We like to set PCIe of TX2 NX always in power on state for doing PCIe testing.
Is there a way to disable "enable-power-down "on Tx2 nx?
Thank you,
Thank you,
You need to modify the kernel directly.
diff --git a/drivers/pci/host/pci-tegra.c b/drivers/pci/host/pci-tegra.c
index 63c0e343d388..52c46b68981e 100644
--- a/drivers/pci/host/pci-tegra.c
+++ b/drivers/pci/host/pci-tegra.c
@@ -2194,7 +2194,7 @@ static bool tegra_pcie_port_check_link(struct tegra_pcie_port *port)
tegra_pcie_port_reset(port);
} while (--retries);
- return false;
+ return true;
static void tegra_pcie_apply_sw_war(struct tegra_pcie_port *port,
Hi WayneWWW,
Thank you for your prompt support.
We’ll test it.
Thanks,
