DisplayPort to HDMI Adapter
I’m using a DisplayPort to HDMI adapter to get a display output, but it’s not working. I’m running JetPack 4.6.3 on a Jetson Nano core board, and the carrier board is the DevKit.
How can I resolve this problem?
Is the adapter a active one?
Thank you for your response.
I’m not familiar with this.
Please get a active adapter. Passive one cannot work on Jetson nano.
I will test it and let you know.
I used an active adapter, but I’m getting this error and there’s no display.
[ 233.938707] tegradc tegradc.1: dp: HPD is not detected
[ 233.938711] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x102, Status 0x0
[ 233.938793] tegradc tegradc.1: dp: HPD is not detected
[ 233.938802] tegradc tegradc.1: dp: HPD is not detected
[ 233.938804] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x10f, Status 0x0
[ 233.938812] tegradc tegradc.1: dp: HPD is not detected
[ 233.938815] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x110, Status 0x0
[ 233.947682] tegradc tegradc.1: dp: HPD is not detected
[ 233.947686] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x202, Status 0x0
[ 233.947693] tegradc tegradc.1: dp: HPD is not detected
[ 233.947696] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x203, Status 0x0
[ 233.947704] tegradc tegradc.1: dp: HPD is not detected
[ 233.947707] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x206, Status 0x0
[ 233.947714] tegradc tegradc.1: dp: HPD is not detected
[ 233.947716] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x207, Status 0x0
[ 233.947723] tegradc tegradc.1: dp: HPD is not detected
[ 233.947725] tegradc tegradc.1: dp: Failed to read DPCD data. CMD 0x20c, Status 0x0
[ 233.947819] tegradc tegradc.1: dp: HPD is not detected
Please try other cable or directly use a native DP monitor.
Thank you for your reply
I have no issues with a direct DisplayPort connection, but I want to use a DisplayPort to HDMI adapter.
Is there any way to solve this problem?
No, this looks not a software issue. You can only try different cables and monitors.
I tried using a different monitor and cable, but it didn’t solve the issue.
Then there is nothing can help here.
