Does Drive Thor platform has DSP?
DRIVE OS Version: Provide DRIVE OS version. Example: 7.0.3
Issue Description: Provide issue description and attached logs as text message instead of images
Hello sir,
I’m researching on Drive Thor SoC. and curious about the existence of physical DSP chip (conventional DSP chip like ADI, Cadence, etc.) So I searched on the web but I could not find concrete clue whether there exist DSP or not.
Some forum says it has dual HiFi5 (NVIDIA Jetson Thor: New SoC Features Guide | RidgeRun Developer Wiki) but it’s Jetson platform, not Drive platform.
I read the article that NVIDIA platform utilized ARM cortex cores as APE (Audio Processing Engine)
is Drive platform also uses ARM core as APE?
Dear @djlee8 ,
The available accelerators/engines are listed under Specifications at DRIVE AGX Autonomous Vehicle Development Platform | NVIDIA Developer
Audio is not supported on DRIVE AGX devkits.
May I know your use case details?
Could you please provide any update for this topic?
Hi @SivaRamaKrishnaNV and @carolyuu thanks for the feedback. the actual use-case details is automotive sound systems such as chimes, alerts, multi-media processing, voice ECNR, etc.
Although conventional historical architecture relies on DSP chips customarily, ARM architecture already had been expanding its capacity to support various signal processing. I think that’s why some previous NVIDA platforms utilized Arm core rather than dedicated DSP chip. QNX’s sound solution also provides this flexibility, scalability by enabling those use-cases to be ported on ARM cores with more standardized interface and dev environment. So I wondered NVIDA is also acknowledged this and skipping DSPs by replacing it with ARM cores to enable more scalable environment.
Dear @djlee8 ,
Yes. ARM cores are used for audio processing on DRIVE. But note that audio is not enabled on DevZone DRIVE OS release.
