Ok, Well then the problem is that this driver cannot install on my Windows 7 or Windows 8.1 system. The release notes specifically mention Windows 7/8/10;
Release 367 Graphics Drivers
for Windows, Version 369.05
RN-W36905-01v01 | August 2, 2016
Windows 10 / <b>Windows 8.1 / Windows 8 / Windows 7</b>
but that driver will not install after checking system capability.
The only supported product for the 369.05 driver is Pascal Titan X (take a look at the supported products tab). Do you have a Pascal Titan X in these systems?
I receive the Pascal Titan X tomorrow, so not yet. Just wanted to set up the environment before installation.
Ok, so I made a mistake in that I understood the “not compatible system” driver install message to be related to the operating system, rather than the hardware(the Pascal Titan X). The fact the driver download only mentioned Windows 10 may have also influenced my thinking.
I now have a Pascal Titan X in my Windows 7 system and the 369.05 driver will not install because it says I have the wrong version of Windows (even though the documentation says Windows 7 is supported).
EDIT: I found the version for Windows 7 which is not the same as the earlier one. This seems to have been the issue as I am installing now.
It’s true that the win10 369.05 driver is not the same as the win7/win8 369.05 driver in this case.
This is somewhat unusual but possible, obviously. This driver is also somewhat unusual in that it supports only Pascal Titan X.
In any event, when selecting a driver for your GPU, its recommended that you go to www.nvidia.com and use the driver download system there. If you give it all the right information (including e.g. OS) it should steer you to the correct driver to use.
Currently the win7/win8 driver download is this one:
Using windows 10 64bit, installed the Titan X Pascal, ran the GeForce Experience and got the “Not compatible with this version of Windows”. Went to the main site and selected down the “Find your drivers” list and downloaded, extracted and attempted to install and again “Not compatible…”
Searched around, found this page and saw the link in the post above, verified that is the same driver I have.
