Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.7.1.8928
Host Machine Version
native Ubuntu 18.04
My configuration:
Hardware:
Nvidia Jetson AGX Dev Kit
Connect Tech’s Rogue Carrier Board
Connect Tech JCB002
NileCam30
Software:
Nvidia: L4T 32.4.4
JetPack : JetPack_4.4.1_Linux_JETSON_AGX_XAVIER
Connectt Techs: CTI-L4T-AGX-32.4.4-V005
I need to add traces to the driver ar0330 (driver of camera NileCam30).
to do a test I compile on an ubuntu PC then I flash the nvidia card.
this takes a long time.
Is it possible to define the driver as a module and only flash the nvidia card once?
Then, if i modify the driver, to compile in order to create the driver.ko and to copy on the card nvidia only the driver.ko with a USB key.
This would be less time consuming than flashing the nvivia card for each test?
Can you help on this point ?
Best regards
Brahim
