DLSS 3.7 in UE 5.4 - Frame Gen plugin not showing up in UE
I’m trying to use DLSS 3.7 in UE 5.4 and followed the instructions.
I copied the DLSS folder to E:\Games\Epic Games\UE_5.4\Engine\Plugins\Marketplace.
But, in UE, I can only see this: Imgur: The magic of the Internet
Any ideas why?
Hi there @pp1, welcome to the NVIDIA developer forums.
What kind of GPU do you have in your system?
FrameGen runs on 40 series GPUs only.
Hi!
RTX 4090
Weird. Also I think the plugin entry should show up in any case.
Can you double check that it unpacked correctly and all files were copied?
Does it make a difference if you copy over all of the directories in the Plugin folder of the DLSS package?
It might be the documentation is not quite correct.
Copying all the folders solved it! Thanks a lot!
Great!
I’ll ask them to update the documentation to make it a bit clearer. FrameGen comes with the Streamline plugin part if I am not mistaken, so naturally you need those folders.
