Hi
I’ve just disabled the CSM in my UEFI BIOS in-order to use a fully EFI startup. Everything is working fine, except that GRUB picks the secondary monitor to display on.
My primary monitor is connected via DVI-D-0, and is what the BIOS is displayed on. When GRUB starts, it switches to the secondary monitor on DP-4. When the nvidia driver loads, it gets both monitors correctly.
Is there anyway to change which monitor is used by default?
Thanks & Regards
elFarto
