Docker desktop on Orin Nano? any users experiences
as all of you guys, i am using docker containers for my apps, but i know there is a docker desktop release for arch-based linux dist available. it comes with its documentation:
Arch | Docker Docs
Do you recommend to install it on the Jetson Orin Nano? — super 8gb
(as the desktop version make it eaiser to manage containers, images and volumes)
thanks
The Jetson Orin Nano is a powerful device, and using Docker containers is a great way to manage your applications. The Docker Desktop release for Arch-based Linux distributions is a great tool for managing containers, images, and volumes.
However, before installing Docker Desktop on your Jetson Orin Nano, you should consider a few things:
  1. Resource constraints: The Jetson Orin Nano has limited resources (CPU, memory, and storage) compared to a typical desktop or laptop. Docker Desktop is designed for more powerful systems, and it may consume more resources than the command-line Docker tools.
  2. Compatibility: Docker Desktop is designed for x86-64 architectures, and the Jetson Orin Nano is an ARM-based device. While Docker Desktop may work on the Jetson Orin Nano, there might be compatibility issues or limitations.
  3. Performance: The Jetson Orin Nano’s performance may be affected by running Docker Desktop, especially if you’re running multiple containers or resource-intensive applications.
That being said, if you still want to install Docker Desktop on your Jetson Orin Nano, you can follow the instructions in the Arch Docker Docs. Keep in mind that you may need to perform a manual installation, as the Jetson Orin Nano is not a typical desktop or laptop.
Here are some pros and cons to consider:
Pros:
  • Easier management of containers, images, and volumes using a graphical user interface (GUI)
  • Simplified workflow for developers and non-technical users
  • Integration with other Docker tools and services
Cons:
  • Potential resource constraints and performance issues
  • Compatibility issues or limitations due to the ARM architecture
  • May require manual installation and configuration
If you decide to install Docker Desktop on your Jetson Orin Nano, make sure to monitor your system’s resources and performance. You can always switch back to using the command-line Docker tools if you encounter any issues.
In comparison, the command-line Docker tools are:
  • More lightweight and resource-efficient
  • Specifically designed for Linux and ARM architectures
  • Provide more control and flexibility for advanced users
However, they may require more technical expertise and manual configuration.
Ultimately, the decision to install Docker Desktop on your Jetson Orin Nano depends on your specific needs and preferences. If you value ease of use and a GUI, Docker Desktop might be a good choice. If you prioritize resource efficiency and flexibility, the command-line Docker tools might be a better fit.
Hello @uriel.deveaud,
I haven’t had a chance to play with docker desktop on a Jetson device yet.
Although, in our experience, it is best to keep everything headless and automated for production. Given that managing Docker at scale with multiple devices is easier if you simply have to deal with a docker compose file or a script.
best regards,
Andrew
We don’t have too much experience with Docker Desktop.
Maybe other users can share their experience.
