Subject: Problem while booting the jetson xavier nx
One of my Jetson xavier nx development SOM is booting properly on Nvidia Dev Boards whereas we are facing issues while booting them on our custom boards.
Peripherals like HDMI, USB are working fine in the terminal shown in the image but its not booting up.
I have attached the boot logs in the image below. Please look into it asap.
- You can try to dump the uart log. It will tell more about the issue. The image from monitor does not help.
What is the command to flash the board? What kind of NX module are you using now?
Are you trying to boot from external drive?
