Does Orin supports having multiple guest operating systems/different containers running parallelly using Hypervisors
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
Android
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
<Does Orin or any NVidia platform supports having multiple guest operating systems/different containers running parallelly using Hypervisors.
our use case :
wanted to run different types apps of cockfit/cluster/ADAS on their corresponding clusters/virtual machines
If yes, pls provide the documents which I need to refer.
Thanks in advance.
Error String
< Please provide just the error messages here >
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text box
Dear @sudarsanarao.makupalli.yg ,
Please see Autonomous Vehicle Virtual Machine Configuration | NVIDIA Docs
Devzone release support single guest OS(linux)
Hi Siva,
Thanks for sharing the link, could you give more details like memory carveout regions for different VMs and more on clusters how to create and maintain. Are you using any hypervisor if so can you give more details about it.
Thanks,
Sudarsan
We use Type1 hypervisor.
Could you elaborate your use case?
I mean to say how much of % memory can be used for guest VMs at max and CPUs too and where these can be configured?
Does THOR and Orin support IVI Android ?
Thanks,
Sudarsanarao
Which Hypervisor do use the name of it ?
Configuration of VM is out of forum support scope.
The devzone supports only AV+L configuration(linux).
Thanks Siva . But who can support on this? can you connect me to right point of contact? if not Forum
Could you reach out to your NVIDIA representative to evaluate your request on multi GOS support and configuration and further guidance.
