulation, the rope dangles for a moment then visibly settles/keeps swinging in favour of one sideway direction. Not even back and forth.
Hi @donkumar727,
The sideways settling is caused by asymmetric attachment points on your deformable rope.
The PhysxAutoAttachmentAPI picks collision mesh vertices near the overlap region
between the rope and the connector. Your collision mesh has only 25 vertices (from
collision simplification), and the selected attachment points end up biased to one
side – the bottom attachment center is offset by ~2-4mm from the rope’s axis. With
a 2kg fruit hanging from a thin 0.75m rope, that offset creates enough torque to
pull the rope sideways.
Workarounds (try in order):
  1. Increase simulation resolution: Set physxDeformable:simulationHexahedralResolution to 16 or 32 for a finer, more symmetric tet mesh.
  2. Disable collision simplification: Set physxDeformable:collisionSimplification = 0 so the full mesh is used for attachments, giving more (and more symmetric) vertex candidates.
  3. Increase damping: Raise elasticityDamping from 0.005 to 0.05 or higher to
    dissipate oscillations faster.
  4. Manual attachment: Instead of auto-attachment, define your attachment points manually at symmetric positions around the rope’s center axis.
Hello!
We noticed that this topic hasn’t received any recent updates from anyone reporting this issue, so we are closing it for now to help keep the forum organized.
If you are still experiencing this issue or have related questions, please create a GitHub Discussion or Issue in the Isaac Sim repository and include a link to this topic along with updated details. Mentioning or linking to this original topic provides helpful context and makes it easier for others to assist you.
Best regards,
