DGX Spark no longer working
My DGX Spark stopped booting after a period of degradation. It now appears to have a firmware/storage boot failure.
Timeline:
  • The system began degrading about 72 hours before total failure.
  • Services became unstable, then the device was rebooted.
  • After reboot, the DGX Spark no longer came back on the network.
  • With monitor/keyboard attached, it repeatedly returned to BIOS instead of booting Ubuntu.
  • The Ubuntu boot entry was present at first, then later disappeared or failed.
  • Boot override to Ubuntu returned to BIOS.
  • UEFI showed EFI files under \EFI\ubuntu, including grubaa64.efi and shimaa64.efi, but selecting them did not boot.
  • The device now sometimes shows “Synchronous Exception at 0x00000000856668E4” on the NVIDIA splash screen before BIOS/boot.
Important symptoms:
  • BIOS/UEFI loop.
  • NVIDIA splash “Synchronous Exception”.
  • Ubuntu boot path fails.
  • Internal Samsung NVMe was visible in BIOS earlier: SAMSUNG MZALC4T0HBL1-00B07.
  • No OS recovery/reflash has been run because I need to preserve data.
Data-preservation attempt:
  • I removed the internal M.2 NVMe only after the system could not boot, to attempt read-only data recovery.
  • On another DGX Spark, the drive appears as a 3.7TB Samsung device with EFI and ext4 root partitions.
  • Read-only mount attempts hang or fail.
  • rsync/read attempts return Input/output errors.
  • fsck.ext4 was run with no-write flags only: fsck.ext4 -fn.
  • fsck reported: “Error reading block 552 (Input/output error)”.
  • Kernel logs showed errors like:
  • critical target error, dev sda, sector …
  • I/O error, dev sda
  • EXT4-fs warning/error reading directory block
  • FAT-fs corrupted directory on the EFI partition
  • I have not run repair, format, recovery, reinstall, or destructive commands.
Request:
Please advise whether this qualifies for warranty/RMA service. I would also like guidance on the safest data-preserving path before any factory recovery or SSD reflash, since NVIDIA recovery appears likely to erase the internal SSD.
It is the customer’s responsibility to backup important data.
For RMA, please open a ticket with customer support and send me the case reference number NVIDIA DGX Spark Support
