DGX Spark shuts down within minutes after OS reinstall (kernel panic during first boot update)
Hello everyone,
I have purchased a DGX Spark and tried to start it for the first time. However, during the initial boot, after connecting to Wi-Fi and applying updates, the system encountered a kernel panic error.
Following the instructions on the page System Recovery — DGX Spark User Guide, I reinstalled the operating system. After the reinstallation, I was able to boot into the desktop successfully.
However, a new issue has appeared: the system now shuts down automatically within a few minutes after reboot, even when idle.
I have already checked system logs using the command below, but did not find anything abnormal:
journalctl -1 -b -e
journalctl.txt (5.0 KB)
nvidia-bug-report.sh
bug-report.txt (2.1 KB)
Could anyone help me diagnose this issue?
Thanks for the detailed report and for attaching the logs.
From what you shared, the strongest clue is that this may not be a new kernel panic after recovery, but instead an input or power-related shutdown.
In the journal, a Logitech USB receiver is detected, and immediately after that the system logs a power-key event. Could you please try the following first?
  • Power the system off and disconnect all non-essential USB devices, docks, hubs, and adapters, especially the Logitech receiver
  • Boot with only the monitor connected, and if needed, use a simple wired keyboard/mouse
  • Confirm that you are using the original DGX Spark power adapter that shipped with the unit, connected directly to wall power
  • Let the system sit idle for a few minutes and check whether it still shuts down
If it still powers off after that, please collect logs from the failing boot again and share them:
journalctl -b -1 -e
journalctl -b -1 | tail -200
Also, the nvidia-bug-report attachment you posted does not look like the full report contents, so if possible please attach the actual nvidia-bug-report.log.gz file from the system.
If the issue reproduces even with:
  • the supplied power adapter
  • no external USB peripherals except basic wired input devices
  • a clean recovered image
then the next recommended step is to run DGX Spark Field Diagnostics.
The official process is:
  • Disable Secure Boot first:
sudo mokutil --sb-state
sudo systemctl reboot --firmware-setup
Then in UEFI, go to Security → Secure Boot → Disable Secure Boot, save changes, and reboot.
  • Install the diagnostic package:
sudo mkdir -p /usr/share/keyrings
curl -fsSL https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2404/sbsa/cuda-archive-keyring.gpg | sudo tee /usr/share/keyrings/cuda-archive-keyring.gpg > /dev/null
echo "deb [signed-by=/usr/share/keyrings/cuda-archive-keyring.gpg] https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2404/sbsa /" | sudo tee /etc/apt/sources.list.d/cuda-sbsa-ubuntu2404.list
sudo apt-get update
sudo apt-get install dgx-spark-fieldiag
  • Run the diagnostic:
sudo init 3
Log in on the TTY console, then run:
cd /opt/nvidia/dgx-spark-fieldiag
sudo ./partnerdiag --field
The test takes about 30 minutes and should end with a PASS or FAIL banner.
After it completes, please share:
  • whether the result is PASS or FAIL
  • any logs produced by the diagnostic
  • whether the shutdown behavior changes when all USB peripherals are removed
After the test, re-enable Secure Boot by rebooting back into UEFI and setting Security → Secure Boot → Enable Secure Boot.
At that point we can better determine whether this is a peripheral-triggered shutdown, a power issue, or something that needs hardware support escalation.
Thanks for your help! I connected Spark to another display, and it eventually worked well. However, it’s worth noting that the display needs to be connected before starting Spark; otherwise, the screen may remain black.
