Hi.
nVIDIA Staff.
Even if the FAN is forcibly stopped while the FAN is rotating, the message that the FAN is locked does not appear.
In R28.1 based Linux / Jetpack, is not FAN lock detection done?
In the developer kit, the FAN_TACH signal is connected to Jetson, but is there a mechanism of Tegra that can detect locking?
best regard.
@BlueYatagarasu
This FAN TACHOMETER is not support on TX1 but TX2.
You can find the REG from TX2 TRM, and kernel driver locate …/kernel/t18x/drivers/tachometer/*
Hi.
ShaneCCC
Thank you for answering.
How to install the tachometer driver?
best regard.
For TX2 I believe it already build in the default kernel Image.
Hi.
ShaneCCC
sorry…
Our Platform is Jetson_TX1…
Right as I say this function not support on TX1.
Impossible to install driver? (…/kernel/t18x/drivers/tachometer/)
Is Jetson_TX 1 hardware not supported?
Yes, I am sorry TX1 chip not support it.
Hi @ShaneCCC
Can you explain exactly why TX1 doesn’t support it?
To me this doesn’t make sense at all… unless TX2 has a hardware timer counter which is used to count the revolutions with that the TX1 doesn’t have…
Please explain.
Lasse
@LasseRoedtnes
You can check the TX1/TX2 TRM to know it. TX2 have relative “Tachometer” registers but TX1 didn’t have it.
