I started the Jetson Xavier NX and the result was a failed startup as shown below.
The baseboard is from the developer kit, but the Jetson Xavier NX module is not the original module from the developer kit, but the emmc version. I have tried to use sdkManager flash device, but neither ubuntu VM nor physical machine recognize Jetson Xavier NX.
Is there any way to fix this problem please?
Do you at least know how to put the device into force recovery mode?
Then do it like:
sudo ./flash.sh jetson-xavier-nx-devkit-emmc internal
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/IN/QuickStart.html
Can you please try a different USB cable?
Like, you cannot use a USB cable that is only capable of charging for flashing.
