Hi, i am now learning the cortex and run the examples, in the tutorial it can Drag the target through the coordinate axis in the viewport ,but the axis do not show in my application:
I’m not sure why the axes aren’t showing up with that configuration (looks like you’ve selected the move widget and selected the motion_commander_target prim). If you switch to the pointer on the left and then back to the move widget, does it show up?
One thing is, for that demo, you should be dragging the FollowSphere (the purple sphere) rather than the motion_commander_target prim. The behavior will get the end-effector to follow the FollowSphere which automatically moves the motion_commander_target prim. One way to select the FollowSphere is to just directly click on the purple sphere in the viewport.
