Detected Faces Tracker
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• TensorRT Version 8.5.2.2
I’m trying to implement a face detection pipeline in DS which detect faces and then track these faces. I’m a beginner in DS and i want to know if there’s a face track sample or how to use the tracker plugin to track detected faces
There is a sample on face detection (using nvidia FaceDetect model ), but it doesn’t use tracker. You can refer to /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test2 on tracker usage, it is common for object detection models.
Thank you.
Is there a way to use the available .txt file to the detect model? or is it only designed for object tracking?
And can i find any documentation of how to link the tracker to the facedetect model
You can use the config file dstest2_tracker_config.txt in the deepstream-test2.
You may refer to the online doc for tracker: Gst-nvtracker — DeepStream 6.2 Release documentation (nvidia.com)
Is there a way to confirm if the tracker is working well in test-2. I have changed the config file to use face detection model but i couldn’t find a way to check if is it using the tracker or is it processing frame by frame.
Is there a way to find the FPS for test-2?
Yes. You can print the tracker information, please refer to the following structure: NvDsObjectMeta in sources\includes\nvdsmeta.h.
Please refer to the link below: https://forums.developer.nvidia.com/t/deepstream-sdk-faq/80236/12
I couldn’t understand how to use nvsmeta.h to check if tracker is working.
As well is there a way to add the FPS to python examples from deepstream
There are some tracker related variables in NvDsObjectMeta, like NvDsComp_BboxInfo tracker_bbox_info; gfloat tracker_confidence;.
For FPS in python, please refer to the demo code: https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/blob/master/apps/deepstream-test3/deepstream_test_3.py#L35C1-L35C33.
I found that there are 3 different trackers libraries in DS (IOU, NvSORT, NvDFC). Is there a way to observe the difference between them from a sample test video?
Yes. You can change the config file. Please refer to our demo code: sources\apps\sample_apps\deepstream-test2\dstest2_tracker_config.txt.
# ll-config-file required to set different tracker types
# ll-config-file=../../../../samples/configs/deepstream-app/config_tracker_IOU.yml
# ll-config-file=../../../../samples/configs/deepstream-app/config_tracker_NvSORT.yml
ll-config-file=../../../../samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
# ll-config-file=../../../../samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
# ll-config-file=../../../../samples/configs/deepstream-app/config_tracker_NvDeepSORT.yml
yes this part is clear. But is there a way to visualize the effect of using these different trackers from the output of a sample video or the difference is only in the hardware utilization.
No. Please refer to the posted Guide link above for their algorithms and differences.
