Having a problem as described in topic.
Steps to reproduce:
/usr/local/driveworks/tools/capture/recorder-tui 4cam.json
(the4cam.jsonfile is for 4x sf3325 cameras) -
Use
dwSensorManager_acquireNextEventanddwSensorCamera_getImagein a loop with the recording in step 1. I used a simplified version ofsample_sfm. -
Add
dwImage_getTimestampto get timestamp and display it for debugging, e.g.
void processCamera(const dwSensorEvent& event)
for (size_t k = 0; k < event.numCamFrames; k++)
dwTime_t currentTimestamp;
CHECK_DW_ERROR(dwImage_getTimestamp(¤tTimestamp, camera.frameCudaYuv));
std::cout << k << " " << currentTimestamp << std::endl;
Expected:
The timestamps should be in consecutive order because dwSensorManager_acquireNextEvent should return “oldest available event among all sensors”
Actual:
Timestamps not consecutive, e.g.:
0 1619516073418415
1 1619516073551740
2 1619516073651728
3 1619516073751751
dwSensorManager_acquireNextEvent DW_SUCCESS
0 1619516073451730
1 1619516073585055
2 1619516073685076
3 1619516073785099
Extra notes
When the same 4cam.json is used directly by the same application based on sample_sfm, timestamps are in order, e.g.
0 1619517985418409
1 1619517985418409
2 1619517985418409
3 1619517985418409
0 1619517985451753
1 1619517985451753
2 1619517985451753
3 1619517985451753
However, there are hundreds (474) of lines worth of ICP DROP messages before processCamera is even reached, e.g.
[27-04-2021 20:06:12] CameraGMSL: Frame: 12 CaptureTimestamp: 1619517972618426 - ICP DROP in camera 2
[27-04-2021 20:06:12] CameraGMSL: Frame: 12 CaptureTimestamp: 1619517972618426 - ICP DROP in camera 0
[27-04-2021 20:06:12] CameraGMSL: Frame: 12 CaptureTimestamp: 1619517972618426 - ICP DROP in camera 1
[27-04-2021 20:06:12] CameraGMSL: Frame: 12 CaptureTimestamp: 1619517972618426 - ICP DROP in camera 3
[27-04-2021 20:06:12] CameraGMSL: Frame: 13 CaptureTimestamp: 1619517972651757 - ICP DROP in camera 2
[27-04-2021 20:06:12] CameraGMSL: Frame: 13 CaptureTimestamp: 1619517972651757 - ICP DROP in camera 1
[27-04-2021 20:06:12] CameraGMSL: Frame: 13 CaptureTimestamp: 1619517972651757 - ICP DROP in camera 3
[27-04-2021 20:06:12] CameraGMSL: Frame: 13 CaptureTimestamp: 1619517972651757 - ICP DROP in camera 0
But it settles down after a few seconds:
[27-04-2021 20:06:16] CameraGMSL: Frame: 128 CaptureTimestamp: 1619517976485100 - ICP DROP in camera 3
[27-04-2021 20:06:16] CameraGMSL: Frame: 129 CaptureTimestamp: 1619517976518435 - ICP DROP in camera 3
[27-04-2021 20:06:16] CameraGMSL: Frame: 129 CaptureTimestamp: 1619517976518435 - ICP DROP in camera 2
[27-04-2021 20:06:16] CameraGMSL: Frame: 129 CaptureTimestamp: 1619517976518435 - ICP DROP in camera 1
[27-04-2021 20:06:16] CameraGMSL: Frame: 129 CaptureTimestamp: 1619517976518435 - ICP DROP in camera 0
0 1619517972518428
1 1619517972518428
2 1619517972518428
3 1619517972518428
0 1619517972551750
1 1619517972551750
2 1619517972551750
3 1619517972551750
0 1619517972585103
1 1619517972585103
2 1619517972585103
3 1619517972585103
[27-04-2021 20:06:16] CameraGMSL: Frame: 130 CaptureTimestamp: 1619517976551743 - ICP DROP in camera 0
[27-04-2021 20:06:16] CameraGMSL: Frame: 130 CaptureTimestamp: 1619517976551743 - ICP DROP in camera 3
[27-04-2021 20:06:16] CameraGMSL: Frame: 130 CaptureTimestamp: 1619517976551743 - ICP DROP in camera 2
[27-04-2021 20:06:16] CameraGMSL: Frame: 130 CaptureTimestamp: 1619517976551743 - ICP DROP in camera 1
0 1619517976585086
1 1619517976585086
2 1619517976585086
3 1619517976585086
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
