Drive Update feature for OTA : Understanding & Usage
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Hi team,
As mentioned in the Drive OS software stack attached below, regarding “Drive Update” Services for the OTA use-case, what services/sdks/api’s are provided in Drive OS Stack is not mentioned anywhere in the documentation available for Drive Orin. Could you provide information regarding this.
Our use-case is " We are developing container based ADAS applications on guest VM having Drive OS, Drive-works middleware & docker runtime as the underlying layers using docker services of Drive OS.
So can we update specific containers using the Update Services or the complete software on the VM can be updated?
Let me know if more information is required.
Dear @saurabh.sinalkar,
DRIVE OTA is not supported in Devzone release.
Dear @SivaRamaKrishnaNV,
In which releases it is supported?
Currently we don’t have plan to support in DRIVE OS SDK(Devzone releases). If this is a critical requirement for you, please contact your NVIDIA representative for support on this and further guidance.
Dear @SivaRamaKrishnaNV ,
Do you mean its supported only in Nvonline partner releases?
Correct, please contact your NVIDIA representative for support on this and further guidance.
