DRIVE OS SDK Container Missing from NGC Catalog
Software Version
DRIVE OS 6.0.10.0
Target Operating System
Linux
Hardware Platform
Host Machine Version
Issue Description
I have an issue with NGC. I have access to the NVIDIA DRIVE SDK through the developer portal (developer.nvidia.com). However, when I try to download the container for DRIVE OS, I run into a problem.
When I go to select the NGC organization, I can see “drive”, and inside it again “drive”, but after selecting it, I’m redirected back to the main NGC Catalog page (https://catalog.ngc.nvidia.com/).
According to the instructions, there should be a driveos-sdk container available, but I don’t see it listed anywhere.
Dear @daniel.suchanek ,
Did you join NVIDIA DRIVE® AGX SDK Developer Program | NVIDIA Developer ? If not, please join the program.
Could you please share the NGC organization where you see drive/drive option?
I have already joined the DRIVE AGX SDK Developer Program, and I can see that my membership is active. However, when I try to access the DRIVE SDK container via the terminal using the provided token (as described in the instructions), I’m unable to reach the container registry.
Additionally, when I check https://catalog.ngc.nvidia.com/ for containers, the “drive” organization link redirects me back to the homepage.
Could you please check if there’s an issue with my account or with the DRIVE container access?
Noticed issue with your NGC account. We are working on fix and update you.
Hi @daniel.suchanek ,
Could you please check now if it fixed?
Yes, it works.
Thanks for your help.
Thanks for confirmation. Closing the topic.
