I am trying to implement DLSS (not DLSSG, so ignore those parts!) for Skyrim Community Shaders and I struggle to make Streamline DLSS work.
I would love some assistance in deciphering the streamline log more, as I am at my wits end on how to investigate this further. I have attached the log and also the cpp code (which is currently a tad messy).
Running on a 4090, drivers 2 weeks old. So DLSS support is there.
This post is a bit of a hailmary - otherwise we might drop dlss and just stick with the frame generation, I am happy to provide further details. Thanks in adance for anyone who takes the time.
[2024-09-22 10:31:53.917] [info] [41392] [Hooks.cpp:196] Creating DXGI factory
[2024-09-22 10:31:53.941] [info] [41392] [Streamline.cpp:199] [Streamline] Succeeded to verify digital signature of sl.interposer.dll
[2024-09-22 10:31:53.943] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-53][streamline][info]pluginmanager.cpp:99[setHostSDKVersion] Streamline v2.0.1.c7f40186 - built on Wed Apr 19 22:02:52 2023 - host SDK v2.0.1
[2024-09-22 10:31:53.943] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-53][streamline][info]pluginmanager.cpp:461[findPlugins] Looking for plugins in Data/SKSE/Plugins/Streamline ...
[2024-09-22 10:31:53.949] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-53][streamline][info]commoninterface.cpp:140[getSystemCaps] Enumerating up to 8 adapters but only one of them can be used to create a device - no mGPU support in this SDK
[2024-09-22 10:31:53.966] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-53][streamline][info]commoninterface.cpp:258[getSystemCaps] >-----------------------------------------
[2024-09-22 10:31:53.966] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-53][streamline][info]commoninterface.cpp:261[getSystemCaps] NVIDIA driver 561.9
[2024-09-22 10:31:53.969] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-53][streamline][info]commoninterface.cpp:286[getSystemCaps] Adapter 0 architecture 0x190 implementation 0x2 revision 0xa1 - bit 0x1 - LUID 0.66200
[2024-09-22 10:31:53.969] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-53][streamline][info]commoninterface.cpp:292[getSystemCaps] -----------------------------------------<
[2024-09-22 10:31:53.970] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-53][streamline][info]commonentry.cpp:1486[getOSVersionAndUpdateTimerResolution] Changed high resolution timer resolution to 5000 [100 ns units]
[2024-09-22 10:31:53.970] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-53][streamline][info]commonentry.cpp:1560[updateEmbeddedJSON] Detected Windows OS version 10.0.22631
[2024-09-22 10:31:53.970] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-53][streamline][info]pluginmanager.cpp:657[mapPlugins] Loaded plugin 'sl.common' - version 2.0.1.c7f40186 - id 4294967295 - priority 0 - adapter mask 0x3 - interposer 'no'
[2024-09-22 10:31:54.484] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]commonentry.cpp:710[getNGXFeatureRequirements] NGX feature 1 requirements - minOS 10.0.0 minHW 0x160
[2024-09-22 10:31:54.484] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]commonentry.cpp:1015[updateCommonEmbeddedJSONConfig] Registering required tag 'kBufferTypeDepth' life-cycle 'ResourceLifecycle::eValidUntilEvaluate' for feature `kFeatureDLSS`
[2024-09-22 10:31:54.484] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]commonentry.cpp:1015[updateCommonEmbeddedJSONConfig] Registering required tag 'kBufferTypeMotionVectors' life-cycle 'ResourceLifecycle::eValidUntilEvaluate' for feature `kFeatureDLSS`
[2024-09-22 10:31:54.484] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]commonentry.cpp:1015[updateCommonEmbeddedJSONConfig] Registering required tag 'kBufferTypeScalingInputColor' life-cycle 'ResourceLifecycle::eValidUntilEvaluate' for feature `kFeatureDLSS`
[2024-09-22 10:31:54.484] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]commonentry.cpp:1015[updateCommonEmbeddedJSONConfig] Registering required tag 'kBufferTypeScalingOutputColor' life-cycle 'ResourceLifecycle::eValidUntilEvaluate' for feature `kFeatureDLSS`
[2024-09-22 10:31:54.484] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]pluginmanager.cpp:657[mapPlugins] Loaded plugin 'sl.dlss' - version 2.0.1.c7f40186 - id 0 - priority 100 - adapter mask 0x1 - interposer 'no'
[2024-09-22 10:31:54.831] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]commonentry.cpp:710[getNGXFeatureRequirements] NGX feature 11 requirements - minOS 10.0.19041 minHW 0x190
[2024-09-22 10:31:54.831] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]commonentry.cpp:1015[updateCommonEmbeddedJSONConfig] Registering required tag 'kBufferTypeDepth' life-cycle 'ResourceLifecycle::eValidUntilPresent' for feature `kFeatureDLSS_G`
[2024-09-22 10:31:54.831] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]commonentry.cpp:1015[updateCommonEmbeddedJSONConfig] Registering required tag 'kBufferTypeMotionVectors' life-cycle 'ResourceLifecycle::eValidUntilPresent' for feature `kFeatureDLSS_G`
[2024-09-22 10:31:54.831] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]commonentry.cpp:1015[updateCommonEmbeddedJSONConfig] Registering required tag 'kBufferTypeHUDLessColor' life-cycle 'ResourceLifecycle::eValidUntilPresent' for feature `kFeatureDLSS_G`
[2024-09-22 10:31:54.831] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]commonentry.cpp:1015[updateCommonEmbeddedJSONConfig] Registering required tag 'kBufferTypeUIColorAndAlpha' life-cycle 'ResourceLifecycle::eValidUntilPresent' for feature `kFeatureDLSS_G`
[2024-09-22 10:31:54.832] [warning] [47328] [Streamline.cpp:23] [22.09.2024 10-31-54][streamline][warn]pluginmanager.cpp:602[mapPlugins] Ignoring plugin 'sl.dlss_g' since it is was not requested by the host
[2024-09-22 10:31:54.837] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]pluginmanager.cpp:657[mapPlugins] Loaded plugin 'sl.reflex' - version 2.0.1.c7f40186 - id 3 - priority 100 - adapter mask 0x3 - interposer 'no'
[2024-09-22 10:31:54.837] [info] [41392] [Streamline.cpp:242] [Streamline] Successfully initialized Streamline
[2024-09-22 10:31:54.837] [info] [41392] [Streamline.cpp:339] [Streamline] Proxying CreateDXGIFactory
[2024-09-22 10:31:54.837] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]pluginmanager.cpp:865[loadPlugins] Plugin execution order based on priority:
[2024-09-22 10:31:54.837] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]pluginmanager.cpp:868[loadPlugins] P0 - sl.common
[2024-09-22 10:31:54.837] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]pluginmanager.cpp:868[loadPlugins] P100 - sl.dlss
[2024-09-22 10:31:54.837] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]pluginmanager.cpp:868[loadPlugins] P100 - sl.reflex
[2024-09-22 10:31:54.838] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-54][streamline][info]dxgi.cpp:323[CreateDXGIFactoryInternal] Injecting hooks into DXGI proxy virtual table
[2024-09-22 10:31:54.839] [info] [41392] [Streamline.cpp:360] [Streamline] Proxying D3D11CreateDeviceAndSwapChain
[2024-09-22 10:31:55.003] [warning] [47328] [Streamline.cpp:23] [22.09.2024 10-31-55][streamline][warn]d3d11.cpp:85[D3D11CreateDeviceAndSwapChain] Automatically assigning d3d11 device, if this is not desired please use `D3D11CreateDevice` followed by `slSetD3DDevice`
[2024-09-22 10:31:55.004] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1053[initializePlugins] Initializing plugins - api 0.0.1 - application ID 100721531
[2024-09-22 10:31:55.004] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]d3d11.cpp:334[init] GPU nodes 1 - visible node mask 1
[2024-09-22 10:31:55.005] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]d3d11.cpp:561[createKernel] Creating DXBC kernel copy.cs:main hash 16359366160719394762
[2024-09-22 10:31:55.005] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]d3d12.cpp:698[init] Detected DX11 on DX12 scenario
[2024-09-22 10:31:55.112] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]d3d12.cpp:1080[createKernel] Creating DXBC kernel copy_to_buffer.cs:main hash 12564409127886710297
[2024-09-22 10:31:55.112] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:1121[slOnPluginStartup] At least one plugin requires NGX, trying to initialize ...
[2024-09-22 10:31:55.112] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] App logging hooks successfully initialized
[2024-09-22 10:31:55.114] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Found matching adapter with NVAPI physical GPU handle: 0x100 and LUID: { 0x0, 0x10298 }
[2024-09-22 10:31:55.114] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Checking for key: NVSupportNGX, in the INF for GPU with physical handle: 0x100 and LUID: { 0x0, 0x10298 }
[2024-09-22 10:31:55.126] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] using path for models: C:\ProgramData/NVIDIA/NGX/models/
[2024-09-22 10:31:55.126] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] security attributes generated successfully
[2024-09-22 10:31:55.126] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] using generated security descriptor for creating folder at: C:\ProgramData\NVIDIA\NGX\models
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] updated access control list for NGX cache (NGX cache should now be usable by all authenticated users)
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] model folder created: C:\ProgramData/NVIDIA/NGX/models/
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [dlss]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_E658702=0.0.0
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_E658701=0.0.0
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9FEB50=1.0.108
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9FF4BC=1.0.108
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9FD524=1.0.108
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9DF510=1.3.106
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9CB0B8=1.0.108
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9E26B0=2.1.28
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9D48D0=1.0.108
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_E99B5EC=1.2.109
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9DFA64=1.0.108
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9FD6C0=1.0.108
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9CF688=2.2.15
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9D6F08=1.0.108
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9BF564=2.1.28
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9DB4F4=1.0.108
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9D2F5C=1.2.110
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9D7388=1.0.108
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9F5618=2.1.29
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9DAE68=1.2.109
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9D8C54=1.2.109
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_3AC09EF=2.5.1
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9D3EF0=2.1.28
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9FACDC=2.1.28
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_F7361DC=2.1.28
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9C3560=2.1.19
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9B0430=2.1.28
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_E658703=0.0.0
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_86DF0A0=3.1.11
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_8615228=2.4.2
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_8627C04=2.3.5
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9393FC=2.2.6
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_87D97FC=3.5.0
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_876232C=3.7.0
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_86AA7B4=2.3.11
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_86C2DA8=3.7.10
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9DB490=3.5.10
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_8708384=2.3.1
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [nvbcast_afx_rec_v0_7]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_E658703=0.7.1
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [dlisp]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9CF688=2.1.15
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_E99B5EC=1.2.102
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_E658703=1.0.101
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9D8C54=1.2.106
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9D2F5C=1.2.106
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9DF510=1.3.101
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9DAE68=1.2.106
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [nvbcast]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [nvbcast_vfx_gs_v0_7]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [sl_pcl_0]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [nvbcast_ar_fd_v0_7]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [nvbcast_afx_bnr_v0_7]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [dlssg]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_876232C=3.6.0
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_3AC09EF=3.5.0
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [nvbcast_afx_bnrrec_v0_7]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [dlssd]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app_B9DB490=3.5.0
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [nvbcast_vfx_lld_v0_7]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [nvbcast_ar_gw_v0_7]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [sl_reflex_0]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [sl_dlss_0]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [sl_common_0]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [sl_dlss_g_0]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [sl_dlss_d_0]
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] listItem.engineVersion .* listItem.genericCMSId 86aa7b4
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] project id 3F9D696D4363312194B0ECB2671E899F cms id B9FBD50
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] listItem.engineVersion .* listItem.genericCMSId 8618954
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] listItem.engineVersion .* listItem.genericCMSId b9b05cc
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] listItem.engineVersion .* listItem.genericCMSId 876232c
[2024-09-22 10:31:55.138] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] Found cms id 876232c for engine: custom engineVersion 1.0.0 projectID f8776929-c969-43bd-ac2b-294b4de58aac
[2024-09-22 10:31:55.204] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] DRS PROFILE FOUND : ProfileName "The Elder Scrolls V: Skyrim Special Edition", AppName "skyrimse.exe"
[2024-09-22 10:31:55.215] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] called from module sl.common.dll at G:\Lorerim\Stock Game\data\SKSE\Plugins\Streamline
[2024-09-22 10:31:55.227] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_dldenoiser.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.238] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] nvLoadSignedLibraryW() failed on snippet 'Data/SKSE/Plugins/Streamline/nvngx_dlss.dll' missing or corrupted - last error One or more arguments are not correct.
[2024-09-22 10:31:55.239] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Validating snippet Data/SKSE/Plugins/Streamline/nvngx_dlss.dll
[2024-09-22 10:31:55.239] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] NGX CORE API version : 0x15, Snippet requires at least : 0x13
[2024-09-22 10:31:55.239] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] GPU architecture : 0x190, Snippet expects at least : 0x160
[2024-09-22 10:31:55.239] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Driver support flags : 0xF(SEAMLESS_OTA|LINUX_EXTENDED_DRIVER_VERSIONS|API_SPECIFIC_POPULATE_PARAMS|REQUIRE_CMSID), Snippet required flags : 0x0()
[2024-09-22 10:31:55.239] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Driver version : 561.9, Snippet expects at least : 512.15
[2024-09-22 10:31:55.239] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Snippet version : 3.1.11, Embedded app Id : E658703 (0)
[2024-09-22 10:31:55.239] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] unable to read the deny list. Assuming that the feature is allowed.
[2024-09-22 10:31:55.251] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_dlinpainting.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.262] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_dlisr.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.274] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_dlslowmo.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.285] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_dlvsr.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.296] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_dlcolorize.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.308] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_dlstyletransfer.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.319] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_dlvdenoiser.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.330] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_dlisp.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.342] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_dlresolve.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.353] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] nvLoadSignedLibraryW() failed on snippet 'Data/SKSE/Plugins/Streamline/nvngx_dlssg.dll' missing or corrupted - last error One or more arguments are not correct.
[2024-09-22 10:31:55.354] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] Querying GPU Architecture Failed - snippet 'Data/SKSE/Plugins/Streamline/nvngx_dlssg.dll' missing or corrupted
[2024-09-22 10:31:55.354] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] error: unable to load DLL metadata via FileVersionInfo for snippet 'Data/SKSE/Plugins/Streamline/nvngx_dlssg.dll'
[2024-09-22 10:31:55.367] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Loaded NGXCore from path (G:\Lorerim\Stock Game\data\SKSE\Plugins\Streamline/nvngx_dlssg.dll)
[2024-09-22 10:31:55.367] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Validating snippet G:\Lorerim\Stock Game\data\SKSE\Plugins\Streamline/nvngx_dlssg.dll
[2024-09-22 10:31:55.367] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] GPU architecture : 0x190, Snippet expects at least : 0x190
[2024-09-22 10:31:55.367] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Driver version : 561.9, Snippet expects at least : 520.0
[2024-09-22 10:31:55.367] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Snippet version : 3.6.0, Embedded app Id : E658703 (0)
[2024-09-22 10:31:55.367] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: skipping downloaded snippet due to lower version 3.6.0 < 3.6.0
[2024-09-22 10:31:55.367] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] app 876232C feature dlssg snippet: G:\Lorerim\Stock Game\data\SKSE\Plugins\Streamline/nvngx_dlssg.dll version: 3.6.0
[2024-09-22 10:31:55.367] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Setting show info tip callback for dlssg
[2024-09-22 10:31:55.367] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Setting telemetry callback for dlssg [schema 3.0+]
[2024-09-22 10:31:55.379] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_deepdvc.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.391] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_dlssd.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.402] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_truehdr.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.414] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: ModuleName - nvngx_vsr.dll doesn't exist in any of the search paths!
[2024-09-22 10:31:55.425] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Detected Windows Version 10.0.22621.4036
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Sending Telemetry Init Data
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] FeatureInitResult = NvNGXFeatureInitSuccess
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] appExeName = sl.common.dll
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] drsProfileName = The Elder Scrolls V: Skyrim Special Edition
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] drsName = skyrimse.exe
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] AppIdType = RENDERING_ENGINE
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] ProjectId = f8776929-c969-43bd-ac2b-294b4de58aac
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] EngineVersion = 1.0.0
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] EngineType = custom
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] cmsId = 0
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] featureType = FrameGeneration
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] gpuDeviceId = 9860
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] gpuVendorId = 4318
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] gpuSubSys = 1086264408
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] gpuRev = 161
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] ngxSDKVersion = 1.5
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] ngxCoreVersion = 1.4.0.1
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] ngxFeatureVersion = 3.6.0
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] displayDriverVersion = 561.9
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] osVersion = 10.0.22621.4036
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] APIType = 0
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] GpuAPI = 1
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] -- END telemetry init data --
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] NGXCore not found next to the application
[2024-09-22 10:31:55.426] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Checking for path to NGX using QueryAdapterInfo
[2024-09-22 10:31:55.427] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] Path to driverStore found using QAI: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_dcf94619172aceb0
[2024-09-22 10:31:55.435] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] Loaded NGXCore from path (C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_dcf94619172aceb0\_nvngx.dll)
[2024-09-22 10:31:55.738] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] warning: attempted to initialize telemetry while already initialized
[2024-09-22 10:31:55.858] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [NGXInitLog:219] App logging hooks successfully initialized
[2024-09-22 10:31:55.858] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [NGXInitLog:226] Built with APP_NAME = default
[2024-09-22 10:31:55.858] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [NGXDLSSG::InitCommon:687] Calling debug config init!
[2024-09-22 10:31:55.858] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [NgxDlssgDebug::LoadKeyConfigJson:24] KeyConfigJson - not found at: ngx_keybinds.json
Using default hardcoded config...
[2024-09-22 10:31:55.858] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:891[ngxLog] [NGXDLSSG::InitCommon:691] Get snippet file version!
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:892[ngxLog] GpuAPI = 2
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]commonentry.cpp:1247[slOnPluginStartup] NGX loaded - app id 100721531 - application data path C:\Users\simon\AppData\Local\Temp\
[2024-09-22 10:31:55.860] [warning] [47328] [Streamline.cpp:23] [22.09.2024 10-31-55][streamline][warn]commonentry.cpp:1251[slOnPluginStartup] Valid application id is required in production builds - allowing for now but please fix this
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1141[mapPluginCallbacks] Callback sl.common:slSetData:0x0
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1142[mapPluginCallbacks] Callback sl.common:slGetData:0x0
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1143[mapPluginCallbacks] Callback sl.common:slAllocateResources:0x0
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1144[mapPluginCallbacks] Callback sl.common:slFreeResources:0x0
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1145[mapPluginCallbacks] Callback sl.common:slEvaluateFeature:0x7ff8a2dc7400
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1146[mapPluginCallbacks] Callback sl.common:slSetTag:0x7ff8a2dc68b0
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1147[mapPluginCallbacks] Callback sl.common:slSetConsts:0x7ff8a2dc7170
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:941[processPluginHooks] Hook sl.common:slHookVkPresent:before - skipped
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:941[processPluginHooks] Hook sl.common:slHookVkCmdBindPipeline:after - skipped
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:941[processPluginHooks] Hook sl.common:slHookVkCmdBindDescriptorSets:after - skipped
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:941[processPluginHooks] Hook sl.common:slHookVkBeginCommandBuffer:after - skipped
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:965[processPluginHooks] Hook sl.common:slHookResizeSwapChainPre:before - OK
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:965[processPluginHooks] Hook sl.common:slHookPresent:before - OK
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:965[processPluginHooks] Hook sl.common:slHookPresent1:before - OK
[2024-09-22 10:31:55.860] [error] [47328] [Streamline.cpp:26] [22.09.2024 10-31-55][streamline][error]dlssentry.cpp:898[slOnPluginStartup] NGX parameter indicating DLSSContext support cannot be found (0xbad00010) - DLSSContext cannot run
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1141[mapPluginCallbacks] Callback sl.reflex:slSetData:0x7ff89fea03a0
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1142[mapPluginCallbacks] Callback sl.reflex:slGetData:0x7ff89fea0970
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1143[mapPluginCallbacks] Callback sl.reflex:slAllocateResources:0x0
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1144[mapPluginCallbacks] Callback sl.reflex:slFreeResources:0x0
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1145[mapPluginCallbacks] Callback sl.reflex:slEvaluateFeature:0x0
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1146[mapPluginCallbacks] Callback sl.reflex:slSetTag:0x0
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:1147[mapPluginCallbacks] Callback sl.reflex:slSetConsts:0x0
[2024-09-22 10:31:55.860] [info] [47328] [Streamline.cpp:20] [22.09.2024 10-31-55][streamline][info]pluginmanager.cpp:926[processPluginHooks] Plugin 'sl.reflex' has no registered hooks
[2024-09-22 10:31:55.870] [error] [41392] [Streamline.cpp:289] [Streamline] DLSS is not supported on this adapter: eErrorFeatureMissing
#define _WIN32_WINNT 0x0A00 // Windows 10 and later
#define NV_WINDOWS
#include <windows.h>
#include <wintrust.h>
#include <softpub.h>
#include "Streamline.h"
#include "sl.h"
#include "sl_result.h"
#include "sl_security.h"
#include <dxgi.h>
#include "Util.h"
void LoggingCallback(sl::LogType type, const char* msg)
switch (type) {
case sl::LogType::eInfo:
logger::info("{}", msg);
break;
case sl::LogType::eWarn:
logger::warn("{}", msg);
break;
case sl::LogType::eError:
logger::error("{}", msg);
break;
void Streamline::DrawSettings()
if (!REL::Module::IsVR()) {
if (ImGui::CollapsingHeader("NVIDIA DLSS", ImGuiTreeNodeFlags_OpenOnArrow | ImGuiTreeNodeFlags_OpenOnDoubleClick)) {
if (streamlineActive) {
ImGui::Text("Streamline uses a D3D11 to D3D12 proxy");
ImGui::Text("Frame Generation always defaults to Auto");
ImGui::Text("To disable Frame Generation, disable it in your mod manager");
// const char* frameGenerationModes[] = { "Off", "On", "Auto" };
// frameGenerationMode = (sl::DLSSGMode)std::min(2u, (uint)frameGenerationMode);
// ImGui::SliderInt("Frame Generation", (int*)&frameGenerationMode, 0, 2, std::format("{}", frameGenerationModes[(uint)frameGenerationMode]).c_str());
// Add DLSS mode selection
const char* dlssModes[] = { "Off", "Ultra Performance", "Performance", "Balanced", "Quality", "Ultra Quality", "DLAA" };
int dlssModeCount = sizeof(dlssModes) / sizeof(dlssModes[0]);
int currentDlssMode = (int)dlssMode;
ImGui::Combo("DLSS Mode", ¤tDlssMode, dlssModes, dlssModeCount);
dlssMode = (sl::DLSSMode)currentDlssMode;
} else {
ImGui::Text("Streamline is not active due to no available plugins");
ImGui::Text("To enable Frame Generation, enable it in your mod manager");
void Streamline::Shutdown()
if (SL_FAILED(res, slShutdown())) {
logger::error("[Streamline] Failed to shutdown Streamline");
} else {
logger::info("[Streamline] Successfully shutdown Streamline");
#include "sl_result.h" // Ensure this header is included
const char* GetSLResultString(sl::Result result) {
switch (result) {
case sl::Result::eOk:
return "eOk";
case sl::Result::eErrorIO:
return "eErrorIO";
case sl::Result::eErrorDriverOutOfDate:
return "eErrorDriverOutOfDate";
case sl::Result::eErrorOSOutOfDate:
return "eErrorOSOutOfDate";
case sl::Result::eErrorOSDisabledHWS:
return "eErrorOSDisabledHWS";
case sl::Result::eErrorDeviceNotCreated:
return "eErrorDeviceNotCreated";
case sl::Result::eErrorNoSupportedAdapterFound:
return "eErrorNoSupportedAdapterFound";
case sl::Result::eErrorAdapterNotSupported:
return "eErrorAdapterNotSupported";
case sl::Result::eErrorNoPlugins:
return "eErrorNoPlugins";
case sl::Result::eErrorVulkanAPI:
return "eErrorVulkanAPI";
case sl::Result::eErrorDXGIAPI:
return "eErrorDXGIAPI";
case sl::Result::eErrorD3DAPI:
return "eErrorD3DAPI";
case sl::Result::eErrorNRDAPI:
return "eErrorNRDAPI";
case sl::Result::eErrorNVAPI:
return "eErrorNVAPI";
case sl::Result::eErrorReflexAPI:
return "eErrorReflexAPI";
case sl::Result::eErrorNGXFailed:
return "eErrorNGXFailed";
case sl::Result::eErrorJSONParsing:
return "eErrorJSONParsing";
case sl::Result::eErrorMissingProxy:
return "eErrorMissingProxy";
case sl::Result::eErrorMissingResourceState:
return "eErrorMissingResourceState";
case sl::Result::eErrorInvalidIntegration:
return "eErrorInvalidIntegration";
case sl::Result::eErrorMissingInputParameter:
return "eErrorMissingInputParameter";
case sl::Result::eErrorNotInitialized:
return "eErrorNotInitialized";
case sl::Result::eErrorComputeFailed:
return "eErrorComputeFailed";
case sl::Result::eErrorInitNotCalled:
return "eErrorInitNotCalled";
case sl::Result::eErrorExceptionHandler:
return "eErrorExceptionHandler";
case sl::Result::eErrorInvalidParameter:
return "eErrorInvalidParameter";
case sl::Result::eErrorMissingConstants:
return "eErrorMissingConstants";
case sl::Result::eErrorDuplicatedConstants:
return "eErrorDuplicatedConstants";
case sl::Result::eErrorMissingOrInvalidAPI:
return "eErrorMissingOrInvalidAPI";
case sl::Result::eErrorCommonConstantsMissing:
return "eErrorCommonConstantsMissing";
case sl::Result::eErrorUnsupportedInterface:
return "eErrorUnsupportedInterface";
case sl::Result::eErrorFeatureMissing:
return "eErrorFeatureMissing";
case sl::Result::eErrorFeatureNotSupported:
return "eErrorFeatureNotSupported";
case sl::Result::eErrorFeatureMissingHooks:
return "eErrorFeatureMissingHooks";
case sl::Result::eErrorFeatureFailedToLoad:
return "eErrorFeatureFailedToLoad";
case sl::Result::eErrorFeatureWrongPriority:
return "eErrorFeatureWrongPriority";
case sl::Result::eErrorFeatureMissingDependency:
return "eErrorFeatureMissingDependency";
case sl::Result::eErrorFeatureManagerInvalidState:
return "eErrorFeatureManagerInvalidState";
case sl::Result::eErrorInvalidState:
return "eErrorInvalidState";
case sl::Result::eWarnOutOfVRAM:
return "eWarnOutOfVRAM";
default:
return "Unknown error";
void Streamline::Initialize_postInit()
// Retrieve other function pointers from the interposer
slInit = (PFun_slInit*)GetProcAddress(interposer, "slInit");
slShutdown = (PFun_slShutdown*)GetProcAddress(interposer, "slShutdown");
slIsFeatureSupported = (PFun_slIsFeatureSupported*)GetProcAddress(interposer, "slIsFeatureSupported");
slIsFeatureLoaded = (PFun_slIsFeatureLoaded*)GetProcAddress(interposer, "slIsFeatureLoaded");
slSetFeatureLoaded = (PFun_slSetFeatureLoaded*)GetProcAddress(interposer, "slSetFeatureLoaded");
slEvaluateFeature = (PFun_slEvaluateFeature*)GetProcAddress(interposer, "slEvaluateFeature");
slAllocateResources = (PFun_slAllocateResources*)GetProcAddress(interposer, "slAllocateResources");
slFreeResources = (PFun_slFreeResources*)GetProcAddress(interposer, "slFreeResources");
slSetTag = (PFun_slSetTag*)GetProcAddress(interposer, "slSetTag");
slGetFeatureRequirements = (PFun_slGetFeatureRequirements*)GetProcAddress(interposer, "slGetFeatureRequirements");
slGetFeatureVersion = (PFun_slGetFeatureVersion*)GetProcAddress(interposer, "slGetFeatureVersion");
slUpgradeInterface = (PFun_slUpgradeInterface*)GetProcAddress(interposer, "slUpgradeInterface");
slSetConstants = (PFun_slSetConstants*)GetProcAddress(interposer, "slSetConstants");
slGetNativeInterface = (PFun_slGetNativeInterface*)GetProcAddress(interposer, "slGetNativeInterface");
slGetFeatureFunction = (PFun_slGetFeatureFunction*)GetProcAddress(interposer, "slGetFeatureFunction");
slGetNewFrameToken = (PFun_slGetNewFrameToken*)GetProcAddress(interposer, "slGetNewFrameToken");
slSetD3DDevice = (PFun_slSetD3DDevice*)GetProcAddress(interposer, "slSetD3DDevice");
// Check for null pointers and handle errors
if (!slShutdown || !slSetD3DDevice || !slIsFeatureLoaded || !slIsFeatureSupported || !slGetFeatureFunction) {
logger::error("[Streamline] Failed to retrieve function pointers from interposer");
streamlineActive = false;
return;
void Streamline::Initialize_preDevice()
logger::debug("[Streamline] Initializing Streamline");
// Securely load the interposer DLL
std::wstring slInterposerPath = L"Data/SKSE/Plugins/Streamline/sl.interposer.dll";
if (!sl::security::verifyEmbeddedSignature(slInterposerPath.c_str())) {
logger::error("[Streamline] Failed to verify digital signature of sl.interposer.dll");
return;
} else {
logger::info("[Streamline] Succeeded to verify digital signature of sl.interposer.dll");
this->interposer = LoadLibraryW(slInterposerPath.c_str());
if (!interposer) {
logger::error("[Streamline] Failed to load sl.interposer.dll");
return;
// Proceed to initialize Streamline
sl::Preferences pref{};
// Set up preferences (features to load, logging, paths, etc.)
sl::Feature featuresToLoad[] = { sl::kFeatureDLSS, sl::kFeatureReflex };
pref.featuresToLoad = featuresToLoad;
pref.numFeaturesToLoad = _countof(featuresToLoad);
pref.logLevel = sl::LogLevel::eVerbose;
pref.logMessageCallback = LoggingCallback;
const wchar_t* pathsToPlugins[] = { L"Data/SKSE/Plugins/Streamline" };
pref.pathsToPlugins = pathsToPlugins;
pref.numPathsToPlugins = _countof(pathsToPlugins);
pref.engine = sl::EngineType::eCustom;
pref.engineVersion = "1.0.0";
pref.projectId = "f8776929-c969-43bd-ac2b-294b4de58aac";
pref.applicationId = 0; // For development, although NGX may require a valid ID
pref.renderAPI = sl::RenderAPI::eD3D11;
// Initialize Streamline
if (!slInit) {
logger::error("[Streamline] Failed to get slInit function from interposer");
return;
sl::Result res = slInit(pref, sl::kSDKVersion);
if (res != sl::Result::eOk) {
logger::error("[Streamline] slInit failed: {}", GetSLResultString(res));
return;
} else {
logger::info("[Streamline] Successfully initialized Streamline");
streamlineActive = true;
initialized = true;
// Hook up interposer
Initialize_postInit();
// pref.engine = sl::EngineType::eCustom
// pref.engineVersion = "1.0.0";
// pref.projectId = "f8776929-c969-43bd-ac2b-294b4de58aac";
// pref.applicationId = 0; // Replace with valid application ID
// pref.renderAPI = sl::RenderAPI::eD3D11;
// // Hook up all of the functions exported by the SL Interposer Library
// slInit = (PFun_slInit*)GetProcAddress(interposer, "slInit");
// slShutdown = (PFun_slShutdown*)GetProcAddress(interposer, "slShutdown");
// slIsFeatureSupported = (PFun_slIsFeatureSupported*)GetProcAddress(interposer, "slIsFeatureSupported");
// slIsFeatureLoaded = (PFun_slIsFeatureLoaded*)GetProcAddress(interposer, "slIsFeatureLoaded");
// slSetFeatureLoaded = (PFun_slSetFeatureLoaded*)GetProcAddress(interposer, "slSetFeatureLoaded");
// slEvaluateFeature = (PFun_slEvaluateFeature*)GetProcAddress(interposer, "slEvaluateFeature");
// slAllocateResources = (PFun_slAllocateResources*)GetProcAddress(interposer, "slAllocateResources");
// slFreeResources = (PFun_slFreeResources*)GetProcAddress(interposer, "slFreeResources");
// slSetTag = (PFun_slSetTag*)GetProcAddress(interposer, "slSetTag");
// slGetFeatureRequirements = (PFun_slGetFeatureRequirements*)GetProcAddress(interposer, "slGetFeatureRequirements");
// slGetFeatureVersion = (PFun_slGetFeatureVersion*)GetProcAddress(interposer, "slGetFeatureVersion");
// slUpgradeInterface = (PFun_slUpgradeInterface*)GetProcAddress(interposer, "slUpgradeInterface");
// slSetConstants = (PFun_slSetConstants*)GetProcAddress(interposer, "slSetConstants");
// slGetNativeInterface = (PFun_slGetNativeInterface*)GetProcAddress(interposer, "slGetNativeInterface");
// slGetFeatureFunction = (PFun_slGetFeatureFunction*)GetProcAddress(interposer, "slGetFeatureFunction");
// slGetNewFrameToken = (PFun_slGetNewFrameToken*)GetProcAddress(interposer, "slGetNewFrameToken");
// slSetD3DDevice = (PFun_slSetD3DDevice*)GetProcAddress(interposer, "slSetD3DDevice");
void Streamline::Initialize_postDevice(IDXGIAdapter* pAdapter)
// Check if DLSS is supported
DXGI_ADAPTER_DESC adapterDesc;
pAdapter->GetDesc(&adapterDesc);
sl::AdapterInfo adapterInfo{};
adapterInfo.deviceLUID = (uint8_t*)&adapterDesc.AdapterLuid;
adapterInfo.deviceLUIDSizeInBytes = sizeof(LUID);
sl::Result res = slIsFeatureSupported(sl::kFeatureDLSS, adapterInfo);
if (res == sl::Result::eOk) {
logger::info("[Streamline] DLSS is supported on this adapter");
} else {
logger::error("[Streamline] DLSS is not supported on this adapter: {}", GetSLResultString(res));
return;
// Check if DLSS is loaded
bool dlssFeatureLoaded = false;
res = slIsFeatureLoaded(sl::kFeatureDLSS, dlssFeatureLoaded);
if (res == sl::Result::eOk && dlssFeatureLoaded) {
logger::info("[Streamline] DLSS feature is loaded");
} else {
logger::error("[Streamline] DLSS feature is not loaded");
return;
// Hook up all of the feature functions using the sl function slGetFeatureFunction
slGetFeatureFunction(sl::kFeatureDLSS_G, "slDLSSGGetState", (void*&)slDLSSGGetState);
slGetFeatureFunction(sl::kFeatureDLSS_G, "slDLSSGSetOptions", (void*&)slDLSSGSetOptions);
// Get DLSS functions
slGetFeatureFunction(sl::kFeatureDLSS, "slDLSSGetOptimalSettings", (void*&)slDLSSGetOptimalSettings);
slGetFeatureFunction(sl::kFeatureDLSS, "slDLSSSetOptions", (void*&)slDLSSSetOptions);
slGetFeatureFunction(sl::kFeatureDLSS, "slDLSSGetState", (void*&)slDLSSGetState);
slGetFeatureFunction(sl::kFeatureReflex, "slReflexGetState", (void*&)slReflexGetState);
slGetFeatureFunction(sl::kFeatureReflex, "slReflexSetMarker", (void*&)slReflexSetMarker);
slGetFeatureFunction(sl::kFeatureReflex, "slReflexSleep", (void*&)slReflexSleep);
slGetFeatureFunction(sl::kFeatureReflex, "slReflexSetOptions", (void*&)slReflexSetOptions);
// We set reflex consts to a default config. This can be changed at runtime in the UI.
auto reflexOptions = sl::ReflexOptions{};
reflexOptions.mode = sl::ReflexMode::eLowLatencyWithBoost;
reflexOptions.useMarkersToOptimize = false;
reflexOptions.virtualKey = 0;
reflexOptions.frameLimitUs = 0;
res = slReflexSetOptions(reflexOptions);
logger::error("[Streamline] Failed to set reflex options");
} else {
logger::info("[Streamline] Successfully set reflex options");
HRESULT Streamline::CreateDXGIFactory(REFIID riid, void** ppFactory)
if (!initialized)
Initialize_preDevice();
logger::info("[Streamline] Proxying CreateDXGIFactory");
auto slCreateDXGIFactory1 = reinterpret_cast<decltype(&CreateDXGIFactory1)>(GetProcAddress(interposer, "CreateDXGIFactory1"));
return slCreateDXGIFactory1(riid, ppFactory);
HRESULT Streamline::CreateDeviceAndSwapChain(IDXGIAdapter* pAdapter,
D3D_DRIVER_TYPE DriverType,
HMODULE Software,
UINT Flags,
const D3D_FEATURE_LEVEL* pFeatureLevels,
UINT FeatureLevels,
UINT SDKVersion,
const DXGI_SWAP_CHAIN_DESC* pSwapChainDesc,
IDXGISwapChain** ppSwapChain,
ID3D11Device** ppDevice,
D3D_FEATURE_LEVEL* pFeatureLevel,
ID3D11DeviceContext** ppImmediateContext,
bool& o_streamlineProxy)
logger::info("[Streamline] Proxying D3D11CreateDeviceAndSwapChain");
// Create the D3D11 device and swap chain
auto slD3D11CreateDeviceAndSwapChain = reinterpret_cast<decltype(&D3D11CreateDeviceAndSwapChain)>(
GetProcAddress(interposer, "D3D11CreateDeviceAndSwapChain"));
auto hr = slD3D11CreateDeviceAndSwapChain(
pAdapter,
DriverType,
Software,
Flags,
pFeatureLevels,
FeatureLevels,
SDKVersion,
pSwapChainDesc,
ppSwapChain,
ppDevice,
pFeatureLevel,
ppImmediateContext);
if (FAILED(hr)) {
logger::error("[Streamline] Failed to create D3D11 device and swap chain: 0x{:X}", hr);
return hr;
this->pDevice = *ppDevice;
// Proceed with the rest of the initialization
Initialize_postDevice(pAdapter);
viewport = { 0 };
o_streamlineProxy = true;
return hr;
void Streamline::CreateFrameGenerationResources()
logger::info("[Streamline] Creating frame generation resources");
auto renderer = RE::BSGraphics::Renderer::GetSingleton();
auto& main = renderer->GetRuntimeData().renderTargets[RE::RENDER_TARGETS::kMAIN];
D3D11_TEXTURE2D_DESC texDesc{};
D3D11_SHADER_RESOURCE_VIEW_DESC srvDesc = {};
D3D11_RENDER_TARGET_VIEW_DESC rtvDesc = {};
D3D11_UNORDERED_ACCESS_VIEW_DESC uavDesc = {};
main.texture->GetDesc(&texDesc);
main.SRV->GetDesc(&srvDesc);
main.RTV->GetDesc(&rtvDesc);
main.UAV->GetDesc(&uavDesc);
texDesc.Format = DXGI_FORMAT_R8G8B8A8_UNORM;
srvDesc.Format = texDesc.Format;
rtvDesc.Format = texDesc.Format;
uavDesc.Format = texDesc.Format;
texDesc.MiscFlags = D3D11_RESOURCE_MISC_SHARED | D3D11_RESOURCE_MISC_SHARED_NTHANDLE;
colorBufferShared = new Texture2D(texDesc);
colorBufferShared->CreateSRV(srvDesc);
colorBufferShared->CreateRTV(rtvDesc);
colorBufferShared->CreateUAV(uavDesc);
// Create output color buffer for DLSS
// TODO: Check is this goes where it should
colorBufferDLSSOutput = new Texture2D(texDesc);
colorBufferDLSSOutput->CreateSRV(srvDesc);
colorBufferDLSSOutput->CreateRTV(rtvDesc);
colorBufferDLSSOutput->CreateUAV(uavDesc);
texDesc.Format = DXGI_FORMAT_R32_FLOAT;
depthBufferShared = new Texture2D(texDesc);
depthBufferShared->CreateSRV(srvDesc);
depthBufferShared->CreateRTV(rtvDesc);
depthBufferShared->CreateUAV(uavDesc);
copyDepthToSharedBufferCS = (ID3D11ComputeShader*)Util::CompileShader(L"Data\\Shaders\\Streamline\\CopyDepthToSharedBufferCS.hlsl", {}, "cs_5_0");
void Streamline::SetupFrameGeneration()
if (!streamlineActive)
return;
CreateFrameGenerationResources();
// sl::DLSSGOptions options{};
// options.mode = sl::DLSSGMode::eAuto;
// options.flags = sl::DLSSGFlags::eRetainResourcesWhenOff;
// if (SL_FAILED(res, slDLSSGSetOptions(viewport, options))) {
// logger::error("[Streamline] Could not enable DLSSG");
void Streamline::CopyResourcesToSharedBuffers()
// if (!streamlineActive || frameGenerationMode == sl::DLSSGMode::eOff)
// return;
auto& context = State::GetSingleton()->context;
if (RE::UI::GetSingleton()->GameIsPaused()) {
float clearColor[4] = { 0, 0, 0, 0 };
auto& motionVectorsBuffer = renderer->GetRuntimeData().renderTargets[RE::RENDER_TARGETS::RENDER_TARGET::kMOTION_VECTOR];
context->ClearRenderTargetView(motionVectorsBuffer.RTV, clearColor);
ID3D11RenderTargetView* backupViews[8];
ID3D11DepthStencilView* backupDsv;
context->OMGetRenderTargets(8, backupViews, &backupDsv); // Backup bound render targets
context->OMSetRenderTargets(0, nullptr, nullptr); // Unbind all bound render targets
auto& swapChain = renderer->GetRuntimeData().renderTargets[RE::RENDER_TARGET::kFRAMEBUFFER];
ID3D11Resource* swapChainResource;
swapChain.SRV->GetResource(&swapChainResource);
context->CopyResource(colorBufferShared->resource.get(), swapChainResource);
auto& depth = renderer->GetDepthStencilData().depthStencils[RE::RENDER_TARGETS_DEPTHSTENCIL::kMAIN];
auto dispatchCount = Util::GetScreenDispatchCount();
ID3D11ShaderResourceView* views[1] = { depth.depthSRV };
context->CSSetShaderResources(0, ARRAYSIZE(views), views);
ID3D11UnorderedAccessView* uavs[1] = { depthBufferShared->uav.get() };
context->CSSetUnorderedAccessViews(0, ARRAYSIZE(uavs), uavs, nullptr);
context->CSSetShader(copyDepthToSharedBufferCS, nullptr, 0);
context->Dispatch(dispatchCount.x, dispatchCount.y, 1);
ID3D11ShaderResourceView* views[1] = { nullptr };
ID3D11UnorderedAccessView* uavs[1] = { nullptr };
ID3D11ComputeShader* shader = nullptr;
context->CSSetShader(shader, nullptr, 0);
context->OMSetRenderTargets(8, backupViews, backupDsv); // Restore all bound render targets
for (int i = 0; i < 8; i++) {
if (backupViews[i])
backupViews[i]->Release();
if (backupDsv)
backupDsv->Release();
void Streamline::Present()
return;
// static auto currentFrameGenerationMode = frameGenerationMode;
// if (currentFrameGenerationMode != frameGenerationMode) {
// currentFrameGenerationMode = frameGenerationMode;
// options.mode = frameGenerationMode;
// logger::error("[Streamline] Could not set DLSSG");
// Handle DLSS mode
static auto currentDLSSMode = dlssMode;
if (currentDLSSMode != dlssMode) {
sl::DLSSOptions dlssOptions = {};
dlssOptions.mode = dlssMode;
dlssOptions.outputWidth = (uint)State::GetSingleton()->screenSize.x;
dlssOptions.outputHeight = (uint)State::GetSingleton()->screenSize.y;
dlssOptions.sharpness = 0.0f; // adjust as needed
dlssOptions.colorBuffersHDR = sl::Boolean::eFalse;
sl::DLSSOptimalSettings dlssSettings = {};
if (SL_FAILED(res, slDLSSGetOptimalSettings(dlssOptions, dlssSettings))) {
logger::error("[Streamline] Could not get DLSS optimal settings");
} else {
// Adjust render resolution if possible
if (SL_FAILED(res, slDLSSSetOptions(viewport, dlssOptions))) {
logger::error("[Streamline] Could not set DLSS options");
// Tag resources for DLSS
sl::Extent fullExtent{ 0, 0, (uint)State::GetSingleton()->screenSize.x, (uint)State::GetSingleton()->screenSize.y };
float2 dynamicScreenSize = Util::ConvertToDynamic(State::GetSingleton()->screenSize);
sl::Extent dynamicExtent{ 0, 0, (uint)dynamicScreenSize.x, (uint)dynamicScreenSize.y };
sl::Resource depth = { sl::ResourceType::eTex2d, depthBufferShared->resource.get(), 0 };
sl::ResourceTag depthTag = sl::ResourceTag{ &depth, sl::kBufferTypeDepth, sl::ResourceLifecycle::eValidUntilPresent, &dynamicExtent };
sl::Resource mvec = { sl::ResourceType::eTex2d, motionVectorsBuffer.texture, 0 };
sl::ResourceTag mvecTag = sl::ResourceTag{ &mvec, sl::kBufferTypeMotionVectors, sl::ResourceLifecycle::eValidUntilPresent, &dynamicExtent };
sl::Resource colorIn = { sl::ResourceType::eTex2d, colorBufferShared->resource.get(), 0 };
sl::ResourceTag colorInTag = sl::ResourceTag{ &colorIn, sl::kBufferTypeScalingInputColor, sl::ResourceLifecycle::eOnlyValidNow, &dynamicExtent };
sl::Resource colorOut = { sl::ResourceType::eTex2d, colorBufferDLSSOutput->resource.get(), 0 };
sl::ResourceTag colorOutTag = sl::ResourceTag{ &colorOut, sl::kBufferTypeScalingOutputColor, sl::ResourceLifecycle::eOnlyValidNow, &fullExtent };
sl::ResourceTag inputs[] = { depthTag, mvecTag, colorInTag, colorOutTag };
slSetTag(viewport, inputs, _countof(inputs), nullptr);
// Evaluate DLSS
EvaluateDLSS();
// Fake NVIDIA Reflex to prevent DLSSG errors
slReflexSetMarker(sl::ReflexMarker::eInputSample, *currentFrame);
slReflexSetMarker(sl::ReflexMarker::eSimulationStart, *currentFrame);
slReflexSetMarker(sl::ReflexMarker::eSimulationEnd, *currentFrame);
slReflexSetMarker(sl::ReflexMarker::eRenderSubmitStart, *currentFrame);
slReflexSetMarker(sl::ReflexMarker::eRenderSubmitEnd, *currentFrame);
slReflexSetMarker(sl::ReflexMarker::ePresentStart, *currentFrame);
slReflexSetMarker(sl::ReflexMarker::ePresentEnd, *currentFrame);
void Streamline::EvaluateDLSS()
if (!streamlineActive || dlssMode == sl::DLSSMode::eOff)
return;
const sl::BaseStructure* evaluateInputs[] = { &viewport };
if (SL_FAILED(res, slEvaluateFeature(sl::kFeatureDLSS, *currentFrame, evaluateInputs, _countof(evaluateInputs), context))) {
logger::error("[Streamline] Could not evaluate DLSS");
} else {
// Restore state if necessary
void Streamline::SetConstants()
return;
auto state = State::GetSingleton();
auto cameraData = Util::GetCameraData(0);
auto eyePosition = Util::GetEyePosition(0);
auto clipToCameraView = cameraData.viewMat.Invert();
auto cameraToWorld = cameraData.viewProjMatrixUnjittered.Invert();
auto cameraToWorldPrev = cameraData.previousViewProjMatrixUnjittered.Invert();
float4x4 cameraToPrevCamera;
calcCameraToPrevCamera(*(sl::float4x4*)&cameraToPrevCamera, *(sl::float4x4*)&cameraToWorld, *(sl::float4x4*)&cameraToWorldPrev);
float4x4 prevCameraToCamera = cameraToPrevCamera;
prevCameraToCamera.Invert();
sl::Constants slConstants = {};
slConstants.cameraAspectRatio = state->screenSize.x / state->screenSize.y;
slConstants.cameraFOV = Util::GetVerticalFOVRad();
slConstants.cameraFar = (*(float*)(REL::RelocationID(517032, 403540).address() + 0x44));
slConstants.cameraMotionIncluded = sl::Boolean::eTrue;
slConstants.cameraNear = (*(float*)(REL::RelocationID(517032, 403540).address() + 0x40));
slConstants.cameraPinholeOffset = { 0.f, 0.f };
slConstants.cameraPos = *(sl::float3*)&eyePosition;
slConstants.cameraFwd = *(sl::float3*)&cameraData.viewForward;
slConstants.cameraUp = *(sl::float3*)&cameraData.viewUp;
slConstants.cameraRight = *(sl::float3*)&cameraData.viewRight;
slConstants.cameraViewToClip = *(sl::float4x4*)&cameraData.viewMat;
slConstants.clipToCameraView = *(sl::float4x4*)&clipToCameraView;
slConstants.clipToPrevClip = *(sl::float4x4*)&cameraToPrevCamera;
slConstants.depthInverted = sl::Boolean::eFalse;
slConstants.jitterOffset = { 0, 0 };
slConstants.mvecScale = { 1, 1 }; // Adjust based on motion vector scale
slConstants.prevClipToClip = *(sl::float4x4*)&prevCameraToCamera;
slConstants.reset = sl::Boolean::eFalse;
slConstants.motionVectors3D = sl::Boolean::eFalse;
slConstants.motionVectorsInvalidValue = FLT_MIN;
slConstants.orthographicProjection = sl::Boolean::eFalse;
slConstants.motionVectorsDilated = sl::Boolean::eFalse;
slConstants.motionVectorsJittered = sl::Boolean::eFalse;
if (SL_FAILED(res, slGetNewFrameToken(currentFrame, nullptr))) {
logger::error("[Streamline] Could not get frame token");
if (SL_FAILED(res, slSetConstants(slConstants, *currentFrame, viewport))) {
logger::error("[Streamline] Could not set constants");
