Display latency when more than one IMX623 camera
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
When more than one IMX623 camera is started with nvsipl_camera and display output enabled, there is some very obvious latency on the display. No dropped frames, but frame discontinuity counter is big. If each camera is started alone, NO display latency, frame discontinuity counter still incrementing. Cameras are connected in the same port group, tried more groups and same results.
Should the VIC engine be on? Because I have tried tegrastats while the nvsipl_camera was running with 2 cameras, and VIC was always off.
Dear @silvia.truica1 ,
Could you share the used model and command? You mean FPS goes down?
It’s a custom camera, ./nvsipl_camera -c “IMX623_RGGB_CPHY_x4_SAME_PORT” -m “0x0000 0x0000 0x0011 0x0000” -d 1 -v 4.
Tried also all combinations of enable raw or disable ISP outputs.
FPS does not go down, it’s stable ~ 30fps in any combinations according to logs; it seems that just the display output has an issue when it has to display more than one camera => that’s why I asked also about VIC
Sorry for the late response.
