Device startup failure
We have a batch of devices delivered to the customer for mass production, several of which cannot be started after use by the customer. The following is the startup log, among which the first log is the normal startup log and the second is the abnormal log. Please help analyze the cause of this situation.
1.log (25.2 KB)
2.log (21.0 KB)
What’s the BSP SW you’re using?
HI, kayccc!
We used the following version of the software.
348629b3ace902b44e01a9057819b8ba
Are you able to reproduce the same issue on DevKits?
How frequently does this issue happen on those malfunctioning devices?
Is it 100%?
The recurrence probability of this device is 100%. We have looked at the log of other devices, and it should not be the same problem as this one. What operation will cause this problem?
我不太懂你這句話的意思,你是說只有這台機器會有問題?
通常custom board遇到硬體問題的話都是kernel panic或是無限重開之類的
如果這台每次開機都卡在同一行的話搞不好是eMMC或是SD卡哪裡壞了,所以開機到那一段剛好讀不到
建議你們先重刷試試看
BTW, due to your SW is R32.5.1 which is very old, I’m not sure if it’s related with some component changes issue if those modules always failed to boot, no matter on devkit carrier board or your custom carrier board.
Could you confirm whether the “Overlay to support Jetson Xavier NX 16GB” package at L4T R32.5.1 Release Page | NVIDIA Developer was integrated on your SW?
We have another machine here that will keep rebooting. Here’s the log.
294_1系统重启.txt (59.5 KB)
Sorry for the late response.
Only this device got it? Reflash device can resolve?
