DGX Spark does not boot
DGX Spark we purchased about 2 weeks ago.
Suddenly it stopped working. Rebooting does not work.
Screen shows following three lines and go to bios mode
Checking Media Presence
Media Presnet
Start PXE over IPv4 on MAC
I performed system recovery with DGK Sprak recovery image.
Recovery process was done successfully but still does not boot.
Boot option is only one. UEFI: PXE IPv4 Realtek PCIe 10 GBE Family Controller.
I can see SAMSUNG SSD in Advanced → MVMe Configuration.
I tried also disbling secure boot. It did not help.
I powered off, unplugged power cable, and held the power button for 30 seconds to drain current.
Then tried again, still did not boot.
I was going to check the hardwared, but I did not try because opening the case might void warranty.
Could you provide any suggestion or advice, please?
In the UEFI menu, at NVMe Configuration. Please run a a Device Self Test with Extended and Controller and Namespace options
I set these.
Setf Test Option: Extended
Seft Test Action: Controller and NameSpace Test
Then ran device self test, and result is:
Status: Failed
Device Self-TEst Status: 07
Segment Number: 02
Valid Diagnostic Info : 01
Power on hours: 0000000C
NSID: 0001
Failing LBA : 00000000
StatusCode Type: 00
StatusCode: 00
Thank you
Thank you it looks like there is an issue with your storage modules. Please open a case with Customer Support to request an RMA
