Xavier NX could not boot up
Hey, two Xavier NX boards 16G EMMC with SSD fail to boot after less than 1 week of use
Not sure what app/program have ran on device, there is no enough info to traige the problem you met. please provide more info, logs or reflash your device to see if can recover them back.
You cana also refer to the debug tips: Debug tips when you hit any issue (fail to boot/ keep reboot …etc) - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
Just an added note: Whenever something goes wrong and you can’t boot (and often even when you can) you would need the serial console log to start. That works even when the GUI is dead, and also works to log boot stage setup. You’d also need to state details about third party carrier boards since they likely get flashed with different software than does the dev kit (the exception being if the carrier board matches the dev kit in electrical layout).
