I have rebuilt the NANO with the latest software (JetPack 4.6.1). I did not use the SDK Manager for this.The NANO boots from a USB device without SD-card.
Now when I start jetson-io.py, it aborts right away. I do not see any message.
I need for my project the I2C an SPI Port
Here some information:
Jetson Nano: P3448 A02
Carrier Board: P3449 A02
@Phoenix:~$ ls /proc/device-tree/chosen/plugin-manager/ids
3448-0000-200 3449-0000-200 connection name
@Phoenix:~$ cat /etc/nv_boot_control.conf
TNSPEC 3448-200-0000-F.0-1-0-jetson-nano-qspi-sd-mmcblk0p1
COMPATIBLE_SPEC 3448-200-0000--1--jetson-nano-devkit-
TEGRA_CHIPID 0x21
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
@Phoenix:~$ ls -l /boot/
total 58536
drwxr-xr-x 2 root root 4096 Mai 6 11:08 dtb
drwxr-xr-x 2 root root 4096 Apr 20 15:15 extlinux
drwxr-xr-x 2 root root 4096 Apr 20 12:55 grub
-rw-r--r-- 1 root root 34484232 Feb 22 21:31 Image
-rw-r--r-- 1 root root 7159624 Feb 22 21:31 initrd
lrwxrwxrwx 1 root root 24 Apr 20 12:54 initrd.img -> initrd.img-4.9.253-tegra
-rw-r--r-- 1 root root 15289192 Apr 20 13:13 initrd.img-4.9.253-tegra
-rw-r--r-- 1 root root 237268 Feb 22 21:31 kernel_tegra210-p3448-0000-p3449-0000-b00.dtb
-rw-r--r-- 1 root root 1077 Feb 19 18:05 tegra210-jetson-tx1-p2597-2180-a01-devkit-adafruit-sph0645lm4h.dtbo
-rw-r--r-- 1 root root 1073 Feb 19 18:05 tegra210-jetson-tx1-p2597-2180-a01-devkit-adafruit-uda1334a.dtbo
-rw-r--r-- 1 root root 1856 Feb 19 18:05 tegra210-jetson-tx1-p2597-2180-a01-devkit-csi.dtbo
-rw-r--r-- 1 root root 488509 Feb 19 18:05 tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
-rw-r--r-- 1 root root 2831 Feb 19 18:05 tegra210-jetson-tx1-p2597-2180-a01-devkit-fe-pi-audio.dtbo
-rw-r--r-- 1 root root 1304 Feb 19 18:05 tegra210-jetson-tx1-p2597-2180-a01-devkit-hdr30.dtbo
-rw-r--r-- 1 root root 3076 Feb 19 18:05 tegra210-jetson-tx1-p2597-2180-a01-devkit-hdr40.dtbo
-rw-r--r-- 1 root root 2111 Feb 19 18:05 tegra210-jetson-tx1-p2597-2180-a01-devkit-m2ke.dtbo
-rw-r--r-- 1 root root 2103 Feb 19 18:05 tegra210-jetson-tx1-p2597-2180-a01-devkit-respeaker-4-mic-array.dtbo
-rw-r--r-- 1 root root 2139 Feb 19 18:05 tegra210-jetson-tx1-p2597-2180-a01-devkit-respeaker-4-mic-lin-array.dtbo
-rw-r--r-- 1 root root 489038 Feb 19 18:05 tegra210-jetson-tx1-p2597-2180-a02-devkit-24x7.dtb
-rw-r--r-- 1 root root 228299 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a00.dtb
-rw-r--r-- 1 root root 1085 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a01-adafruit-sph0645lm4h.dtbo
-rw-r--r-- 1 root root 1081 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a01-adafruit-uda1334a.dtbo
-rw-r--r-- 1 root root 228259 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a01.dtb
-rw-r--r-- 1 root root 2839 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a01-fe-pi-audio.dtbo
-rw-r--r-- 1 root root 3700 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a01-hdr40.dtbo
-rw-r--r-- 1 root root 2119 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a01-m2ke.dtbo
-rw-r--r-- 1 root root 3344 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a01-mcp251x.dtbo
-rw-r--r-- 1 root root 2111 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a01-respeaker-4-mic-array.dtbo
-rw-r--r-- 1 root root 2147 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a01-respeaker-4-mic-lin-array.dtbo
-rw-r--r-- 1 root root 1121 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a02-adafruit-sph0645lm4h.dtbo
-rw-r--r-- 1 root root 1117 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a02-adafruit-uda1334a.dtbo
-rw-r--r-- 1 root root 228761 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a02.dtb
-rw-r--r-- 1 root root 2875 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a02-fe-pi-audio.dtbo
-rw-r--r-- 1 root root 3740 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a02-hdr40.dtbo
-rw-r--r-- 1 root root 2155 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a02-m2ke.dtbo
-rw-r--r-- 1 root root 3400 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a02-mcp251x.dtbo
-rw-r--r-- 1 root root 2147 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a02-respeaker-4-mic-array.dtbo
-rw-r--r-- 1 root root 2183 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-a02-respeaker-4-mic-lin-array.dtbo
-rw-r--r-- 1 root root 237268 Feb 19 18:05 tegra210-p3448-0000-p3449-0000-b00.dtb
-rw-r--r-- 1 root root 228655 Feb 19 18:05 tegra210-p3448-0002-p3449-0000-a02.dtb
-rw-r--r-- 1 root root 237198 Feb 19 18:05 tegra210-p3448-0002-p3449-0000-b00.dtb
-rw-r--r-- 1 root root 1077 Feb 19 18:05 tegra210-p3448-0003-p3542-0000-adafruit-sph0645lm4h.dtbo
-rw-r--r-- 1 root root 1073 Feb 19 18:05 tegra210-p3448-0003-p3542-0000-adafruit-uda1334a.dtbo
-rw-r--r-- 1 root root 229155 Feb 19 18:05 tegra210-p3448-0003-p3542-0000.dtb
-rw-r--r-- 1 root root 2831 Feb 19 18:05 tegra210-p3448-0003-p3542-0000-fe-pi-audio.dtbo
-rw-r--r-- 1 root root 3696 Feb 19 18:05 tegra210-p3448-0003-p3542-0000-hdr40.dtbo
-rw-r--r-- 1 root root 2103 Feb 19 18:05 tegra210-p3448-0003-p3542-0000-respeaker-4-mic-array.dtbo
-rw-r--r-- 1 root root 2139 Feb 19 18:05 tegra210-p3448-0003-p3542-0000-respeaker-4-mic-lin-array.dtbo
-rw-r--r-- 1 root root 2780 Feb 19 18:05 tegra210-p3448-all-p3449-0000-camera-imx219-dual.dtbo
-rw-r--r-- 1 root root 3036 Feb 19 18:05 tegra210-p3448-all-p3449-0000-camera-imx477-dual.dtbo
-rw-r--r-- 1 root root 2959 Feb 19 18:05 tegra210-p3448-all-p3449-0000-camera-imx477-imx219.dtbo
-rw-r--r-- 1 root root 2795 Feb 19 18:05 tegra210-p3448-common-imx219.dtbo
-rw-r--r-- 1 root root 2930 Feb 19 18:05 tegra210-p3448-common-imx477.dtbo
@Phoenix:~$ ls -l /boot/dtb
total 232
Thanks for your support.
Norbert
