I’m trying to use the HP Reverb G2 HMD with a Xavier NX using Displayport. A lower resolution (2880 x 1440 x 90 fps) works fine, however setting the native resolution (4320 x 2160 x 90 fps) causes the display to turn off. It seems that the max pixel clock rate for Displayport may be the issue - the limit is 540 MHz according to the Xavier NX datasheet. According to the EDID information, 2880x1440 needs 428 MHz (and works), 4320x2160 resolution needs 905 MHz (and fails).
Is this understanding correct? Is there any way to increase this limit, perhaps by configuring hardware clocks? It’s unfortunate that Displayport 1.4 HBR3 has the bandwidth to transmit much higher resolutions than the pixel clock limit would allow.
