Does QUADRO P4000 support XenApp 7.15?
Hello! Can someone kindly advise how to make a QUADRO P4000 works in Windows Server 2016 for XenApp 7.15?
Hi
Install it as Passthrough (assuming you’re using a Hypervisor), use the standard Quadro driver from NVIDIA website.
Enable the "Use the hardware default graphics adapter for all Remote Desktop Services sessions" Group Policy to enable the OS to use the GPU.
Lastly, configure your Citrix Policies appropriately.
Regards
MG
Thank you sir! Actually i don’t have any Hypervisor, i just install Windows Server 2016 as host O/S and want to use XenApp, does it work?
Hi
Sure, that will work just fine.
Install the Windows OS > Install the NVIDIA Driver > Join the Domain > Install XenApp (this will automatically install the appropriate Server Roles (RDSH)) > Install all Windows Updates > Install the Applications > Check for Windows Updates again > Optimise and clean up the OS > Assign User access through Citrix Studio > Log in with Users and test … Easy ;-)
Make sure you enable that Group Policy mentioned above. Without it, the XenApp Server won’t use the GPU.
Regards
MG
