Dp output error on jetson orin nx
follow the design of Design_Guide_DG-10931-001_v1.1, figure 9-1
when plug in the DP cable,the DP1-HPD is correct,but no DP signal
is the hardwire design uncorrect ?
the jetson would check anyother enable signal for DP output ??
please try to share clear schematic. I am not even able to read the word in your schematic with zoom in.
the issue have been fixed,figure 9-1,only supports DP to DP,first time ,we used a DP to HDMI port.
