Jetbot isn't moving in Isaac Sim
Hi all,
Context - I have real world coordinates that I would like to pass as UTM coordinates to Jetbot and make it move along the roads in CityEngine 3D Model that would be added to the scene in Isaac Sim.CityEngine model(San Diego, CA) uses UTM coordinates as well.
Issue - my Jetbot can move on the default ground plane between the sequence of waypoints without issues, but when I pass UTM coordinates(they are all big numbers like x=400k and y=1M, e.g. [485249.52187495545,3619255.632121088,0]), Jetbot isn’t moving, but I see spinning wheels.
I wonder if when I pass big numbers as a coordinates to my robot, physics applied differently to the robots.
Question - what can be the root cause of this issue and how can I resolve it.
Hi @slugovoy , can you share the code snippets to help resolve the issue?
Hi @rthaker sorry for the very late response. I’ve resolved that issue by creating a reference point and basically moving the whole 3D cityEngine model to (0,0,0). Now my Jetbot is moving on the city roads, but with one issue - it does not move in negative X coordinates on straight line(e.g from (-7,200,0) to (-90,200,0)). Would you be able to point me why is it happening? Thanks!
P.S.: Code snippets are below
  1. Robot class
class RobotMoving(BaseTask):
    def __init__(self, name, offset=None, robot_index=None):
        super().__init__(name=name, offset=offset)
        self._extension_data_path = "source/extensions/deloitte.cuopt_app.moving_to_target/data/"  # noqa: E501
        self._robot_index = robot_index
        self.offset = offset
        self._locations_obj = TransportOrders()
        self._load_orders()
        self._jetbot_goal_position = np.array(self._locations_obj.graph_locations[self._robot_index][1])
        self._task_achieved = False
        self._coord_indx = 1
        print(f"JETBOT {self._robot_index} navigating to {self._jetbot_goal_position}")
        return
    # Here we setup all the assets that we care about in this task.
    def set_up_scene(self, scene):
        super().set_up_scene(scene)
        scene.add_ground_plane(
            size=1000,
            color=np.array([0.38, 0.5, 0.5])
        # Find a unique scene name
        jetbot_name = find_unique_string_name(
            initial_name="fancy_jetbot", is_unique_fn=lambda x: not self.scene.object_exists(x)
        # Find a unique prim path
        jetbot_prim_path = find_unique_string_name(
            initial_name="/World/Fancy_Jetbot", is_unique_fn=lambda x: not is_prim_path_valid(x)
        assets_root_path = get_assets_root_path()
        jetbot_asset_path = assets_root_path + "/Isaac/Robots/Jetbot/jetbot.usd"
        self._jetbot = scene.add(
            WheeledRobot(
                prim_path=jetbot_prim_path,
                name=jetbot_name,
                wheel_dof_names=["left_wheel_joint", "right_wheel_joint"],
                create_robot=True,
                usd_path=jetbot_asset_path,
                # position=np.array([0, 0.3, 0]) + self._offset
                # position=np.array([-7.19, 318.85, 0.0]) + self._offset
                position=np.array(self._locations_obj.graph_locations[self._robot_index][0]) + self._offset
                # position=np.array([-21.19, 3.12, 0.0]) + self._offset
  1. How I pass next goal to the robot
def pre_step(self, control_index, simulation_time):
        current_jetbot_position, _ = self._jetbot.get_world_pose()
        # np_mean = np.mean(np.abs(current_jetbot_position[:2] - self._jetbot_goal_position[:2]))
        np_mean = np.mean(np.abs(self._jetbot_goal_position[:2] - current_jetbot_position[:2]))
        if not self._task_achieved and np_mean < 0.6 and self._coord_indx == (len(self.task_data["task_locations"])-1):
            print("GOAL HAS BEEN REACHED")
            self._task_achieved = True
        elif self._coord_indx < (len(self.task_data["task_locations"])-1) and not self._task_achieved and (np_mean > 1.2 and np_mean < 1.8):
            self._coord_indx += 1
            self._jetbot_goal_position = np.array(self.task_data["task_locations"][self._coord_indx])  # noqa E501
        return
  1. That is the World where I use Robot’s class
class HelloWorld(BaseSample):
    def __init__(self) -> None:
        super().__init__()
        # Add lists for tasks,
        self._tasks = []
        self._num_of_robots = 0
        #  Add lists for controllers
        self._jetbot_controllers = []
        # Add lists for variables needed for control
        self._jetbots = []
        return
    def setup_scene(self):
        self._num_of_robots = self.get_number_of_vehicles()
        # self._num_of_robots = 1
        world = self.get_world()
        for i in range(self._num_of_robots):
            world.add_task(RobotMoving(name="my_awesome_task_" + str(i), offset=np.array([0, (i * 3.5) - 1.0, 0]), robot_index=i))  # noqa: E501
        return
    async def setup_post_load(self):
        self._world = self.get_world()
            self._tasks.append(self._world.get_task(name="my_awesome_task_" + str(i)))
            # Get variables needed for control
            task_params = self._tasks[i].get_params()
            self._jetbots.append(self._world.scene.get_object(task_params["jetbot_name"]["value"]))
            # Define Controllers
            self._jetbot_controllers.append(WheelBasePoseController(name="cool_controller",
                                            open_loop_wheel_controller=DifferentialController(name="simple_control", wheel_radius=0.198, wheel_base=0.66750)))  # noqa: E501  # noqa: E128
        self._world.add_physics_callback("sim_step", callback_fn=self.physics_step)
        await self._world.play_async()
        return
    async def setup_post_reset(self):
        for i in range(len(self._tasks)):
            # Reset controller
            self._jetbot_controllers[i].reset()
        return
    def physics_step(self, step_size):
        # Gets all the tasks observations
        current_observations = self._world.get_observations()
            goal_x, goal_y, goal_z = current_observations[self._jetbots[i].name]["goal_position"]
            # print("Navigating directly to goal ({}, {}, {})".format(goal_x, goal_y, goal_z))
            self._jetbots[i].apply_wheel_actions(
                    self._jetbot_controllers[i].forward(
                        start_position=current_observations[self._jetbots[i].name]["position"],
                        start_orientation=current_observations[self._jetbots[i].name]["orientation"],
                        goal_position=current_observations[self._jetbots[i].name]["goal_position"],
                        lateral_velocity=1.6,
                        yaw_velocity=0.8,))
        return
Hi @slugovoy - Sincere apologies for the late response. Please let us know if you still have any issues with the latest Isaac Sim release.
