DS 6.1 - Number of detected objects (pgie) does NOT exceed 20
• Hardware Platform (Jetson / GPU) → NVIDIA GeForce GTX 1650
• DeepStream Version → 6.1
• JetPack Version (valid for Jetson only) NA
• TensorRT Version → TensorRT 8.2.5.1
• NVIDIA GPU Driver Version (valid for GPU only) NVIDIA driver 515
• Issue Type( questions, new requirements, bugs) Question
Hello, I’m running a Retina Face primary detector using deepstream python sample applications as a reference.
My problem is that objectList in the posprocessing function in C++ shows +40 objects detected, while the number of objects after returning to python code is capped at 20.
std::vector NvDsInferObjectDetectionInfo &objectList
The video I’m using contains at least 50 faces. Which is confirmed by the List size in c++ vDsInferParseCustomRetinaFace function. But Python code only shows 20, and while running Deepstream the shown bounding boxes are only 20. I know the model is detecting more but for some reason DS only shows a max of 20.
Here are the inputs which may help you identify the problem.
config_Retinaface.txt FIle
[property]
gpu-id=0
# model-engine-file=../../data/models/Retina_Mobilenet_-1_3_640_640_dynamic.engine
# model-engine-file=../../data/models/RetinaFace_-1_3_1920_1080_dynamic.engine
# model-engine-file=../../data/models/RetinaFace_res50_640_640_dynamic.engine
model-engine-file=../../data/models/RetinaFace_res50_1920_1080_dynamic.engine
# model-engine-file=../../data/models/Pytorch_RetinaFace_resnet50-720-1080.engine
# model-engine-file=../../data/models/Pytorch_RetinaFace_resnet50.engine
# model-engine-file=../../data/models/RetinaFace_-1_3_512_512_dynamic.engine
# model-engine-file=../../data/models/RetinaFace_-1_3_720_720_dynamic.engine
labelfile-path=../../data/models/Retinaface_labels.txt
batch-size=4
net-scale-factor=1.0
offsets=104.0;117.0;123.0
force-implicit-batch-dim=1
model-color-format=1
# Data format to be used by inference Integer 0: FP32 1: INT8 2: FP16
network-mode=0
process-mode=1
num-detected-classes=1
interval=0
gie-unique-id=1
parse-bbox-func-name=NvDsInferParseCustomRetinaFace
custom-lib-path=../nvdsinfer_customparser/libnvds_RetinaFaceParser.so
maintain-aspect-ratio=1
[class-attrs-all]
# bbox threshold [Resnet .80]
pre-cluster-threshold=0.1
# nms threshold
post-cluster-threshold=0.2
nvdsinfer_RetinaFaceParser.cpp file:
 * Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include "nvdsinfer_custom_impl.h"
#include <algorithm>
#include <cassert>
#include <cmath>
#include <cstring>
#include <iostream>
#define MIN(a, b) ((a) < (b) ? (a) : (b))
#define MAX(a, b) ((a) > (b) ? (a) : (b))
#define CLIP(a, min, max) (MAX(MIN(a, max), min))
extern "C" bool NvDsInferParseCustomRetinaFace(std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
                                               NvDsInferNetworkInfo const &networkInfo,
                                               NvDsInferParseDetectionParams const &detectionParams,
                                               std::vector<NvDsInferObjectDetectionInfo> &objectList);
struct Bbox {
    int x1, y1, x2, y2;
    float score;
struct anchorBox {
    float cx;
    float cy;
    float sx;
    float sy;
void postprocessing(float *bbox, float *conf, float bbox_threshold, float nms_threshold, unsigned int topk, int width,
                    int height, std::vector<NvDsInferObjectDetectionInfo> &objectList);
void create_anchor_retinaface(std::vector<anchorBox> &anchor, int w, int h);
bool cmp(NvDsInferObjectDetectionInfo a, NvDsInferObjectDetectionInfo b);
void nms(std::vector<NvDsInferObjectDetectionInfo> &input_boxes, float NMS_THRESH);
                    int height, std::vector<NvDsInferObjectDetectionInfo> &objectList) {
    std::vector<anchorBox> anchor;
    create_anchor_retinaface(anchor, width, height);
    for (unsigned int i = 0; i < anchor.size(); ++i) {
        if (*(conf + 1) > bbox_threshold) {
            anchorBox tmp = anchor[i];
            anchorBox tmp1;
            NvDsInferObjectDetectionInfo result;
            result.classId = 0;
            // decode bbox
            tmp1.cx = tmp.cx + *(bbox + 0) * 0.1 * tmp.sx;
            tmp1.cy = tmp.cy + *(bbox + 1) * 0.1 * tmp.sy;
            tmp1.sx = tmp.sx * exp(*(bbox + 2) * 0.2);
            tmp1.sy = tmp.sy * exp(*(bbox + 3) * 0.2);
            result.left = (tmp1.cx - tmp1.sx / 2) * width;
            result.top = (tmp1.cy - tmp1.sy / 2) * height;
            result.width = (tmp1.cx + tmp1.sx / 2) * width - result.left;
            result.height = (tmp1.cy + tmp1.sy / 2) * height - result.top;
            // Clip object box coordinates to network resolution
            result.left = CLIP(result.left, 0, width - 1);
            result.top = CLIP(result.top, 0, height - 1);
            result.width = CLIP(result.width, 0, width - 1);
            result.height = CLIP(result.height, 0, height - 1);
            result.detectionConfidence = *(conf + 1);
            objectList.push_back(result);
        bbox += 4;
        conf += 2;
    std::sort(objectList.begin(), objectList.end(), cmp);
    std::cerr << "Before NMS objectList.size()" << objectList.size() << std::endl;
    nms(objectList, nms_threshold);
    std::cerr << "After NMS objectList.size()" << objectList.size() << std::endl;
    // TODO: Setup a limiter according to recognition model batch size.
    // if (objectList.size() > topk)
    //     objectList.resize(topk);
void create_anchor_retinaface(std::vector<anchorBox> &anchor, int w, int h) {
    anchor.clear();
    std::vector<std::vector<int>> feature_map(3), min_sizes(3);
    float steps[] = {8, 16, 32};
    for (unsigned int i = 0; i < feature_map.size(); ++i) {
        feature_map[i].push_back(ceil(h / steps[i]));
        feature_map[i].push_back(ceil(w / steps[i]));
    //std::vector<int> minsize1 = {10, 20};
    std::vector<int> minsize1 = {16, 32};
    min_sizes[0] = minsize1;
    //std::vector<int> minsize2 = {32, 64};
    std::vector<int> minsize2 = {64, 128};
    min_sizes[1] = minsize2;
    //std::vector<int> minsize3 = {128, 256};
    std::vector<int> minsize3 = {256, 512};
    min_sizes[2] = minsize3;
    for (unsigned int k = 0; k < feature_map.size(); ++k) {
        std::vector<int> min_size = min_sizes[k];
        for (int i = 0; i < feature_map[k][0]; ++i) {
            for (int j = 0; j < feature_map[k][1]; ++j) {
                for (unsigned int l = 0; l < min_size.size(); ++l) {
                    float s_kx = min_size[l] * 1.0 / w;
                    float s_ky = min_size[l] * 1.0 / h;
                    float cx = (j + 0.5) * steps[k] / w;
                    float cy = (i + 0.5) * steps[k] / h;
                    anchorBox axil = {cx, cy, s_kx, s_ky};
                    anchor.push_back(axil);
bool cmp(NvDsInferObjectDetectionInfo a, NvDsInferObjectDetectionInfo b) {
    if (a.detectionConfidence > b.detectionConfidence)
        return true;
    return false;
void nms(std::vector<NvDsInferObjectDetectionInfo> &input_boxes, float NMS_THRESH) {
    std::vector<float> vArea(input_boxes.size());
    for (int i = 0; i < int(input_boxes.size()); ++i) {
        vArea[i] = (input_boxes.at(i).width + 1) * (input_boxes.at(i).height + 1);
        for (int j = i + 1; j < int(input_boxes.size());) {
            float xx1 = std::max(input_boxes[i].left, input_boxes[j].left);
            float yy1 = std::max(input_boxes[i].top, input_boxes[j].top);
            float xx2 =
                std::min(input_boxes[i].left + input_boxes[i].width, input_boxes[j].left + input_boxes[j].width);
            float yy2 =
                std::min(input_boxes[i].top + input_boxes[i].height, input_boxes[j].top + input_boxes[j].height);
            float w = std::max(float(0), xx2 - xx1 + 1);
            float h = std::max(float(0), yy2 - yy1 + 1);
            float inter = w * h;
            float ovr = inter / (vArea[i] + vArea[j] - inter);
            if (ovr >= NMS_THRESH) {
                input_boxes.erase(input_boxes.begin() + j);
                vArea.erase(vArea.begin() + j);
            } else {
                j++;
    // Get output indexes
    static int bboxLayerIndex = -1;
    static int confLayerIndex = -1;
    for (unsigned int i = 0; i < outputLayersInfo.size(); i++) {
        if (strcmp(outputLayersInfo[i].layerName, "bbox") == 0) {
            bboxLayerIndex = i;
        } else if (strcmp(outputLayersInfo[i].layerName, "conf") == 0) {
            confLayerIndex = i;
    if ((bboxLayerIndex == -1) || (confLayerIndex == -1)) {
        std::cerr << "Could not find output layer buffer while parsing" << std::endl;
        return false;
    // Host memory for "decode"
    float *bbox = (float *)outputLayersInfo[bboxLayerIndex].buffer;
    float *conf = (float *)outputLayersInfo[confLayerIndex].buffer;
    // Get thresholds and topk value
    const float bbox_threshold = detectionParams.perClassPreclusterThreshold[0];
    const float nms_threshold = detectionParams.perClassPostclusterThreshold[0];
    const unsigned int rec_batch_size = 50; // TODO: Get rec_batch_size from configurations, and use it as limiter
    // Do post processing
    postprocessing(bbox, conf, bbox_threshold, nms_threshold, rec_batch_size, networkInfo.width, networkInfo.height, objectList);
    std::cerr << "After postprocessing objectList.size()" << objectList.size() << std::endl;
    return true;
/* Check that the custom function has been defined correctly */
CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(NvDsInferParseCustomRetinaFace);
tiler_sink_pad_buffer_probe Function that output the number of Objects
def tiler_sink_pad_buffer_probe(pad, info, u_data):
    frame_number = 0
    num_rects = 0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        frame_number = frame_meta.frame_num
        l_obj = frame_meta.obj_meta_list
        num_rects = frame_meta.num_obj_meta
        is_first_obj = True
        save_image = False
        obj_counter = {
            PGIE_CLASS_ID_FACE: 0
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
                # Define an analyze_meta function to manipulate metadata
                break
            obj_counter[obj_meta.class_id] += 1
            faces_count["stream_{}".format(frame_meta.pad_index)] += 1
            try:
                l_obj = l_obj.next
                break
        print("Frame Number=", frame_number, "Number of Objects=", num_rects, "Face_count=",
              obj_counter[PGIE_CLASS_ID_FACE])
        # update frame rate through this probe
        stream_index = "stream{0}".format(frame_meta.pad_index)
        global perf_data
        perf_data.update_fps(stream_index)
        saved_count["stream_{}".format(frame_meta.pad_index)] += 1
        try:
            l_frame = l_frame.next
            break
    return Gst.PadProbeReturn.OK
Sample Output from DS run:
**PERF:  {'stream0': 7.2}
Before NMS objectList.size() 82
After NMS objectList.size() 41
After postprocessing objectList.size() 41
Frame Number= 4 Number of Objects= 20 Face_count= 20
Before NMS objectList.size() 72
After NMS objectList.size() 35
After postprocessing objectList.size() 35
Frame Number= 5 Number of Objects= 20 Face_count= 20
Before NMS objectList.size() 81
After NMS objectList.size() 38
After postprocessing objectList.size() 38
Frame Number= 6 Number of Objects= 20 Face_count= 20
Before NMS objectList.size() 78
After NMS objectList.size() 40
After postprocessing objectList.size() 40
Frame Number= 7 Number of Objects= 20 Face_count= 20
Before NMS objectList.size() 83
After NMS objectList.size() 44
After postprocessing objectList.size() 44
Frame Number= 8 Number of Objects= 20 Face_count= 20
Before NMS objectList.size() 77
Frame Number= 9 Number of Objects= 20 Face_count= 20
Before NMS objectList.size() 91
Frame Number= 10 Number of Objects= 20 Face_count= 20
If you need anymore input from my side please let me know. Thank you.
Hi @yousef.hesham1 , Could you share your stream to us?
Which demo sample is used in deepstream python?
Could you provide your model from the google driver or other link? Thanks
Hi @yuweiw Thanks for the quick response!
You can find the video used: Bridge London_2160.webm - Google Drive
I’m using the apps/­deepstream-imagedata-multistream Sample application
You can find both engine and ONNX models here: Models - Google Drive
Hi @yousef.hesham1 , I use your stream as a source to test the deepstream-imagedata-multistream. It shows more than 20 object. We have no limit for this number.
====>objectList in the posprocessing function in C++ shows +40 objects detected
Do you use the same model to test it?
Which demo sample is used in deepstream C++?
Hello @yuweiw , I only tested it with the multi-stream sample. The model used is attached above in a google drive link.
Did you use the model provided earlier? (ONNX).
And
=====>Did you use the model provided earlier? (ONNX).
No, I use the model in our demo. Because the engine file is related to your env, I cannot use it directly. But when I use your onnx model, it cannot create engine in my env. Could you please attach how you run the demo with your onnx model step by step and the lable file(Retinaface_labels.txt). Thanks
Hello @yuweiw , You can use this ONNX file along with the following trtexc command to generate .engine:
trtexec --onnx=./RetinaRes50_-N_3_640_640.onnx --fp16 --explicitBatch --saveEngine=./RetinaRes50_-N_3_640_640.engine --optShapes=input:8x3x640x640 --maxShapes=input:8x3x640x640 --minShapes=input:1x3x640x640
This is to generate a engine file for a maximum of 8 streams using the ONNX provided (640x640)
Pgie configuration is available in my original post.
Retinaface_labels.txt file can found here
Please let me know how it goes and if you need anymore inputs from me.
I use your onnx model to test. The object number mismatch between the post process and the python demo too. The reason of this problem is the cluster algorithm. It filtered out some unqualified object. You can set up the cluster mode by yourself. Just refer the link below:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvinfer.html
That solved it, many thanks
