I am having issues with a CANFD driver and the device tree relating to SPI. This driver is working fine with a devkit nano, but when I switch to a production nano it fails to initialize.
Can someone provide some insight on how I can fix this? I’m not even sure where to start looking.
Here is the dmesg output:
[8.622392] spi_tegra114p: loading out-of-tree module taints kernel.
[8.637087] tegra210-pinctrl 700008d4.pinmux: pin SPI1_CS1 PC4 already requested
by 700008d4.pinmux; cannot claim for 7000d400.spi
[8.651103] tegra210-pinctrl 700008d4.pinmux: pin-20 (7000d400.spi) status -22
[8.847546] tegra210-pinctrl 700008d4.pinmux: could not request pin 20
(SPI1_CS1 PC4) from group spi1_cs1_pc4 on device 700008d4.pinmux
[8.976207] spi-tegra114p 7000d400.spi: Error applying setting, reverse things back
[8.986613] spi-tegra114p: probe of 7000d400.spi failed with error -22
it’s different board configurations for the DevKits and Production modules.
had you update the pin configuration? you may also access pinmux spreadsheets for reference;
please check developer guide, Configuring the 40-Pin Expansion Header, here’s a python tool, Jetson-IO tool to simplify the configuration
thanks
What pin configuration needs to change? Part of what I’m asking is what needs to change - I have no idea.
I have tried using the jetson-io tool - the instructions are vague and I have no idea what I should be doing with it. I use it to activate the .dtbo for my driver. What else should I do with it?
how about compare the device tree settings to check the difference.
for example, you may disassembler the devkit’s dtb file into text file as following, $ dtc -I dtb -O dts -o devkit.txt tegra210-p3448-0002-p3449-0000-a02.dtb
thanks
